Коллеги, приветствую. Проблема с EX4200-24T, девайс новый, из коробки.
Включаем, идет бут:
U-Boot 1.1.6 (Feb 6 2008 - 11:27:42)
Board: EX4200-24T 2.17
EPLD: Version 6.0 (0x85)
DRAM: Initializing (1024 MB)
FLASH: 8 MB
USB: scanning bus for devices... 2 USB Device(s) found
scanning bus for storage devices... 1 Storage Device(s) found
Consoles: U-Boot console
Found compatible API, ver. 7
FreeBSD/PowerPC U-Boot bootstrap loader, Revision 2.1
(marcelm@apg-bbuild01.juniper.net, Wed Feb 6 11:23:55 PST 2008)
Memory: 1024MB
Loading /boot/defaults/loader.conf
/kernel data=0x7fcbac+0x8774c syms=[0x4+0x6ee90+0x4+0x9bae3]
Hit [Enter] to boot immediately, or space bar for command prompt.
Booting [/kernel]...
Kernel entry at 0xa00000e0 ...
GDB: no debug ports present
KDB: debugger backends: ddb
KDB: current backend: ddb
platform_early_bootinit: EX Series Early Boot Initialization
Copyright © 1996-2010, Juniper Networks, Inc.
All rights reserved.
Copyright © 1992-2006 The FreeBSD Project.
Copyright © 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
The Regents of the University of California. All rights reserved.
JUNOS 10.0S10.1 #0: 2010-11-08 21:23:50 UTC
builder@ormonth.juniper.net:/volume/build/junos/10.0/service/10.0S10.1/obj-powerpc/bsd/sys/compile/JUNIPER-EX
Timecounter "decrementer" frequency 50000000 Hz quality 0
cpu0: Freescale e500v2 core revision 2.2
cpu0: HID0 80004080<EMCP,TBEN,EN_MAS7_UPDATE>
real memory = 1050673152 (1002 MB)
avail memory = 1029038080 (981 MB)
ETHERNET SOCKET BRIDGE initialising
Initializing EXSERIES platform properties ...
nexus0: <PPC e500 Nexus device>
ocpbus0: <on-chip peripheral bus> on nexus0
openpic0: <OpenPIC in on-chip peripheral bus> iomem 0xfef40000-0xfef600b3 on ocpbus0
uart0: <16550 or compatible> iomem 0xfef04500-0xfef0450f irq 58 on ocpbus0
uart0: console (9600,n,8,1)
uart1: <16550 or compatible> iomem 0xfef04600-0xfef0460f irq 58 on ocpbus0
lbc0: <Freescale 8533 Local Bus Controller> iomem 0xfef05000-0xfef05fff,0xff000000-0xffffffff irq 22 on ocpbus0
cfi0: <AMD/Fujitsu - 8MB> iomem 0xff800000-0xffffffff on lbc0
syspld0 iomem 0xff000000-0xff00ffff on lbc0
tsec0: <eTSEC ethernet controller> iomem 0xfef24000-0xfef24fff irq 45,46,50 on ocpbus0
tsec0: hardware MAC address b0:c6:9a:63:72:7f
miibus0: <MII bus> on tsec0
e1000phy0: <Marvell 88E1112 Gigabit PHY> on miibus0
e1000phy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseTX-FDX, auto
pcib0: <Freescale MPC8544 PCI host controller> iomem 0xfef08000-0xfef08fff,0xf0000000-0xf3ffffff on ocpbus0
pci0: <PCI bus> on pcib0
pci0: <serial bus, USB> at device 18.0 (no driver attached)
ehci0: <Philips ISP156x USB 2.0 controller> mem 0xf0001000-0xf00010ff irq 22 at device 18.2 on pci0
usb0: EHCI version 1.0
usb0: <Philips ISP156x USB 2.0 controller> on ehci0
usb0: USB revision 2.0
uhub0: Philips EHCI root hub, class 9/0, rev 2.00/1.00, addr 1
uhub0: 2 ports with 2 removable, self powered
umass0: STMicroelectronics ST72682 High Speed Mode, rev 2.00/2.10, addr 2
pcib1: <Freescale MPC8544 PCI Express host controller> iomem 0xfef0a000-0xfef0afff,0xe0000000-0xe3ffffff,0xec000000-0xec0fffff irq 42 on ocpbus0
pci1: <PCI bus> on pcib1
pcib2: <PCI-PCI bridge> at device 0.0 on pci1
pci2: <PCI bus> on pcib2
mpfe0: <Juniper EX-series Packet Forwarding Engine> mem 0xa4000000-0xa40fffff,0xa0000000-0xa3ffffff irq 19 at device 0.0 on pci2
pcib3: <Freescale MPC8544 PCI Express host controller> iomem 0xfef0b000-0xfef0bfff,0xe8000000-0xebffffff,0xec200000-0xec2fffff irq 43 on ocpbus0
pci3: <PCI bus> on pcib3
pcib4: <PCI-PCI bridge> at device 0.0 on pci3
pci4: <PCI bus> on pcib4
mpfe1: <Juniper EX-series Packet Forwarding Engine> mem 0xb4000000-0xb40fffff,0xb0000000-0xb3ffffff irq 18 at device 0.0 on pci4
i2c0: <MPC85XX OnChip i2c controller> iomem 0xfef03000-0xfef03014 irq 59 on ocpbus0
i2c1: <MPC85XX OnChip i2c controller> iomem 0xfef03100-0xfef03114 irq 59 on ocpbus0
idma0: <mp85xxx DMA Controller> iomem 0xfef21000-0xfef21300 irq 36 on ocpbus0
Initializing product: 41 ..
bme0:Virtual BME driver initializing
Timecounters tick every 1.000 msec
Loading the NETPFE picpeer module
IPsec: Initialized Security Association Processing.
da0 at umass-sim0 bus 0 target 0 lun 0
da0: <ST ST72682 2.10> Removable Direct Access SCSI-2 device
da0: 40.000MB/s transfers
da0: 1000MB (2048000 512 byte sectors: 64H 32S/T 1000C)
if_pfe_open: listener socket opened, listening on ...
Trying to mount root from ufs:/dev/da0s1a
Attaching /packages/jbase via /dev/mdctl...
Mounted jbase package on /dev/md0...
Verified manifest signed by PackageProduction_10_0_0
Verified jboot signed by PackageProduction_10_0_0
Verified jbase-10.0S10.1 signed by PackageProduction_10_0_0
/packages/jcrypto-ex-10.0S10.1 not present.
/packages/jdocs-ex-10.0S10.1 not present.
Mounted jkernel-ex package on /dev/md1...
Verified jkernel-ex-10.0S10.1 signed by PackageProduction_10_0_0
/packages/jpfe-ex42x-10.0S10.1 not present.
Mounted jroute-ex package on /dev/md2...
Verified jroute-ex-10.0S10.1 signed by PackageProduction_10_0_0
/packages/jswitch-ex-10.0S10.1 not present.
Mounted jweb-ex package on /dev/md3...
Verified jweb-ex-10.0S10.1 signed by PackageProduction_10_0_0
Executing /packages/mnt/jweb-ex-10.0S10.1/mount.post..
Automatic reboot in progress...
FILE SYSTEM CLEAN; SKIPPING CHECKS
clean, 51449 free (33 frags, 6427 blocks, 0.0% fragmentation)
clean, 28282 free (50 frags, 3529 blocks, 0.2% fragmentation)
clean, 61059 free (219 frags, 7605 blocks, 0.3% fragmentation)
clean, 160780 free (20 frags, 20095 blocks, 0.0% fragmentation)
Creating initial configuration...mgd: error: Couldn't open lib "/usr/lib/dd//libjcrypto-dd.so": Cannot open "/usr/lib/dd//libjcrypto-dd.so"
mgd: error: Couldn't open lib "/usr/lib/dd//libjcrypto_junos-dd.so": Cannot open "/usr/lib/dd//libjcrypto_junos-dd.so"
mgd: error: Couldn't open lib "/usr/lib/dd//libjdocs-dd.so": Cannot open "/usr/lib/dd//libjdocs-dd.so"
mgd: error: Couldn't open lib "/opt/lib/dd/libjswitch-dd.so": Cannot open "/opt/lib/dd/libjswitch-dd.so"
mgd: error: Couldn't open lib "/opt/lib/dd/libautod-dd.so": Cannot open "/opt/lib/dd/libautod-dd.so"
mgd: commit complete
Setting initial options: debugger_on_panic=NO debugger_on_break=NO.
Starting optional daemons: .
Doing initial network setup:
Initial interface configuration:
additional daemons:.
Additional routing options:kern.module_path: /boot//kernel;/bootLoading the NETPFE ethernet module
/modules -> /booLoading the EX-series platform NETPFE module
t//kernel;/boot/modules;/modules
grat_arp_on_ifup=YES: net.link.ether.inet.grat_arp_on_ifup: 1 -> 1
grat_arp_delay=${grat_arp_delay}: net.link.ether.inet.grat_arp_delay: 0 -> 0
kld netpfe drv: ifpfed_ethkld platform: ex_ifpfe if_vcpkern.module_path: /boot//kernel;/boot/modules;/modules -> /boot//kernel;/boot/modules;/modules;/modules/peertype
kld peertype: peertype_hcm peertype_pfem peertype_sfi peertype_slavere.
Doing additional network setup:.
Starting final network daemons:.
setting ldconfig path: /usr/lib /opt/lib
starting standard daemons: cron.
Local package initialization:.
kern.securelevel: -1 -> 1
starting local daemons:.
Sat Apr 16 16:10:35 UTC 2011
Amnesiac (ttyu0)
В итоге, часть CLI недоступна (по сравнению с EX4200-24F), на LCD дисплее пишет: Loading junos (хотя в консоль пускает), на кнопки не реагирует.
Что это может быть?
Что это может быть?
сделайте реинсталл 11.4R10 (или 12.3R5, если очень хочется) с форматом.
10.0S10 :D вам такой анахронизм не нужен в любом случае, а апгрейдить его "мягко" устанеш. Edited by pfexec
Что это может быть?
Коллега, а как нам быть в случае того, что поддержка на девайсы не куплена, где брать софт?
идите на support.juniper.net и регайтесь.
после этого сможете спокойно скачать junos желанной версии. :)
Edited by pfexec
После входа в систему вот что имеем:
--- JUNOS 10.0S10.1 built 2010-11-08 21:23:50 UTC
root@:LC:0% cli
rend_dlinit: not a proper library: /usr/lib/render//libkmd-render.so: Cannot open "/usr/lib/render//libkmd-render.so"
rend_dlinit: not a proper library: /usr/lib/render//liblldpd-render.so: Cannot open "/usr/lib/render//liblldpd-render.so"
rend_dlinit: not a proper library: /usr/lib/render//libeswd-render.so: Cannot open "/usr/lib/render//libeswd-render.so"
rend_dlinit: not a proper library: /usr/lib/render//libdot1xd-render.so: Cannot open "/usr/lib/render//libdot1xd-render.so"
rend_dlinit: not a proper library: /usr/lib/render//libautod-render.so: Cannot open "/usr/lib/render//libautod-render.so"
rend_dlinit: not a proper library: /usr/lib/render//libsflowd-render.so: Cannot open "/usr/lib/render//libsflowd-render.so"
rend_dlinit: not a proper library: /usr/lib/render//libvccpd-render.so: Cannot open "/usr/lib/render//libvccpd-render.so"
{linecard:0}
root> show version
{linecard:0}
root> show version detail
{linecard:0}
root> configure
Entering configuration mode
{linecard:0}[edit]
root# set ?
Possible completions:
> access Network access configuration
> access-profile Access profile for this instance
> accounting-options Accounting data configuration
+ apply-groups Groups from which to inherit configuration data
> chassis Chassis configuration
> class-of-service Class-of-service configuration
> diameter Diameter protocol layer
> event-options Event processing configuration
> firewall Define a firewall configuration
> forwarding-options Configure options to control packet forwarding
> groups Configuration groups
> interfaces Interface configuration
> jsrc JSRC partition configuration
> jsrc-partition JSRC partition configuration
> logical-systems Logical systems
> multicast-snooping-options Multicast snooping option configuration
> policy-options Routing policy option configuration
> protocols Routing protocol configuration
> routing-instances Routing instance configuration
> routing-options Protocol-independent routing option configuration
> security Security configuration
> services
> snmp Simple Network Management Protocol configuration
> system System parameters
{linecard:0}[edit]
root# run show configuration
## Last commit: 2011-04-16 15:43:14 UTC by root
version 10.0S10.1;
system {
root-authentication {
encrypted-password "$1$OReVqebR$65Wt8HmVbB4.e40mJwfYH1"; ## SECRET-DATA
syslog {
user * {
any emergency;
file messages {
any notice;
authorization info;
file interactive-commands {
interactive-commands any;
chassis {
container-devices {
device-count 1;
interfaces {
ge-0/0/0 {
unit 0 {
## Warning: statement ignored: unsupported platform (ex4200-24t)
family ethernet-switching;
ge-0/0/1 {
unit 0 {
ge-0/0/2 {
unit 0 {
ge-0/0/3 {
unit 0 {
ge-0/0/4 {
unit 0 {
ge-0/0/5 {
unit 0 {
ge-0/0/6 {
unit 0 {
ge-0/0/7 {
unit 0 {
ge-0/0/8 {
unit 0 {
ge-0/0/9 {
unit 0 {
ge-0/0/10 {
unit 0 {
ge-0/0/11 {
unit 0 {
ge-0/0/12 {
unit 0 {
ge-0/0/13 {
unit 0 {
ge-0/0/14 {
unit 0 {
ge-0/0/15 {
unit 0 {
ge-0/0/16 {
unit 0 {
ge-0/0/17 {
unit 0 {
ge-0/0/18 {
unit 0 {
ge-0/0/19 {
unit 0 {
ge-0/0/20 {
unit 0 {
ge-0/0/21 {
unit 0 {
ge-0/0/22 {
unit 0 {
ge-0/0/23 {
unit 0 {
ge-0/1/0 {
unit 0 {
xe-0/1/0 {
unit 0 {
ge-0/1/1 {
unit 0 {
xe-0/1/1 {
unit 0 {
ge-0/1/2 {
unit 0 {
ge-0/1/3 {
unit 0 {
protocols {
igmp-snooping {
## invalid path element 'vlans'
vlan all;
{linecard:0}[edit]
root#
Почему оно считает себя linecard а не RE ? Почему про интерфейсы так пишет и почему их больше ge-0/1/0 - ge-0/1/3 ?
Edited by mse.rus77
Почему оно считает себя linecard а не RE ? Почему про интерфейсы так пишет и почему их больше в два раза?
я думаю самое время для фразы: "позовите одмина, он вам поможет."
А как вы инициализировали кластер? загрузкой или с предустановками?
Поменяйте софт, как рекомендовал pfexec.
Я собирал на 12.3 (вроде), все работало прекрасно. По поводу невидимых интерфейсов, то просто создайте их используя аналогичные порты.
Например порт ge-0/0/1, то порты бэкапа будут ge-1/0/1 - вроде бы, могу ошибаться, собирал один раз.
Устройство не в стэке, но такое ощущение, что когда-то оно в нем было в роли бэкапа. Хотя странно, мы еще этот девайс не эксплуатировали.
