Nurmukhamed Posted May 30, 2010 Posted May 30, 2010 (edited) Добрый день. имею следующий каталист в эксплуатации sh version Rec-1#sh version Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(52)XO, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright © 1986-2009 by Cisco Systems, Inc. Compiled Sun 17-May-09 18:51 by prod_rel_team Image text-base: 0x10000000, data-base: 0x124CA328 ROM: 12.2(44r)SG5 Darkside Revision 4, Jawa Revision 9, Tatooine Revision 140, Forerunner Revision 1.11 Rec-1 uptime is 2 weeks, 2 days, 16 hours, 15 minutes System returned to ROM by reload System image file is "bootflash:cat4500e-ipbasek9-mz.122-52.XO.bin" This product contains cryptographic features and is subject to United States and local country laws governing import, export, transfer and use. Delivery of Cisco cryptographic products does not imply third-party authority to import, export, distribute or use encryption. Importers, exporters, distributors and users are responsible for compliance with U.S. and local country laws. By using this product you agree to comply with applicable laws and regulations. If you are unable to comply with U.S. and local laws, return this product immediately. A summary of U.S. laws governing Cisco cryptographic products may be found at: http://www.cisco.com/wwl/export/crypto/tool/stqrg.html If you require further assistance please contact us by sending email to export@cisco.com. cisco WS-C4506-E (MPC8548) processor (revision 8) with 524288K bytes of memory. Processor board ID FOX1335GE86 MPC8548 CPU at 1GHz, Supervisor 6L-E Last reset from Reload 19 Virtual Ethernet interfaces 52 Gigabit Ethernet interfaces 2 Ten Gigabit Ethernet interfaces 511K bytes of non-volatile configuration memory. Configuration register is 0x2102 sh inventory Rec-1#sh inventory NAME: "Switch System", DESCR: "Cisco Systems, Inc. WS-C4506-E 6 slot switch " PID: WS-C4506-E , VID: V02 , SN: FOX1335GE86 NAME: "Linecard(slot 1)", DESCR: "Supervisor 6L-E 10GE (X2), 1000BaseX (SFP)with 2 10GE X2 ports" PID: WS-X45-SUP6L-E , VID: V01 , SN: JAE1336I6NR NAME: "Converter 1/1", DESCR: "Converter Module" PID: CVR-X2-SFP , VID: V02 , SN: FDO13300SAB NAME: "GigabitEthernet1/3", DESCR: "1000BaseSX" PID: Unspecified , VID: , SN: AGM134012Y7 NAME: "GigabitEthernet1/4", DESCR: "1000BaseLH" PID: Unspecified , VID: , SN: LP640062611746 NAME: "Converter 1/2", DESCR: "Converter Module" PID: CVR-X2-SFP , VID: V02 , SN: FDO13300JGJ NAME: "GigabitEthernet1/5", DESCR: "1000BaseSX" PID: Unspecified , VID: , SN: AGA133016EB NAME: "GigabitEthernet1/6", DESCR: "1000BaseSX" PID: Unspecified , VID: , SN: AGA133016E2 NAME: "Linecard(slot 2)", DESCR: "10/100/1000BaseT (RJ45) with 24 10/100/1000 baseT ports" PID: WS-X4424-GB-RJ45 , VID: V06 , SN: JAE1342LK0D NAME: "Linecard(slot 3)", DESCR: "10/100/1000BaseT (RJ45) with 24 10/100/1000 baseT ports" PID: WS-X4424-GB-RJ45 , VID: V06 , SN: JAE1337J53M NAME: "Fan", DESCR: "FanTray" PID: WS-X4596-E , VID: V02 , SN: FOX1335GATB NAME: "Power Supply 1", DESCR: "Power Supply ( AC 1000W )" PID: PWR-C45-1000AC , VID: V05 , SN: AZS13380FGR NAME: "Power Supply 2", DESCR: "Power Supply ( AC 1000W )" PID: PWR-C45-1000AC , VID: V05 , SN: AZS13380FH1 хочу применить следующий скрипт ip access-list extended rules4vlan143! access to univer.somewhere.kz port 80 permit tcp 10.10.10.32 0.0.0.31 host 10.7.1.43 80 ! access to univer.somewhere.kz port 8080 permit tcp 10.10.10.32 0.0.0.31 host 10.7.1.40 8080 ! access to stud.somewhere.kz port 80 permit tcp 10.10.10.32 0.0.0.31 host 10.60.0.50 80 ! access to www.somewhere.kz permit tcp 10.10.10.32 0.0.0.31 host 10.5.0.26 80 ! access to gateway ip, to ping permit icmp 10.10.10.32 0.0.0.31 host 10.10.10.33 ! access to dns server permit udp 10.10.10.32 0.0.0.31 host 10.5.0.10 53 ! access to dw.somewhere.kz port 80 permit tcp 10.10.10.32 0.0.0.31 host 10.5.0.20 80 ! access to cl.somewhere.kz port 80 permit tcp 10.10.10.32 0.0.0.31 host 10.5.0.26 80 ! access to cl.somewhere.kz port 8443 permit tcp 10.10.10.32 0.0.0.31 host 10.5.0.26 8443 ! access to cl.somewhere.kz port 443 permit tcp 10.10.10.32 0.0.0.31 host 10.5.0.26 443 ! access to cl.somewhere.kz port 389 permit tcp 10.10.10.32 0.0.0.31 host 10.5.0.26 389 route-map vlan143routemap deny 10 match ip address rules4vlan143 set ip default next-hop 212.154.154.210 int vlan 143 description no description ip address 10.10.10.33 255.255.255.224 ip policy route-map vlan143routemap но он не хочет применятся. последняя строка не срабатывает. помоги что здесь не правильно, может следует другой образ поставить? или нуно еще какой нибудь модуль воткнуть? Edited May 30, 2010 by Nurmukhamed Вставить ник Quote
Nurmukhamed Posted June 7, 2010 Author Posted June 7, 2010 Эта фича не поддерживается в IPBASE Добрый день. попробывал загрузить следующие образы cat4500e-entservicesk9-mz.122-53.SG.bin cat4500e-entservicesk9-mz.122-53.SG1.bin каталист ругается, говорит что образ не поддерживается. что делать? какой образ подойдет для етого каталиста? Вставить ник Quote
Stak Posted June 7, 2010 Posted June 7, 2010 Судя по сравнительной табличке, это сильно урезанный вариант суп6Е: http://www.cisco.com/en/US/products/hw/swi...comparison.html Смотрите через фиченавигатор, возможно на нём вообще PBR не поддерживается... Вставить ник Quote
nnm Posted June 7, 2010 Posted June 7, 2010 Cisco Catalyst 4500 Supervisor Engine 6L-E Feature Highlights Supports the following software packages, LAN Base, IP Base and Enterprise services (Eneterprise services support introduced with IOS release 12.2(53)SG2 ) Вставить ник Quote
