RG-45 Posted November 19, 2010 Posted November 19, 2010 (edited) при установке verlihub ось centos вылетает ошибка при команде ./configure : hecking for pgf90... no checking for pghpf... no checking for epcf90... no checking for gfortran... no checking for g95... no checking for xlf95... no checking for f95... no checking for fort... no checking for ifort... no checking for ifc... no checking for efc... no checking for pgf95... no checking for lf95... no checking for ftn... no checking whether we are using the GNU Fortran 77 compiler... no checking whether accepts -g... no checking the maximum length of command line arguments... 98304 checking command to parse /usr/bin/nm -B output from gcc object... ok checking for objdir... .libs checking for ar... ar checking for ranlib... ranlib checking for strip... strip checking for correct ltmain.sh version... yes checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by g++... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC checking if g++ PIC flag -fPIC works... yes checking if g++ static flag -static works... yes checking if g++ supports -c -o file.o... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so (cached) (cached) checking how to hardcode library paths into programs... immedi ate appending configuration tag "F77" to libtool checking host system type... (cached) i686-pc-linux-gnu Your OS is i686-pc-linux-gnu *** *** Checking 3rd party libraries (mysql, prec, geoip, zlib, etc.)... *** checking for mysql-devel... yes checking for pcre-devel... yes checking for MySQL... checking for noapos_mysql... ./noapos_mysql checking for MYSQL CFLAGS... -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURC E=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -fasynchronous -unwind-tables -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -fno-str ict-aliasing -fwrapv checking for MYSQL LIBS... -rdynamic -L/usr/lib/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib -lssl -lcrypto checking for MYSQL VERSION... 5.0.77 checking for MYSQL - any version... yes adding -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fsta ck-protector --param=ssp-buffer-size=4 -m32 -fasynchronous-unwind-tables -D_GNU_ SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -fno-strict-aliasing -fwrapv t o CXXFLAGS adding -rdynamic -L/usr/lib/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib -lssl -lcrypto to LDFLAGS checking for pcre... checking for noapos_pcre... ./noapos_pcre checking for PCRE CFLAGS... checking for PCRE LIBS... -lpcre checking for PCRE VERSION... 6.6 checking for PCRE - version >= 3.0.0... yes adding to CXXFLAGS adding -lpcre to LDFLAGS checking for GeoIP... checking for config_geoip... ./config_geoip checking for GEOIP CFLAGS... checking for GEOIP LIBS... -L/usr/lib -lGeoIP checking for GEOIP VERSION... checking for GEOIP - version >= 0.0.0... no *** The test program failed to compile or link. See the file *** config.log for the exact error that occured. This usually *** means GEOIP was not installed, was incorrectly installed *** or that you have moved GEOIP since it was installed. In *** the latter case, you may want to edit the $ac_path_lib_geoip_config *** script: $GEOIP_CONFIG Please download and install GeoIP package from: ./configure: line 21645: http://www.maxmind.com/download/geoip/api/c/: No such f ile or directory [root@HUB verlihub-0.9.8e-r2]# [root@HUB verlihub-0.9.8e-r2]# ./configure checking for a BSD-compatible install... /usr/bin/install -c checking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes *** *** Checking compiler... *** checking for g++... g++ checking for C++ compiler default output file name... a.out checking whether the C++ compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C++ compiler... yes checking whether g++ accepts -g... yes checking for style of include used by make... GNU checking dependency style of g++... gcc3 checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for gcc... gcc checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking dependency style of gcc... gcc3 checking for a sed that does not truncate output... /bin/sed checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking whether ln -s works... yes checking how to recognize dependent libraries... pass_all checking how to run the C preprocessor... gcc -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking how to run the C++ preprocessor... g++ -E checking for g77... no checking for xlf... no checking for f77... no checking for frt... no checking for pgf77... no checking for cf77... no checking for fort77... no checking for fl32... no checking for af77... no checking for xlf90... no checking for f90... no checking for pgf90... no checking for pghpf... no checking for epcf90... no checking for gfortran... no checking for g95... no checking for xlf95... no checking for f95... no checking for fort... no checking for ifort... no checking for ifc... no checking for efc... no checking for pgf95... no checking for lf95... no checking for ftn... no checking whether we are using the GNU Fortran 77 compiler... no checking whether accepts -g... no checking the maximum length of command line arguments... 98304 checking command to parse /usr/bin/nm -B output from gcc object... ok checking for objdir... .libs checking for ar... ar checking for ranlib... ranlib checking for strip... strip checking for correct ltmain.sh version... yes checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool checking for ld used by g++... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking for g++ option to produce PIC... -fPIC checking if g++ PIC flag -fPIC works... yes checking if g++ static flag -static works... yes checking if g++ supports -c -o file.o... yes checking whether the g++ linker (/usr/bin/ld) supports shared libraries... yes checking dynamic linker characteristics... GNU/Linux ld.so (cached) (cached) checking how to hardcode library paths into programs... immediate appending configuration tag "F77" to libtool checking host system type... (cached) i686-pc-linux-gnu Your OS is i686-pc-linux-gnu *** *** Checking 3rd party libraries (mysql, prec, geoip, zlib, etc.)... *** checking for mysql-devel... yes checking for pcre-devel... yes checking for MySQL... checking for noapos_mysql... ./noapos_mysql checking for MYSQL CFLAGS... -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -fasynchronous-unwind-tables -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -fno-strict-aliasing -fwrapv checking for MYSQL LIBS... -rdynamic -L/usr/lib/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib -lssl -lcrypto checking for MYSQL VERSION... 5.0.77 checking for MYSQL - any version... yes adding -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m32 -fasynchronous-unwind-tables -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -fno-strict-aliasing -fwrapv to CXXFLAGS adding -rdynamic -L/usr/lib/mysql -lmysqlclient -lz -lcrypt -lnsl -lm -L/usr/lib -lssl -lcrypto to LDFLAGS checking for pcre... checking for noapos_pcre... ./noapos_pcre checking for PCRE CFLAGS... checking for PCRE LIBS... -lpcre checking for PCRE VERSION... 6.6 checking for PCRE - version >= 3.0.0... yes adding to CXXFLAGS adding -lpcre to LDFLAGS checking for GeoIP... checking for config_geoip... ./config_geoip checking for GEOIP CFLAGS... checking for GEOIP LIBS... -L/usr/lib -lGeoIP checking for GEOIP VERSION... checking for GEOIP - version >= 0.0.0... no *** The test program failed to compile or link. See the file *** config.log for the exact error that occured. This usually *** means GEOIP was not installed, was incorrectly installed *** or that you have moved GEOIP since it was installed. In *** the latter case, you may want to edit the $ac_path_lib_geoip_config *** script: $GEOIP_CONFIG Please download and install GeoIP package from: ./configure: line 21645: http://www.maxmind.com/download/geoip/api/c/: No such file or directory [root@HUB verlihub-0.9.8e-r2]# а при make :[root@HUB verlihub-0.9.8e-r2]# make /bin/sh ./config.status --recheck /bin/sh: ./config.status: No such file or directory make: *** [config.status] Error 127 [root@HUB verlihub-0.9.8e-r2]# при make install : [root@HUB verlihub-0.9.8e-r2]# make install make install-recursive make[1]: Entering directory `/root/verlihub-0.9.8e-r2' Making install in src make[2]: Entering directory `/root/verlihub-0.9.8e-r2/src' Makefile:592: .deps/cantiflood.Plo: No such file or directory Makefile:593: .deps/casyncconn.Plo: No such file or directory Makefile:594: .deps/casyncsocketserver.Plo: No such file or directory Makefile:595: .deps/cban.Plo: No such file or directory Makefile:596: .deps/cbanlist.Plo: No such file or directory Makefile:597: .deps/ccallbacklist.Plo: No such file or directory Makefile:598: .deps/cchatconsole.Plo: No such file or directory Makefile:599: .deps/ccmdr.Plo: No such file or directory Makefile:600: .deps/ccommand.Plo: No such file or directory Makefile:601: .deps/cconfigbase.Plo: No such file or directory Makefile:602: .deps/cconfigfile.Plo: No such file or directory Makefile:603: .deps/cconfigitembase.Plo: No such file or directory Makefile:604: .deps/cconfmysql.Plo: No such file or directory Makefile:605: .deps/cconnchoose.Plo: No such file or directory Makefile:606: .deps/cconndc.Plo: No such file or directory Makefile:607: .deps/cconnpoll.Plo: No such file or directory Makefile:608: .deps/cconnselect.Plo: No such file or directory Makefile:609: .deps/cconntypes.Plo: No such file or directory Makefile:610: .deps/ccustomredirect.Plo: No such file or directory Makefile:611: .deps/ccustomredirects.Plo: No such file or directory Makefile:612: .deps/cdbconf.Plo: No such file or directory Makefile:613: .deps/cdcclients.Plo: No such file or directory Makefile:614: .deps/cdccommand.Plo: No such file or directory Makefile:615: .deps/cdcconf.Plo: No such file or directory Makefile:616: .deps/cdcconsole.Plo: No such file or directory Makefile:617: .deps/cdcproto.Plo: No such file or directory Makefile:618: .deps/cdctag.Plo: No such file or directory Makefile:619: .deps/cfreqlimiter.Plo: No such file or directory Makefile:620: .deps/cgeoip.Plo: No such file or directory Makefile:621: .deps/cinfoserver.Plo: No such file or directory Makefile:622: .deps/cinterpolexp.Plo: No such file or directory Makefile:623: .deps/ckick.Plo: No such file or directory Makefile:624: .deps/ckicklist.Plo: No such file or directory Makefile:625: .deps/cmeanfrequency.Plo: No such file or directory Makefile:626: .deps/cmessagedc.Plo: No such file or directory Makefile:627: .deps/cmutex.Plo: No such file or directory Makefile:628: .deps/cmysql.Plo: No such file or directory Makefile:629: .deps/cobj.Plo: No such file or directory Makefile:630: .deps/coperator.Plo: No such file or directory Makefile:631: .deps/cpcre.Plo: No such file or directory Makefile:632: .deps/cpenaltylist.Plo: No such file or directory Makefile:633: .deps/cpluginbase.Plo: No such file or directory Makefile:634: .deps/cpluginloader.Plo: No such file or directory Makefile:635: .deps/cpluginmanager.Plo: No such file or directory Makefile:636: .deps/cprotocol.Plo: No such file or directory Makefile:637: .deps/cprotocommand.Plo: No such file or directory Makefile:638: .deps/cquery.Plo: No such file or directory Makefile:639: .deps/creglist.Plo: No such file or directory Makefile:640: .deps/creguserinfo.Plo: No such file or directory Makefile:641: .deps/cserverdc.Plo: No such file or directory Makefile:642: .deps/csetuplist.Plo: No such file or directory Makefile:643: .deps/ctempfunctionbase.Plo: No such file or directory Makefile:644: .deps/cthread.Plo: No such file or directory Makefile:645: .deps/cthreadwork.Plo: No such file or directory Makefile:646: .deps/ctime.Plo: No such file or directory Makefile:647: .deps/ctimeout.Plo: No such file or directory Makefile:648: .deps/ctrigger.Plo: No such file or directory Makefile:649: .deps/ctriggers.Plo: No such file or directory Makefile:650: .deps/cuser.Plo: No such file or directory Makefile:651: .deps/cusercollection.Plo: No such file or directory Makefile:652: .deps/cvhplugin.Plo: No such file or directory Makefile:653: .deps/cvhpluginmgr.Plo: No such file or directory Makefile:654: .deps/cworkerthread.Plo: No such file or directory Makefile:655: .deps/libverlihub_a-cantiflood.Po: No such file or directory Makefile:656: .deps/libverlihub_a-casyncconn.Po: No such file or directory Makefile:657: .deps/libverlihub_a-casyncsocketserver.Po: No such file or directory Makefile:658: .deps/libverlihub_a-cban.Po: No such file or directory Makefile:659: .deps/libverlihub_a-cbanlist.Po: No such file or directory Makefile:660: .deps/libverlihub_a-ccallbacklist.Po: No such file or directory Makefile:661: .deps/libverlihub_a-cchatconsole.Po: No such file or directory Makefile:662: .deps/libverlihub_a-ccmdr.Po: No such file or directory Makefile:663: .deps/libverlihub_a-ccommand.Po: No such file or directory Makefile:664: .deps/libverlihub_a-cconfigbase.Po: No such file or directory Makefile:665: .deps/libverlihub_a-cconfigfile.Po: No such file or directory Makefile:666: .deps/libverlihub_a-cconfigitembase.Po: No such file or directory Makefile:667: .deps/libverlihub_a-cconfmysql.Po: No such file or directory Makefile:668: .deps/libverlihub_a-cconnchoose.Po: No such file or directory Makefile:669: .deps/libverlihub_a-cconndc.Po: No such file or directory Makefile:670: .deps/libverlihub_a-cconnpoll.Po: No such file or directory Makefile:671: .deps/libverlihub_a-cconnselect.Po: No such file or directory Makefile:672: .deps/libverlihub_a-cconntypes.Po: No such file or directory Makefile:673: .deps/libverlihub_a-ccustomredirect.Po: No such file or directory Makefile:674: .deps/libverlihub_a-ccustomredirects.Po: No such file or directory Makefile:675: .deps/libverlihub_a-cdbconf.Po: No such file or directory Makefile:676: .deps/libverlihub_a-cdcclients.Po: No such file or directory Makefile:677: .deps/libverlihub_a-cdccommand.Po: No such file or directory Makefile:678: .deps/libverlihub_a-cdcconf.Po: No such file or directory Makefile:679: .deps/libverlihub_a-cdcconsole.Po: No such file or directory Makefile:680: .deps/libverlihub_a-cdcproto.Po: No such file or directory Makefile:681: .deps/libverlihub_a-cdctag.Po: No such file or directory Makefile:682: .deps/libverlihub_a-cfreqlimiter.Po: No such file or directory Makefile:683: .deps/libverlihub_a-cgeoip.Po: No such file or directory Makefile:684: .deps/libverlihub_a-cinfoserver.Po: No such file or directory Makefile:685: .deps/libverlihub_a-cinterpolexp.Po: No such file or directory Makefile:686: .deps/libverlihub_a-ckick.Po: No such file or directory Makefile:687: .deps/libverlihub_a-ckicklist.Po: No such file or directory Makefile:688: .deps/libverlihub_a-cmeanfrequency.Po: No such file or directory Makefile:689: .deps/libverlihub_a-cmessagedc.Po: No such file or directory Makefile:690: .deps/libverlihub_a-cmutex.Po: No such file or directory Makefile:691: .deps/libverlihub_a-cmysql.Po: No such file or directory Makefile:692: .deps/libverlihub_a-cobj.Po: No such file or directory Makefile:693: .deps/libverlihub_a-coperator.Po: No such file or directory Makefile:694: .deps/libverlihub_a-cpcre.Po: No such file or directory Makefile:695: .deps/libverlihub_a-cpenaltylist.Po: No such file or directory Makefile:696: .deps/libverlihub_a-cpluginbase.Po: No such file or directory Makefile:697: .deps/libverlihub_a-cpluginloader.Po: No such file or directory Makefile:698: .deps/libverlihub_a-cpluginmanager.Po: No such file or directory Makefile:699: .deps/libverlihub_a-cprotocol.Po: No such file or directory Makefile:700: .deps/libverlihub_a-cprotocommand.Po: No such file or directory Makefile:701: .deps/libverlihub_a-cquery.Po: No such file or directory Makefile:702: .deps/libverlihub_a-creglist.Po: No such file or directory Makefile:703: .deps/libverlihub_a-creguserinfo.Po: No such file or directory Makefile:704: .deps/libverlihub_a-cserverdc.Po: No such file or directory Makefile:705: .deps/libverlihub_a-csetuplist.Po: No such file or directory Makefile:706: .deps/libverlihub_a-ctempfunctionbase.Po: No such file or directory Makefile:707: .deps/libverlihub_a-cthread.Po: No such file or directory Makefile:708: .deps/libverlihub_a-cthreadwork.Po: No such file or directory Makefile:709: .deps/libverlihub_a-ctime.Po: No such file or directory Makefile:710: .deps/libverlihub_a-ctimeout.Po: No such file or directory Makefile:711: .deps/libverlihub_a-ctrigger.Po: No such file or directory Makefile:712: .deps/libverlihub_a-ctriggers.Po: No such file or directory Makefile:713: .deps/libverlihub_a-cuser.Po: No such file or directory Makefile:714: .deps/libverlihub_a-cusercollection.Po: No such file or directory Makefile:715: .deps/libverlihub_a-cvhplugin.Po: No such file or directory Makefile:716: .deps/libverlihub_a-cvhpluginmgr.Po: No such file or directory Makefile:717: .deps/libverlihub_a-cworkerthread.Po: No such file or directory Makefile:718: .deps/libverlihub_a-script_api.Po: No such file or directory Makefile:719: .deps/libverlihub_a-stringutils.Po: No such file or directory Makefile:720: .deps/libverlihub_a-thasharray.Po: No such file or directory Makefile:721: .deps/libverlihub_a-tpluginbase.Po: No such file or directory Makefile:722: .deps/script_api.Plo: No such file or directory Makefile:723: .deps/stringutils.Plo: No such file or directory Makefile:724: .deps/thasharray.Plo: No such file or directory Makefile:725: .deps/tpluginbase.Plo: No such file or directory Makefile:726: .deps/verlihub.Po: No such file or directory make[2]: *** No rule to make target `.deps/verlihub.Po'. Stop. make[2]: Leaving directory `/root/verlihub-0.9.8e-r2/src' make[1]: *** [install-recursive] Error 1 make[1]: Leaving directory `/root/verlihub-0.9.8e-r2' make: *** [install] Error 2 [root@HUB verlihub-0.9.8e-r2]# Подскажите что не так ? Edited November 19, 2010 by RG-45 Вставить ник Quote
RG-45 Posted November 19, 2010 Author Posted November 19, 2010 yum install GeoIP-devel Все решил ...... спасибо! Вставить ник Quote
RG-45 Posted November 20, 2010 Author Posted November 20, 2010 При установке Lua требует установки нескольких файлов configure: error: Please install the lua library headers (lua.h, lualib.h, lauxlib.h). Вопрос где их взять и как установить? Вставить ник Quote
s.lobanov Posted November 20, 2010 Posted November 20, 2010 В пакете lua-devel, он в экстрасах, поэтому его не видно скорее всего http://rpm.pbone.net/index.php3/stat/4/idp...b.i386.rpm.html http://rpm.pbone.net/index.php3/stat/4/idp...x86_64.rpm.html Вставить ник Quote
