GANJUBASS Posted July 31, 2014 Posted July 31, 2014 Доброго всем времени суток! Возникла такая проблема: с начала месяца бывают моменты что на некоторых БС Roket M2 отпадают клиенты каждые несколько секунд причем все одновременно за исключением одного двух.. у юзеров все точки ubnt M серии. До этого в течении 2 лет таких проблем не было. Если у кого были такие проблемы, буду очень благодарен за совет решения данной ситуации!!! Вот Log с клиентской точки. Jan 29 02:41:15 wpa-supplicant: Trying to associate with dc:9f:db:77:77:77 (SSID='G' freq=2472 MHz) Jan 29 02:41:15 wireless: ath0 Set Mode:Managed Jan 29 02:41:15 wireless: ath0 Set Frequency:2.472 GHz (Channel 13) Jan 29 02:41:15 wireless: ath0 New Access Point/Cell address:DC:9F:DB Jan 29 02:41:15 wpa-supplicant: Associated with dc:9f:db:77:77:77 Jan 29 02:41:15 wpa-supplicant: WPA: Key negotiation completed with dc:9f:db:77:77:77 [PTK=CCMP GTK=CCMP] Jan 29 02:41:15 wpa-supplicant: CTRL-EVENT-CONNECTED - Connection to dc:9f:db:77:77:77 completed (auth) [id=0 id_str=] Jan 29 02:41:18 wpa-supplicant: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Jan 29 02:41:18 wireless: ath0 Received deauth from dc:9f:db:77:77:77. Reason: Unspecified (1). Jan 29 02:41:18 wireless: ath0 New Access Point/Cell address:Not-Associated Jan 29 02:41:21 wireless: ath0 Scan request completed Jan 29 02:41:21 wpa-supplicant: Trying to associate with dc:9f:db:77:77:77 (SSID='G' freq=2472 MHz) Jan 29 02:41:21 wireless: ath0 Set Mode:Managed Jan 29 02:41:21 wireless: ath0 Set Frequency:2.472 GHz (Channel 13) Jan 29 02:41:21 wireless: ath0 New Access Point/Cell address:DC:9F:DB:77:77:77 Jan 29 02:41:21 wpa-supplicant: Associated with dc:9f:db:77:77:77 Jan 29 02:41:21 wpa-supplicant: WPA: Key negotiation completed with dc:9f:db:77:77:77[PTK=CCMP GTK=CCMP] Jan 29 02:41:21 wpa-supplicant: CTRL-EVENT-CONNECTED - Connection to dc:9f:db:77:77:77completed (reauth) [id=0 id_str=] Jan 29 02:41:23 wpa-supplicant: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Jan 29 02:41:23 wireless: ath0 Received deauth from dc:9f:db:77:77:77. Reason: Unspecified (1). Jan 29 02:41:23 wireless: ath0 New Access Point/Cell address:Not-Associated Jan 29 02:41:25 wireless: ath0 Scan request completed Jan 29 02:41:33 wireless: ath0 Scan request completed Jan 29 02:41:41 wireless: ath0 Scan request completed Jan 29 02:41:41 wpa-supplicant: Trying to associate with dc:9f:db:77:77:77 (SSID='G' freq=2472 MHz) Jan 29 02:41:41 wireless: ath0 Set Mode:Managed Jan 29 02:41:41 wireless: ath0 Set Frequency:2.472 GHz (Channel 13) Jan 29 02:41:41 wireless: ath0 New Access Point/Cell address:DC:9F:DB:77:77:77 Jan 29 02:41:41 wpa-supplicant: Associated with dc:9f:db:77:77:77 Jan 29 02:41:41 wpa-supplicant: WPA: Key negotiation completed with dc:9f:db:77:77:77 [PTK=CCMP GTK=CCMP] Jan 29 02:41:41 wpa-supplicant: CTRL-EVENT-CONNECTED - Connection to dc:9f:db:77:77:77 completed (reauth) [id=0 id_str=] Jan 29 02:41:45 wpa-supplicant: CTRL-EVENT-DISCONNECTED - Disconnect event - remove keys Jan 29 02:41:45 wireless: ath0 Received disassoc from dc:9f:db:77:77:77. Reason: Unspecified (1). Jan 29 02:41:45 wireless: ath0 New Access Point/Cell address:Not-Associated Jan 29 02:41:48 wireless: ath0 Scan request completed Jan 29 02:41:48 wpa-supplicant: Trying to associate with dc:9f:db:77:77:77 (SSID='G' freq=2472 MHz) Jan 29 02:41:48 wireless: ath0 Set Mode:Managed Jan 29 02:41:48 wireless: ath0 Set Frequency:2.472 GHz (Channel 13) Jan 29 02:41:48 wireless: ath0 New Access Point/Cell address:DC:9F:DB:77:77:77 Jan 29 02:41:48 wpa-supplicant: Associated with dc:9f:db:77:77:77 Jan 29 02:41:48 wpa-supplicant: WPA: Key negotiation completed with dc:9f:db:77:77:77 [PTK=CCMP GTK=CCMP] Jan 29 02:41:48 wpa-supplicant: CTRL-EVENT-CONNECTED - Connection to dc:9f:db:77:77:77 completed (reauth) [id=0 id_str=] Jan 29 02:41:48 wpa-supplicant: WPA: Key negotiation completed with dc:9f:db:77:77:77 [PTK=CCMP GTK=CCMP] Вставить ник Quote
Ferdin Posted July 31, 2014 Posted July 31, 2014 Наверно помеха, со стороны клиентов. Вставить ник Quote
GANJUBASS Posted July 31, 2014 Author Posted July 31, 2014 Наверно помеха, со стороны клиентов. А что моет служить такой сильной помехой.. Эфир при анализе довольно чистый, и к тому же базы разнесены по частотам. Вставить ник Quote
Ferdin Posted August 2, 2014 Posted August 2, 2014 Могут и клентские роутеры мешать, как вариант уходить на нестандартные частоты. Вставить ник Quote
NewUse Posted August 3, 2014 Posted August 3, 2014 пошивки на тд и клиенте одинаковые?, недавно обновлений не делали? Вставить ник Quote
GANJUBASS Posted August 4, 2014 Author Posted August 4, 2014 пошивки на тд и клиенте одинаковые?, недавно обновлений не делали? [Прошивки у юзеров в основном 5.5.6 и 5.5.8 на БС 5.5.8. Обновления делал но не на всех точках может на 25-30% Вставить ник Quote
GANJUBASS Posted August 4, 2014 Author Posted August 4, 2014 на счет роутеров у клиентов раньше же все было норм. И почему сразу на нескольких базах такое происходит.. Сигналы у всех очень хорошие и скорость. В какое то время начинается как буря, просто бардак, как вирус какой то)). Один раз в течении 2 часов в другой 3 раз даже 12. Одну базу на 10Мгц перевел вроде как на ней не видно проблем. Буду смотреть дальше)) Отпишусь.. Вставить ник Quote
SSD Posted August 4, 2014 Posted August 4, 2014 на счет роутеров у клиентов раньше же все было норм. И почему сразу на нескольких базах такое происходит.. Сигналы у всех очень хорошие и скорость. В какое то время начинается как буря, просто бардак, как вирус какой то)). Один раз в течении 2 часов в другой 3 раз даже 12. Одну базу на 10Мгц перевел вроде как на ней не видно проблем. Буду смотреть дальше)) Отпишусь.. Определенно помеха. Возможно рядом появилось 3г. Вставить ник Quote
