vovan-pmr Posted July 29, 2010 Posted July 29, 2010 Здравствуйте! Есть проблема. Между 2-мя роутерами Cisco 7609 сделали туннель L2tpv3. Туннель поднялся, но пакеты через него не ходят. sh l2tun session all L2TP Session Information Total tunnels 1 sessions 1 Session id 7432 is up, tunnel id 3925069788 Remote session id is 5075, remote tunnel id 1343098550 Locally initiated session Unique ID is 12 Session Layer 2 circuit, type is Ethernet Vlan, name is Vlan18:18 Session vcid is 16 Circuit state is UP Local circuit state is UP Remote circuit state is UP Call serial number is 1115500011 Remote tunnel name is Router1 Internet address is x.x.x.x Local tunnel name is Router2 Internet address is x.x.x.x IP protocol 115 Session is L2TP signaled Session state is established, time since change 00:18:43 0 Packets sent, 0 received 0 Bytes sent, 0 received Last clearing of counters never Counters, ignoring last clear: 0 Packets sent, 0 received 0 Bytes sent, 0 received Receive packets dropped: out-of-order: 0 total: 0 Send packets dropped: exceeded session MTU: 0 total: 0 DF bit off, ToS reflect disabled, ToS value 0, TTL value 255 Sending UDP checksums are disabled Received UDP checksums are verified Session PMTU enabled, path MTU is not known No session cookie information available FS cached header information: encap size = 24 bytes 45000014 00000000 FF734E59 D913DBFE D913DEF7 000013D3 Sequencing is off Conditional debugging is disabled Вот конфиг одного из роутеров: l2tp-class Router2-Router1 authentication password 7 xxxxxxxxxxxxxxxxxxx retransmit initial retries 30 pseudowire-class Router2-Router1 encapsulation l2tpv3 protocol l2tpv3 Router2-Router1 ip local interface Loopback0 ip pmtu interface Loopback0 ip address x.x.x.x 255.255.255.255 interface Vlan18 no ip address xconnect y.y.y.y 18 pw-class Router2-Router1 На втором роутере аналогично. В чем проблема??? ПРобовали пинги разного размера, ничего не проходит...... Вставить ник Quote
Картуччо Posted July 30, 2010 Posted July 30, 2010 Конфиг нормальный, только я не прописывал retransmit initial retries 30 и ip pmtu работает куча таких туннелей, только строятся между сабинтерфейсами на 38хх и 72хх. Хотелось бы посмотреть на топологию с обоих сторон на уровне vlan и ip, хотя бы в общих чертах. Вставить ник Quote
vovan-pmr Posted July 30, 2010 Author Posted July 30, 2010 насколько я понял туннели l2tpv3 работать не будут. они работают только на ES+ и SIP 400 картах, к сожалению. а у нас их нету :( Вставить ник Quote
