Controller E1 changed state to down (RAI detected)
Вот такая ошибка на интерфейсе E1 и постоянно скачет интерфейс а потом уходит в даун, что делать не знаю уже и карточку поменял.
sh controller E1 0/1/0 br
E1 0/1/0 is down.
Applique type is Channelized E1 - balanced
Receiver has remote alarm.
alarm-trigger is not set
Version info Firmware: 20050620, FPGA: 16, spm_count = 0
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (79 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 79 Unavail Secs
Total Data (last 29 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 25328 Unavail Secs
Конфиг
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
controller E1 0/0/0
channel-group 0 timeslots 1-31 Это сущаствующий
controller E1 0/0/1
framing NO-CRC4
channel-group 1 timeslots 1-31 В этот сечас ничего не воткнуто
loopback diag
controller E1 0/1/0
channel-group 2 timeslots 1-31 этот который сечас настраиваем
interface Loopback0
ip address
interface Multilink1
no ip address
ppp multilink
ppp multilink fragment delay 10
ppp multilink interleave
ppp multilink group 1
interface FastEthernet0/0
description
no ip address
load-interval 30
speed 10
full-duplex
interface FastEthernet0/0.2
encapsulation dot1Q 2
ip address
no snmp trap link-status
interface FastEthernet0/1
no ip address
duplex auto
speed auto
interface Serial0/0/0:0
ip unnumbered Loopback0
encapsulation ppp
interface Serial0/0/1:1
no ip address
interface Serial0/1/0:2
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0
ip route
no ip http server
ip http access-class 23
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
disable-eadi
control-plane
banner motd ^CC
RAI -- это remote alarm indicator (или типа того)
т.е. это бит, который устанавливает УДАЛЕННАЯ сторона, когда видет проблему.
Вы ищете не на той стороне. обратитесь к провайдеру услуги (возможно, у них тупо один из проводов RX незакроссирован нормально).
