всем привет!
в linux-3.9 добавили аналог freebsd'шного ng_bpf - xt_bpf
At least, on an x86_64 that achieves 40K netperf TCP_STREAM without
any iptables rules (40 GBps),
inserting 100x this bpf rule gives 28K
./iptables -A OUTPUT -m bpf --bytecode '6,40 0 0 14, 21 0 3 2048,48 0 0 25,21 0 1 20,6 0 0 96,6 0 0 0,' -j
inserting 100x this u32 rule gives 21K
./iptables -A OUTPUT -m u32 --u32 '6&0xFF=0x20' -j DROP
компилятор байткода:
http://patchwork.ozlabs.org/patch/221140/
модуль для iptables:
http://patchwork.ozlabs.org/patch/215095/
Правда, можно обойтись без компилятора байткода и использовать для этих целей tcpdump:
modprobe ipip
tcpdump -i tunl0 -ddd 'udp' > udp.bpf
tcpdump -i tunl0 -ddd 'icmp' > icmp.bpf
iptables -A INPUT -m bpf --bytecode-file udp.bpf  -j LOG --log-prefix "udp: "
iptables -A INPUT -m bpf --bytecode-file icmp.bpf  -j LOG --log-prefix "icmp: "
в итоге:
[17450.201379] udp: IN=dsw0 OUT= MAC= SRC=192.168.99.1 DST=192.168.99.255 LEN=225 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=631 DPT=631 LEN=205
[17450.201430] udp: IN=eth0 OUT= MAC= SRC=192.168.100.2 DST=192.168.100.255 LEN=226 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=631 DPT=631 LEN=206
[17450.201477] udp: IN=virbr0 OUT= MAC= SRC=192.168.122.1 DST=192.168.122.255 LEN=226 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=UDP SPT=631 DPT=631 LEN=206
[17451.241597] udp: IN=eth0 OUT= MAC=00:15:17:14:c8:c3:00:30:4f:64:71:92:08:00 SRC=10.250.0.3 DST=192.168.100.2 LEN=507 TOS=0x00 PREC=0x00 TTL=60 ID=44930 PROTO=UDP SPT=5060 DPT=5060 LEN=487
[17453.963938] udp: IN=eth0 OUT= MAC=00:15:17:14:c8:c3:00:30:4f:64:71:92:08:00 SRC=192.168.100.1 DST=192.168.100.2 LEN=237 TOS=0x00 PREC=0x00 TTL=64 ID=63634 PROTO=UDP SPT=53 DPT=8516 LEN=217
[17460.203403] icmp: IN=eth0 OUT= MAC=00:15:17:14:c8:c3:00:30:4f:64:71:92:08:00 SRC=192.168.100.1 DST=192.168.100.2 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=ICMP TYPE=8 CODE=0 ID=18090 SEQ=1
[17461.204093] icmp: IN=eth0 OUT= MAC=00:15:17:14:c8:c3:00:30:4f:64:71:92:08:00 SRC=192.168.100.1 DST=192.168.100.2 LEN=84 TOS=0x00 PREC=0x00 TTL=64 ID=0 DF PROTO=ICMP TYPE=8 CODE=0 ID=18090 SEQ=2
Ооо, ну это вообще круто. Надо будет защупать...
Спасибо за информацию.
как я понимаю, на некоторых платформах оно ещё делает jit в нативный код, если сказать sysctl -w net.core.bpf_jit_enable=1
