bondarchuk Posted February 3, 2013 Posted February 3, 2013 есть рабочий сервер с такими дисками: fdisk -l Disk /dev/sda: 250.0 GB, 250059350016 bytes 255 heads, 63 sectors/track, 30401 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x000b3ad5 Device Boot Start End Blocks Id System /dev/sda1 1 365 2931831 82 Linux swap / Solaris /dev/sda2 366 30401 241264170 fd Linux raid autodetect Disk /dev/sdb: 250.0 GB, 250059350016 bytes 255 heads, 63 sectors/track, 30401 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x000cc8ed Device Boot Start End Blocks Id System /dev/sdb1 1 365 2931831 82 Linux swap / Solaris /dev/sdb2 366 30401 241264170 fd Linux raid autodetect Disk /dev/sdc: 250.0 GB, 250059350016 bytes 255 heads, 63 sectors/track, 30401 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x000dc313 Device Boot Start End Blocks Id System /dev/sdc1 1 365 2931831 82 Linux swap / Solaris /dev/sdc2 366 30401 241264170 fd Linux raid autodetect Disk /dev/sdd: 250.0 GB, 250059350016 bytes 255 heads, 63 sectors/track, 30401 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk identifier: 0x000f223b Device Boot Start End Blocks Id System /dev/sdd1 1 365 2931831 82 Linux swap / Solaris /dev/sdd2 366 30401 241264170 fd Linux raid autodetect Disk /dev/md0: 247.0 GB, 247054401536 bytes 2 heads, 4 sectors/track, 60316016 cylinders Units = cylinders of 8 * 512 = 4096 bytes Disk identifier: 0x00000000 Disk /dev/md0 doesn't contain a valid partition table но mdadm выдает такое: mdadm -D /dev/md0 /dev/md0: Version : 0.90 Creation Time : Sun Dec 19 18:32:25 2010 Raid Level : raid1 Array Size : 241264064 (230.09 GiB 247.05 GB) Used Dev Size : 241264064 (230.09 GiB 247.05 GB) Raid Devices : 2 Total Devices : 1 Preferred Minor : 0 Persistence : Superblock is persistent Update Time : Sun Feb 3 15:39:16 2013 State : clean, degraded Active Devices : 1 Working Devices : 1 Failed Devices : 0 Spare Devices : 0 UUID : 5ecd5946:1bd74e72:e1cbcd4c:602336b4 Events : 0.20826386 Number Major Minor RaidDevice State 0 8 2 0 active sync /dev/sda2 1 0 0 1 removed cat /proc/mdstat Personalities : [raid1] md0 : active raid1 sda2[0] 241264064 blocks [2/1] [u_] unused devices: <none> Помогите разобраться, что к чему? Вставить ник Quote
roma33rus Posted February 3, 2013 Posted February 3, 2013 Number Major Minor RaidDevice State 0 8 2 0 active sync /dev/sda2 1 0 0 1 removed Во второй строчке и кроется ответ. Нету диска Вставить ник Quote
replicant Posted February 3, 2013 Posted February 3, 2013 (edited) Personalities : [raid1] md0 : active raid1 sda2[0] 241264064 blocks [2/1] [u_] Помогите разобраться, что к чему? 2/1 U_ - это пропажа второго диска массива. Работающий на всех дисках массив выглядит так md0 : active raid6 sdc1[0] sdf1[3] sde1[4] sdd1[1] 292784128 blocks super 1.2 level 6, 512k chunk, algorithm 2 [4/4] [uUUU] Т.е. все UUUU на месте 4/4. Вопрос "Почему нет второго диска в raid1?" или "Что случилось с диском и как его туда вернуть?". На вопросы "Что с диском и почему нет" ответить сложно. Тут желательно иметь диск в руках и сервер в доступе. Судя по всему у вас система стоит на этом зеркале, а второе зеркало является зеркалом первого, если судить по наличию одинаковых swap. В противном случае наличие swap никак объяснить нельзя. А на вопрос "Как вернуть" ответ можно найти тут http://xgu.ru/wiki/raid или в аналогичных руководствах по mdadm. Edited February 3, 2013 by replicant Вставить ник Quote
