Никак не могу настроить multicast routing на Catalyst 6500. Чего-то не хватает, но чего, я увы пока понять не могу.
Catalyst 6500 с SUP2 (IOS 12.2(18) ADVIPSERVICESK9_WAN-M).
В Fa3/48 включен PBI 4000-42S, порт access'ом в vlan 398 (везде по тексту XX.XX.XX.XX - это один и тот же IP):
ip pim rp-address XX.XX.XX.XX
interface Vlan398
ip address XX.XX.XX.XX 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip igmp snooping mrouter interface FastEthernet3/48
Вижу только одну multicast группу (PIM)
# sh ip igmp groups
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
224.0.1.40 Vlan398 2d01h 00:02:39 XX.XX.XX.XX
Пытаюсь присоединится к группе 238.1.1.1 с vlan 397:
# sh run int vlan 397
interface Vlan397
ip address 192.168.99.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
# sh ip igmp int vlan 397
Vlan397 is up, line protocol is up
Internet address is 192.168.99.2/30
IGMP is disabled on interface
Multicast routing is disabled on interface
Multicast TTL threshold is 0
No multicast groups joined by this system
IGMP snooping is globally enabled
IGMP snooping is enabled on this interface
IGMP snooping fast-leave (for v2) is disabled and querier is disabled
IGMP snooping explicit-tracking is enabled
IGMP snooping last member query response interval is 1000 ms
IGMP snooping report-suppression is enabled
Смущает "IGMP is disabled on interface" и "Multicast routing is disabled on interface"
В то же время на int vlan 398, где включен pim эти параметры "enabled":
#sh ip igmp int vlan 398
Vlan398 is up, line protocol is up
Internet address is XX.XX.XX.XX/30
IGMP is enabled on interface
Current IGMP host version is 2
Current IGMP router version is 2
IGMP query interval is 60 seconds
IGMP querier timeout is 120 seconds
IGMP max query response time is 10 seconds
Last member query count is 2
Last member query response interval is 1000 ms
Inbound IGMP access group is not set
IGMP activity: 1 joins, 0 leaves
Multicast routing is enabled on interface
Multicast designated router (DR) is XX.XX.XX.XX (this system)
IGMP querying router is XX.XX.XX.XX (this system)
Multicast groups joined by this system (number of users):
224.0.1.40(1)
Что нужно сделать для того, чтобы заработал роутинг multicast? PIM включать и на клиентских интерфейсах (как-то не то)?
Снимите с ручника, пожалуйста :-) Подскажите что делать.
Ок, с этим разобрались, огромное спасибо!
Теперь, когда я делаю join с Vlan397 в группу 238.1.1.1, то Catalyst это отрабатывает:
#sh ip igmp groups
238.1.1.1        Vlan397                  00:00:05  00:02:54  192.168.99.1
224.0.1.40       Vlan398                  2d18h     00:02:04  XX.XX.XX.XX
Но rtp потока с PBI я не вижу (на PBI настроено 6 каналов в группах 238.1.1.1-238.1.1.6)
Чего-то еще не хватает...
поток в интерфейс идёт? нагрузка на порту/svi есть?
TTL > 1? на PBI адреса подсетки вещания из сети которая на vl398?
точкой рандеву лучше объявить лупбек.
Переключил рандеву поинт на лупбек.
А по поводу multicast все оказалось донельзя глупо: я пытался получить поток с management ethernet.
Немного оправдывает то, что я далеко и PBI ни разу в глаза не видел, но все равно обидно :-)
Появится тех. персонал на площадке, попрошу включить в свич второй порт, а пока уберу pim с управляющего VLAN :-)
А как разрешить только igmp join с клиентских VLAN?
А то включил ip pim sparse-mode в офисном vlan'е и свич тут же увидел 2 группы:
#sh ip igmp groups
224.0.1.40       Vlan397                  1d00h     00:02:40  192.168.99.2
224.0.1.60       Vlan98                   14:49:34  00:02:43  10.0.0.59
239.255.255.250  Vlan98                   00:43:27  00:02:36  10.0.0.252
