Доброе время суток.
Есть cisco 7206, на ней поднят PPPoE, обрабатывает примерно 140Мб(в час пик чуть более 1000 абонентов) трафика.
При этом наблюдается довольно высокая загрузка CPU:
CPU utilization for five seconds: 47%/41%; one minute: 45%; five minutes: 46%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
44 27957584 1637899 17069 2.39% 1.29% 1.27% 0 Per-Second Jobs
267 1179532 51393612 22 0.87% 0.87% 0.86% 0 PPP Events
5 2249036 208526 10785 0.87% 0.14% 0.09% 0 Check heaps
87 10696704 53866996 198 0.39% 0.47% 0.61% 0 IP Input
19 5084240 94833484 53 0.31% 0.26% 0.25% 0 ARP Input
264 1235016 4160186 296 0.23% 0.16% 0.16% 0 PPPoE Discovery
97 780720 1426639 547 0.15% 0.10% 0.08% 0 SSS Manager
142 29432 381901590 0 0.15% 0.20% 0.21% 0 HQF Shaper Backg
112 172660 2438754 70 0.15% 0.15% 0.15% 0 CEF: IPv4 proces
6 55960 191513 292 0.07% 0.00% 0.00% 0 Pool Manager
257 1140108 6339086 179 0.07% 0.09% 0.08% 0 RADIUS
110 89924 253806 354 0.07% 0.00% 0.00% 0 IP RIB Update
109 72284 711808 101 0.07% 0.00% 0.00% 0 IP Background
40 104980 917502 114 0.07% 0.03% 0.02% 0 Net Background
266 23496 48266110 0 0.07% 0.07% 0.07% 0 PPP manager
16 27152 28050742 0 0.00% 0.01% 0.00% 0 EnvMon
Плюс к этому наблюдается большое количество ошибок на интерфейсе:
GigabitEthernet0/1 is up, line protocol is up
Hardware is MV64460 Internal MAC, address is 000d.bcfd.771b (bia 000d.bcfd.771b)
Description: MANAGMENT
Internet address is 192.168.16.2/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 6/255, rxload 105/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is RJ45
output flow-control is XON, input flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 3/75/1315303/16 (size/max/drops/flushes); Total output drops: 35
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 41444000 bits/sec, 16683 packets/sec
5 minute output rate 104395000 bits/sec, 16115 packets/sec
4039847522 packets input, 1488246833 bytes, 41 no buffer
Received 202067301 broadcasts, 0 runts, 0 giants, 0 throttles
530179 input errors, 0 CRC, 0 frame, 0 overrun, 530179 ignored
0 watchdog, 46836686 multicast, 0 pause input
0 input packets with dribble condition detected
4030099125 packets output, 434300790 bytes, 0 underruns
8 output errors, 0 collisions, 2 interface resets
2355702 unknown protocol drops
0 babbles, 0 late collision, 0 deferred
8 lost carrier, 0 no carrier, 0 pause output
0 output buffer failures, 0 output buffers swapped out
GigabitEthernet0/1.5 is up, line protocol is up
Description: WAN Vlan5
Internet address is ХХ.ХХ.ХХ.2/23
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 100 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 5.
GigabitEthernet0/1.24 is up, line protocol is up
Description: LAN PPPoE Clients
Internet address is 192.168.24.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 24.
В чем может быть причина такой загрузки и большого количества ошибок?
ignored - это не ошибки, это отброшенные пакеты. Вилан не тот, пакет какой-нибудь IPX/IPv6. Короче всё, что не попало в обработку - ignored.
А загрузка для NPE-G1 нормальная, он 300 мегабит с трудом проедает в качестве БРАСа.
Вот бордером - другое дело...
NPE-G2 тоже не слишком крут, 300 мегабит и для него неплохо.
Кстати, на новых IOS'ах (как раз 12.4Т) NPE-G1 слабее NPE-G2 чуть не в два раза...
TurboACL включены? Они неплохо могут уменьшить загрузку.
show interface switching можно?
а почему такой разброс txload 6/255, rxload 105/255 ?
ну судя по последнему как раз мегабит 400 ;) а не 140. Проверьте может быть кто-то флудит.
sh int switching
GigabitEthernet0/1 MANAGMENT
Throttle count 0
Drops RP 1371341 SP 0
SPD Flushes Fast 16 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 167622509 Drops 1370394
Protocol IP
Switching path Pkts In Chars In Pkts Out Chars Out
Process 4001345 414840273 4423880 2520373297
Cache misses 0 - - -
Fast 52082737 3291768004 105058688 707183325
Auton/SSE 0 0 0 0
Protocol ARP
Process 159487961 979102470 734700 46325820
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol CDP
Process 27335 11890341 27353 10202708
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol PPPoE
Process 41639161 4135582662 163263480 1745385687
Fast 458255498 212266502 406646787 1130019021
Auton/SSE 0 0 0 0
Protocol Other
Process 2485159 175226374 1005745 63854658
Fast 0 0 0 0
Auton/SSE 0 0 0 0
NOTE: all counts are cumulative and reset only after a reload.
Interface FastEthernet0/2 is disabled
GigabitEthernet0/2 OUTSIDE
Throttle count 0
Drops RP 0 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 729464 Drops 0
Protocol IP
Process 34783748 571663775 4017342 291729086
Fast 1815621740 2648370427 2174777350 1233012041
Auton/SSE 0 0 0 0
Protocol ARP
Process 13748 824880 125935 7556100
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol CDP
Process 27342 11893770 27347 10200431
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Protocol Other
Process 0 0 164035 9842100
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Interface GigabitEthernet0/3 is disabled
Loopback0 Source LoopBack
All statistics for this interface are zero.
NVI0
Virtual-Access1
Virtual-Access2
Throttle count 0
Drops RP 0 SP 0
SPD Aggress Fast 0
SPD Priority Inputs 26493457 Drops 0
Protocol IP
Process 39199782 3073989203 62165378 3829812575
Fast 353068099 514203385 406513130 4039823503
Auton/SSE 0 0 0 0
Protocol PPPoE
Process 0 0 8519 187326
Fast 0 0 133685 1503590
Auton/SSE 0 0 0 0
Protocol Other
Process 1004 115810 99803568 1395976849
Fast 0 0 0 0
Auton/SSE 0 0 0 0
Virtual-Template1
Virtual-Template2 PPTP
По какому принципу считается что rxload105/255 это 400Мб?
  • 2 weeks later...
