Linux, Nagios + немного роутинга. Несколько раз в сутки в логи вываливается следующее:
hdc: status timeout: status=0xd0 { Busy }
ide: failed opcode was: unknown
hdc: no DRQ after issuing MULTWRITE_EXT
ide1: reset: success
Кто расшифрует? Это начало конца или винт просто не вывозит кол-во обращений (из-за нагиоса например)?
smartctl -H  /dev/hdc
smartctl version 5.38 [i686-redhat-linux-gnu] Copyright (C) 2002-8 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
smartctl -A  /dev/hdc
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
 1 Raw_Read_Error_Rate     0x000f   075   063   044    Pre-fail  Always       -       155568880
 3 Spin_Up_Time            0x0003   099   099   000    Pre-fail  Always       -       0
 4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       24
 5 Reallocated_Sector_Ct   0x0033   100   100   036    Pre-fail  Always       -       0
 7 Seek_Error_Rate         0x000f   082   060   030    Pre-fail  Always       -       198862163
 9 Power_On_Hours          0x0032   076   076   000    Old_age   Always       -       21818
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   037   020    Old_age   Always       -       24
184 Unknown_Attribute       0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Unknown_Attribute       0x0032   100   056   000    Old_age   Always       -       4295035960
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   073   064   045    Old_age   Always       -       27 (Lifetime Min/Max 10/36)
194 Temperature_Celsius     0x0022   027   040   000    Old_age   Always       -       27 (0 10 0 0)
195 Hardware_ECC_Recovered  0x001a   039   031   000    Old_age   Always       -       155568880
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
Полный вывод:
smartctl -a /dev/hdc
smartctl version 5.38 [i686-redhat-linux-gnu] Copyright © 2002-8 Bruce Allen
=== START OF INFORMATION SECTION ===
Device Model: ST3250310NS
Serial Number: 9SF0Q7LK
Firmware Version: SN06
User Capacity: 250,059,350,016 bytes
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Mon Apr 23 13:14:44 2012 NOVT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 634) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 60) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x103d) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
7 Seek_Error_Rate 0x000f 082 060 030 Pre-fail Always - 198863060
190 Airflow_Temperature_Cel 0x0022 074 064 045 Old_age Always - 26 (Lifetime Min/Max 10/36)
194 Temperature_Celsius 0x0022 026 040 000 Old_age Always - 26 (0 10 0 0)
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 18112 -
# 2 Short offline Completed without error 00% 18088 -
# 3 Short offline Completed without error 00% 18064 -
# 4 Short offline Completed without error 00% 18040 -
# 5 Short offline Completed without error 00% 18016 -
# 6 Extended offline Interrupted (host reset) 20% 17993 -
# 7 Short offline Completed without error 00% 17992 -
# 8 Short offline Completed without error 00% 17968 -
# 9 Short offline Completed without error 00% 17944 -
#10 Short offline Completed without error 00% 17920 -
#11 Short offline Completed without error 00% 17896 -
#12 Short offline Completed without error 00% 17872 -
#13 Short offline Completed without error 00% 17848 -
#14 Extended offline Completed without error 00% 17826 -
#15 Short offline Completed without error 00% 17824 -
#16 Short offline Completed without error 00% 17800 -
#17 Short offline Completed without error 00% 17776 -
#18 Short offline Completed without error 00% 17752 -
#19 Short offline Completed without error 00% 17728 -
#20 Short offline Completed without error 00% 17704 -
#21 Short offline Completed without error 00% 17680 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Edited by kaktak
  • 2 weeks later...
ЗачОтное корыто.
Если винт марки seagate, то большие значения первых двух параметров обычное явление.
угу, есть такое наблюдение. а что скажите насчет остального?
По Hardware_ECC_Recovered: возможно sata кабель скручен в пружинку каким-нибудь умником.
PS
В вашем случае я бы поменял и винт и sata кабель и возможно переходник питания (если таковые имеются и винт не в корзине, хотя корзина тоже не безгрешна), т.к. высок риск потерять данные, пока будете возиться с поиском причины, которую придётся исправлять тем-же способом.
