user_145 Posted October 28, 2009 Posted October 28, 2009 Здравствуйте. Столкнулся с такой проблемой. Есть маршрутизатор циско 2811. В него был вставлен модуль vic2-2fxo. Вроде маршрутизатор видит #show diag Slot 0: C2811 Motherboard with 2FE and integrated VPN Port adapter, 2 ports Port adapter is analyzed Port adapter insertion time unknown Onboard VPN : v2.2.0 EEPROM contents at hardware discovery: PCB Serial Number : FOC0950282L Hardware Revision : 1.0 Top Assy. Part Number : 800-21849-02 Board Revision : B0 Deviation Number : 0 Fab Version : 03 RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Processor type : 87 Hardware date code : 20051216 Chassis Serial Number : FCZ100170U4 Chassis MAC Address : 0015.fad8.21a8 MAC Address block size : 24 CLEI Code : CNMJ7N0BRA Product (FRU) Number : CISCO2811 Part Number : 73-10258-03 Version Identifier : V02 EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF C1 8B 46 4F 43 30 39 35 30 32 38 32 4C 40 0x10: 03 E7 41 01 00 C0 46 03 20 00 55 59 02 42 42 30 0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00 0x30: 09 87 83 01 31 F5 10 C2 8B 46 43 5A 31 30 30 31 0x40: 37 30 55 34 C3 06 00 15 FA D8 21 A8 43 00 18 C6 0x50: 8A 43 4E 4D 4A 37 4E 30 42 52 41 CB 8F 43 49 53 0x60: 43 4F 32 38 31 31 20 20 20 20 20 20 82 49 28 12 0x70: 03 89 56 30 32 20 D9 02 40 C1 FF FF FF FF FF FF WIC Slot 3: 2nd generation - FXO Voice daughter card (2 port) Hardware Revision : 5.0 Top Assy. Part Number : 800-21597-03 Board Revision : B0 Deviation Number : 0-0 Fab Version : 04 PCB Serial Number : FOC121904R5 RMA Test History : 00 RMA Number : 0-0-0-0 RMA History : 00 Product (FRU) Number : VIC2-2FXO Version Identifier : V02 CLEI Code : CNUIARTAAB EEPROM format version 4 EEPROM contents (hex): 0x00: 04 FF 40 00 4D 41 05 00 C0 46 03 20 00 54 5D 03 0x10: 42 42 30 80 00 00 00 00 02 04 C1 8B 46 4F 43 31 0x20: 32 31 39 30 34 52 35 03 00 81 00 00 00 00 04 00 0x30: CB 89 56 49 43 32 2D 32 46 58 4F 89 56 30 32 20 0x40: C6 8A 43 4E 55 49 41 52 54 41 41 42 FF FF FF FF 0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF #show version Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9_IVS-M), Version 12.4(9)T, RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright © 1986-2006 by Cisco Systems, Inc. Compiled Fri 16-Jun-06 22:22 by prod_rel_team Cisco 2811 (revision 53.51) with 772096K/14336K bytes of memory. Processor board ID FCZ100170U4 2 FastEthernet interfaces 18 Serial interfaces 2 Channelized E1/PRI ports 1 Virtual Private Network (VPN) Module 2 Voice FXO interfaces DRAM configuration is 64 bits wide with parity enabled. 239K bytes of non-volatile configuration memory. 62720K bytes of ATA CompactFlash (Read/Write) Configuration register is 0x3922 При попытке обнаружить в конфигурации #show voice port глухо. при #conf t (config)#voice-port ? <1-50> Voice interface slot 1- это установленный модуль с е1 50 - виртуальные порты CME Судя с show diag - vic2-fxo должен опознаваться как voice-port 0/3/х. В чем может быть проблема? Как достучаться? Заранее благодарен за помощь. Вставить ник Quote
