Собственно, впрервые настраиваю, может кто сталкивался
DES-3028 настроен с вкл. option 82 и вроде даже вставляет ее в dhcp запрос, что видно по логу wireshark:
91	44.406940	10.0.0.100	10.0.0.1	DHCP	DHCP Request  - Transaction ID 0x3b866793
Option: (t=82,l=18) Agent Information Option
Option: (82) Agent Information Option
Length: 18
Value: 010600040001000202080006001e58aab3ad
Agent Circuit ID: 000400010002
Agent Remote ID: 0006001e58aab3ad
End Option
При этом, что происходит в Dnsmasq:
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 available DHCP range: 10.0.0.2 -- 10.0.0.150
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 client provides name: artyom
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 vendor class: MSFT 5.0
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 DHCPREQUEST(eth1) 10.0.0.133 00:0a:e4:33:3c:97
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 DHCPACK(eth1) 10.0.0.133 00:0a:e4:33:3c:97 artyom
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 requested options: 1:netmask, 15:domain-name, 3:router, 6:dns-server,
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 requested options: 44:netbios-ns, 46:netbios-nodetype, 47:netbios-scope,
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 requested options: 31:router-discovery, 33:static-route, 249,
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 requested options: 43:vendor-encap
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 tags: eth1
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 next server: 10.0.0.1
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  1 option: 53:message-type  05
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  4 option: 54:server-identifier  10.0.0.1
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  4 option: 51:lease-time  00:00:a8:c0
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  4 option: 58:T1  00:00:4b:05
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  4 option: 59:T2  00:00:8a:4d
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  4 option:  1:netmask  255.255.255.0
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  4 option: 28:broadcast  10.0.0.255
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  4 option:  3:router  10.0.0.100
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  9 option: 81:FQDN  03:ff:ff:61:72:74:79:6f:6d
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  8 option:  6:dns-server  10.0.0.1, 8.8.8.8
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  7 option: 43:vendor-encap  06:04:01:01:01:01:ff
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size:  8 option: 60:vendor-class  4d:53:46:54:20:35:2e:30
Apr 25 11:29:36 Server dnsmasq-dhcp[25986]: 1391247347 sent size: 18 option: 82:agent-id  01:06:00:04:00:01:00:02:02:08:00:06:00...
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 available DHCP range: 10.0.0.2 -- 10.0.0.150
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 client provides name: artyom
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 vendor class: MSFT 5.0
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 DHCPREQUEST(eth1) 10.0.0.133 00:0a:e4:33:3c:97
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 DHCPACK(eth1) 10.0.0.133 00:0a:e4:33:3c:97 artyom
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 requested options: 1:netmask, 15:domain-name, 3:router, 6:dns-server,
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 requested options: 44:netbios-ns, 46:netbios-nodetype, 47:netbios-scope,
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 requested options: 31:router-discovery, 33:static-route, 249,
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 requested options: 43:vendor-encap
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 tags: eth1
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 next server: 10.0.0.1
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  1 option: 53:message-type  05
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  4 option: 54:server-identifier  10.0.0.1
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  4 option: 51:lease-time  00:00:a8:c0
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  4 option: 58:T1  00:00:4c:8d
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  4 option: 59:T2  00:00:8b:d5
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  4 option:  1:netmask  255.255.255.0
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  4 option: 28:broadcast  10.0.0.255
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  4 option:  3:router  10.0.0.1
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  9 option: 81:FQDN  03:ff:ff:61:72:74:79:6f:6d
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  8 option:  6:dns-server  10.0.0.1, 8.8.8.8
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  7 option: 43:vendor-encap  06:04:01:01:01:01:ff
Apr 25 11:29:38 Server dnsmasq-dhcp[25986]: 54831025 sent size:  8 option: 60:vendor-class  4d:53:46:54:20:35:2e:30
Как понимать эту строчку?
В конфиге dnsmasq по поводу настройки option 82 следующее:
dhcp-remoteid=set:switch1,00:1E:58:AA:B3:AD
dhcp-circuitid=set:port-3,3
dhcp-range=net:switch1,net:port-3,10.10.35.2,10.10.35.5,255.255.255.0
В общем непонятки по поводу dhcp-circuitid, как она должна выглядеть в конфиге?
dnsmasq писан чтобы статикой со своего конфига всё брать, это не всегда оптимально при работе с опцией 82.
В данном примере в начале вы определяете свич по его идентификатору (мак из опции 82), потом порт.
В последней строчке на основании мака свича и номера порта выдаются настройки.
Почитайте про логику работы dnsmasq: он в начале на основе некоторых параеметров из запроса определяет группу, а потом выдаёт настройки для этой группы.
Ок, давайте сделаем группу fixedport.
Например:
tag-if=set:fixedport,tag:switch1,tag:port2
dhcp-range=net:#fixedport,10.10.40.50,10.10.40.60,255.255.255.0
dhcp-option=net:#fixedport,option:router,10.0.0.100
dhcp-option=net:#fixedport,option:dns-server,8.8.8.8
dhcp-remoteid=set:switch1,00:1e:58:aa:b3:ad
dhcp-circuitid=set:port2,01:06:00:04:00:01:00:02
В этом случае шлюз и dns-ы отдает клиенту, одако ip-шник выдает из дефолтного 10.0.0.0/24. И как я и писал, подозрение на строку описания порта, в данном случае #2. Мутатор отдает
Я пробовал и так:
и так:
dhcp-circuitid=set:port2,0106000400010002
и так:
dhcp-circuitid=set:port2,000400010002
и так:
dhcp-circuitid=set:port2,00:04:00:01:00:02
и я уже хз че ему надо
В мане буквально следующее:
--dhcp-circuitid=set:<tag>,<circuit-id>, --dhcp-remoteid=set:<tag>,<remote-id>
Map from RFC3046 relay agent options to tags. This data may be provided by DHCP relay agents. The circuit-id or remote-id is normally given as colon-separated hex, but is also allowed to be a simple string. If an exact match is achieved between the circuit or agent ID and one provided by a relay agent, the tag is set.
Лог самого dnsmasq:
Apr 26 10:19:46 Server dnsmasq-dhcp[14838]: 2733913276 sent size: 18 option: 82:agent-id 01:06:00:04:00:01:00:02:02:08:00:06:00...
Где грабли?
Edited by ga6iem
