Помогите, уже мозг вынес себе ПЛНОСТЬЮ )))
поставил Icecast2 Win32 и через него хочу ретранслировать радиосьанции из Интернета в локальную сеть.
вот мой конфиг:
<!-- This config file contains a minimal set of configurable parameters,
and mostly just contains the things you need to change. We created
this for those who got scared away from the rather large and heavily
commented icecast.xml.dist file. -->
<icecast>
<limits>
<clients>100</clients>
<!-- skolko stantcij -->
<sources>50</sources>
<threadpool>5</threadpool>
<queue-size>102400</queue-size>
<client-timeout>30</client-timeout>
<header-timeout>15</header-timeout>
<source-timeout>10</source-timeout>
<!-- If enabled, this will provide a burst of data when a client
first connects, thereby significantly reducing the startup
time for listeners that do substantial buffering. However,
it also significantly increases latency between the source
client and listening client. For low-latency setups, you
might want to disable this. -->
<burst-on-connect>1</burst-on-connect>
<!-- same as burst-on-connect, but this allows for being more
specific on how much to burst. Most people won't need to
change from the default 64k. Applies to all mountpoints -->
<burst-size>32768</burst-size>
</limits>
<authentication>
<source-password>victor</source-password>
<relay-password>victor</relay-password>
<admin-user>admin</admin-user>
<admin-password>789512301</admin-password>
</authentication>
<relay>
<server>radio.north.kz</server>
<port>8000</port>
<mount>/ultra-192</mount>
<local-mount>/ultra</local-mount>
<relays-on-demand>1</relays-on-demand>
<relay-shoutcast-metadata>0</relay-shoutcast-metadata>
</relay>
<hostname>localhost</hostname>
<listen-socket>
<port>8000</port>
</listen-socket>
<fileserve>1</fileserve>
<paths>
<logdir>./logs</logdir>
<webroot>./web</webroot>
<adminroot>./admin</adminroot>
<alias source="/" dest="/status.xsl"/>
</paths>
<logging>
<accesslog>access.log</accesslog>
<errorlog>error.log</errorlog>
<loglevel>3</loglevel> <!-- 4 Debug, 3 Info, 2 Warn, 1 Error -->
</logging>
</icecast>
НИФИГА НЕПОЛУЧАЕТСЯ!
кучу статей перечитал, добился только того что радио УЛТРА в самой программе появляется
на страничке, куда должен заходить клиент - радио вообще никакого.
Заранее благодарен!
Бери мой конфиг. 124 радиостанции. Обязательно поправь пароль и имя хоста. Если есть проблемы пиши разберёмся.
<icecast>
<limits>
<clients>500</clients>
<sources>100</sources>
<threadpool>50</threadpool>
<queue-size>524288</queue-size>
<burst-size>65536000</burst-size>
</limits>
<authentication>
<relay-password>pass</relay-password>
<admin-user>root</admin-user>
<admin-password>pass</admin-password>
</authentication>
<directory>
<yp-url-timeout>15</yp-url-timeout>
<yp-url>http://dir.xiph.org/cgi-bin/yp-cgi</yp-url>
</directory>
<directory>
<yp-url>http://www.oddsock.org/cgi-bin/yp-cgi</yp-url>
</directory>
#------------------------------------------------------------------------------ Все, что ниже это Радиостанции
<relay>
<server>trance.liquid.fm</server>
<port>8000</port>
<local-mount>/trance.liquid.fm.mp3</local-mount>
<on-demand>1</on-demand>
<relay-shoutcast-metadata>1</relay-shoutcast-metadata>
</relay>
<relay>
<server>194.67.28.101</server>
<port>8000</port>
<mount>/</mount>
<local-mount>/combat</local-mount>
</relay>
<relay>
<server>217.10.44.211</server>
<port>8000</port>
<mount>/europaplus128.mp3</mount>
<local-mount>/europaplus128.mp3</local-mount>
</relay>
<relay>
<port>8000</port>
<mount>/mayak128.mp3</mount>
<local-mount>/mayak128.mp3</local-mount>
</relay>
<relay>
<port>8000</port>
<mount>/moscowecho128.mp3</mount>
<local-mount>/moscowecho128.mp3</local-mount>
</relay>
<relay>
<port>8000</port>
<mount>/orfey128.mp3</mount>
<local-mount>/orfey128.mp3</local-mount>
</relay>
<relay>
<port>8000</port>
<mount>/radioretro128.mp3</mount>
<local-mount>/radioretro128.mp3</local-mount>
</relay>
<relay>
<port>8000</port>
<mount>/radioyunost128.mp3</mount>
<local-mount>/radioyunost128.mp3</local-mount>
</relay>
<relay>
<port>8000</port>
<mount>/silverrain128.mp3</mount>
<local-mount>/silverrain128.mp3</local-mount>
</relay>
<relay>
<server>85.21.79.5</server>
<port>8091</port>
<mount>/</mount>
<local-mount>/rnb</local-mount>
</relay>
<relay>
<port>8000</port>
<mount>/</mount>
<local-mount>/PsychedeliC</local-mount>
</relay>
<relay>
<port>8005</port>
<mount>/</mount>
<local-mount>/POP</local-mount>
</relay>
<relay>
<port>8010</port>
<mount>/</mount>
<local-mount>/DarkMetal</local-mount>
</relay>
<relay>
<port>8015</port>
<mount>/</mount>
<local-mount>/DruMandBasS</local-mount>
</relay>
<relay>
<port>8025</port>
<mount>/</mount>
<local-mount>/HousE</local-mount>
</relay>
<relay>
<port>8030</port>
<mount>/</mount>
<local-mount>/BriT</local-mount>
</relay>
<relay>
<port>8035</port>
<mount>/</mount>
<local-mount>/ambient</local-mount>
</relay>
<relay>
<port>8040</port>
<mount>/</mount>
<local-mount>/deepmix</local-mount>
</relay>
<relay>
<port>8100</port>
<mount>/</mount>
<local-mount>/ULTRA</local-mount>
</relay>
<relay>
<port>8050</port>
<mount>/</mount>
<local-mount>/EuroHIT</local-mount>
</relay>
<relay>
<port>8060</port>
<mount>/</mount>
<local-mount>/MFM</local-mount>
</relay>
<relay>
<port>8045</port>
<mount>/</mount>
<local-mount>/MDS</local-mount>
</relay>
<relay>
<port>8067</port>
<mount>/</mount>
<local-mount>/ShaNsoN</local-mount>
</relay>
<relay>
<port>8071</port>
<mount>/</mount>
<local-mount>/RagnaroK</local-mount>
</relay>
<relay>
<port>8073</port>
<mount>/</mount>
<local-mount>/RocK-Ru</local-mount>
</relay>
<relay>
<port>9054</port>
<mount>/</mount>
<local-mount>/BigBeatH</local-mount>
</relay>
<relay>
<port>9056</port>
<mount>/</mount>
<local-mount>/BigBeatM</local-mount>
</relay>
<relay>
<port>8075</port>
<mount>/</mount>
<local-mount>/AlterRadio</local-mount>
</relay>
<relay>
<port>9058</port>
<mount>/</mount>
<local-mount>/sevenskies</local-mount>
</relay>
<relay>
<port>8002</port>
<mount>/</mount>
<local-mount>/Armenia</local-mount>
</relay>
<relay>
<port>8007</port>
<mount>/</mount>
<local-mount>/Beatles</local-mount>
</relay>
<relay>
<port>8012</port>
<mount>/</mount>
<local-mount>/Mix</local-mount>
</relay>
<relay>
<port>8017</port>
<mount>/</mount>
<local-mount>/CyberSpace</local-mount>
</relay>
<relay>
<port>8022</port>
<mount>/</mount>
<local-mount>/RusReggae</local-mount>
</relay>
<relay>
<port>8027</port>
<mount>/</mount>
<local-mount>/Jazz</local-mount>
</relay>
<relay>
<port>8032</port>
<mount>/</mount>
<local-mount>/NRJRock</local-mount>
</relay>
<relay>
<port>8037</port>
<mount>/</mount>
<local-mount>/EasyListening</local-mount>
</relay>
<relay>
<port>8042</port>
<mount>/</mount>
<local-mount>/visotsky</local-mount>
</relay>
<relay>
<port>8047</port>
<mount>/</mount>
<local-mount>/Instrumental</local-mount>
</relay>
<relay>
<port>8052</port>
<mount>/</mount>
<local-mount>/Live</local-mount>
</relay>
<relay>
<port>8054</port>
<mount>/</mount>
<local-mount>/USSR5070</local-mount>
</relay>
<relay>
<port>8056</port>
<mount>/</mount>
<local-mount>/Experimental</local-mount>
</relay>
<relay>
<port>8058</port>
<mount>/</mount>
<local-mount>/NRJBrum</local-mount>
</relay>
<relay>
<port>8062</port>
<mount>/</mount>
<local-mount>/Ukrainian</local-mount>
</relay>
<relay>
<port>8064</port>
<mount>/</mount>
<local-mount>/Musicles</local-mount>
</relay>
<relay>
<port>8069</port>
<mount>/</mount>
<local-mount>/Queen</local-mount>
</relay>
<relay>
<port>8077</port>
<mount>/</mount>
<local-mount>/NRJTrance</local-mount>
</relay>
<relay>
<port>8079</port>
<mount>/</mount>
<local-mount>/Swing</local-mount>
</relay>
<relay>
<port>8081</port>
<mount>/</mount>
<local-mount>/NewYork</local-mount>
</relay>
<relay>
<port>8083</port>
<mount>/</mount>
<local-mount>/Country</local-mount>
</relay>
<relay>
<port>8085</port>
<mount>/</mount>
<local-mount>/Erotic</local-mount>
</relay>
<relay>
<port>8087</port>
<mount>/</mount>
<local-mount>/Fabrika</local-mount>
</relay>
<relay>
<port>8105</port>
<mount>/</mount>
<local-mount>/Chanson</local-mount>
</relay>
<relay>
<port>8107</port>
<mount>/</mount>
<local-mount>/Atmospheric</local-mount>
</relay>
<relay>
<port>8089</port>
<mount>/</mount>
<local-mount>/NRJDance</local-mount>
</relay>
<relay>
<port>8093</port>
<mount>/</mount>
<local-mount>/NRJTop30</local-mount>
</relay>
<relay>
<port>8095</port>
<mount>/</mount>
<local-mount>/NRJHouse</local-mount>
</relay>
<relay>
<port>8097</port>
<mount>/</mount>
<local-mount>/NRJElectro</local-mount>
</relay>
<relay>
<port>8109</port>
<mount>/</mount>
<local-mount>/NRJProgressive</local-mount>
</relay>
<relay>
<port>8111</port>
<mount>/</mount>
<local-mount>/BreakBeat</local-mount>
</relay>
<relay>
<port>8113</port>
<mount>/</mount>
<local-mount>/NRJTechno</local-mount>
</relay>
<relay>
<port>8117</port>
<mount>/</mount>
<local-mount>/PsyGoaTrance</local-mount>
</relay>
<relay>
<port>8119</port>
<mount>/</mount>
<local-mount>/GangstaRap</local-mount>
</relay>
<relay>
<port>8121</port>
<mount>/</mount>
<local-mount>/disco80</local-mount>
</relay>
<relay>
<port>8125</port>
<mount>/</mount>
<local-mount>/autoradio</local-mount>
</relay>
<relay>
<port>8127</port>
<mount>/</mount>
<local-mount>/HihiFM</local-mount>
</relay>
<relay>
<port>8129</port>
<mount>/</mount>
<local-mount>/GenreClassic</local-mount>
</relay>
<relay>
<port>8131</port>
<mount>/</mount>
<local-mount>/anecdot</local-mount>
</relay>
<relay>
<port>8133</port>
<mount>/</mount>
<local-mount>/Office</local-mount>
</relay>
<relay>
<port>8135</port>
<mount>/</mount>
<local-mount>/SmoothJazz</local-mount>
</relay>
<relay>
<port>8137</port>
<mount>/</mount>
<local-mount>/CinemaMusic</local-mount>
</relay>
<relay>
<port>8139</port>
<mount>/</mount>
<local-mount>/LoveSongs</local-mount>
</relay>
<relay>
<port>8141</port>
<mount>/</mount>
<local-mount>/chillout</local-mount>
</relay>
<relay>
<port>8143</port>
<mount>/</mount>
<local-mount>/BreathofNature</local-mount>
</relay>
<relay>
<port>8145</port>
<mount>/</mount>
<local-mount>/Ambient</local-mount>
</relay>
<relay>
<port>8147</port>
<mount>/</mount>
<local-mount>/RussP</local-mount>
</relay>
<relay>
<port>8149</port>
<mount>/</mount>
<local-mount>/MilitarySongs</local-mount>
</relay>
<relay>
<port>8151</port>
<mount>/</mount>
<local-mount>/KSP</local-mount>
</relay>
<relay>
<port>8153</port>
<mount>/</mount>
<local-mount>/VIA</local-mount>
</relay>
<relay>
<port>8155</port>
<mount>/</mount>
<local-mount>/RussianFolk</local-mount>
</relay>
<relay>
<port>8157</port>
<mount>/</mount>
<local-mount>/RusRap</local-mount>
</relay>
<relay>
<port>8159</port>
<mount>/</mount>
<local-mount>/RusRok</local-mount>
</relay>
<relay>
<port>8161</port>
<mount>/</mount>
<local-mount>/Rus90</local-mount>
</relay>
<relay>
<port>8163</port>
<mount>/</mount>
<local-mount>/RusTop50</local-mount>
</relay>
<relay>
<port>8165</port>
<mount>/</mount>
<local-mount>/ChurchMusic</local-mount>
</relay>
<relay>
<port>8167</port>
<mount>/</mount>
<local-mount>/shanson101</local-mount>
</relay>
<relay>
<port>8169</port>
<mount>/</mount>
<local-mount>/KavkazHits</local-mount>
</relay>
<relay>
<port>8171</port>
<mount>/</mount>
<local-mount>/USSR3050</local-mount>
</relay>
<relay>
<port>8173</port>
<mount>/</mount>
<local-mount>/Shanson2</local-mount>
</relay>
<relay>
<port>8175</port>
<mount>/</mount>
<local-mount>/Crying</local-mount>
</relay>
<relay>
<port>8177</port>
<mount>/</mount>
<local-mount>/Folk</local-mount>
</relay>
<relay>
<port>8179</port>
<mount>/</mount>
<local-mount>/TimeMachine</local-mount>
</relay>
<relay>
<port>8183</port>
<mount>/</mount>
<local-mount>/PinkFloyd</local-mount>
</relay>
<relay>
<port>8185</port>
<mount>/</mount>
<local-mount>/AquariumBG</local-mount>
</relay>
<relay>
<port>8189</port>
<mount>/</mount>
<local-mount>/Reggae</local-mount>
</relay>
<relay>
<port>8191</port>
<mount>/</mount>
<local-mount>/RocknRoll</local-mount>
</relay>
<relay>
<port>8193</port>
<mount>/</mount>
<local-mount>/Mainstream101</local-mount>
</relay>
<relay>
<port>8195</port>
<mount>/</mount>
<local-mount>/Gold90</local-mount>
</relay>
<relay>
<port>8197</port>
<mount>/</mount>
<local-mount>/Dance90</local-mount>
</relay>
<relay>
<port>8199</port>
<mount>/</mount>
<local-mount>/SoulFunk</local-mount>
</relay>
<relay>
<port>8201</port>
<mount>/</mount>
<local-mount>/LiveMixed</local-mount>
</relay>
<relay>
<port>8203</port>
<mount>/</mount>
<local-mount>/Emo</local-mount>
</relay>
<relay>
<port>8205</port>
<mount>/</mount>
<local-mount>/EuroHits</local-mount>
</relay>
<relay>
<port>8207</port>
<mount>/</mount>
<local-mount>/CatsDogs</local-mount>
</relay>
<relay>
<port>8209</port>
<mount>/</mount>
<local-mount>/Disco</local-mount>
</relay>
<relay>
<port>8211</port>
<mount>/</mount>
<local-mount>/BabyBox</local-mount>
</relay>
<relay>
<port>8213</port>
<mount>/</mount>
<local-mount>/Lalaby</local-mount>
</relay>
<relay>
<port>8215</port>
<mount>/</mount>
<local-mount>/Gladkov</local-mount>
</relay>
<relay>
<port>8217</port>
<mount>/</mount>
<local-mount>/Italia</local-mount>
</relay>
<relay>
<port>8219</port>
<mount>/</mount>
<local-mount>/latino</local-mount>
</relay>
<relay>
<port>8221</port>
<mount>/</mount>
<local-mount>/MosaiqueFrancaise</local-mount>
</relay>
<relay>
<port>8223</port>
<mount>/</mount>
<local-mount>/Gypsy</local-mount>
</relay>
<relay>
<port>8225</port>
<mount>/</mount>
<local-mount>/vostok</local-mount>
</relay>
<relay>
<port>8227</port>
<mount>/</mount>
<local-mount>/Japan</local-mount>
</relay>
<relay>
<port>8229</port>
<mount>/</mount>
<local-mount>/Spivakov</local-mount>
</relay>
<relay>
<port>8231</port>
<mount>/</mount>
<local-mount>/Opera</local-mount>
</relay>
<relay>
<port>8233</port>
<mount>/</mount>
<local-mount>/PopClassic</local-mount>
</relay>
<relay>
<port>8235</port>
<mount>/</mount>
<local-mount>/Hard</local-mount>
</relay>
<relay>
<port>8237</port>
<mount>/</mount>
<local-mount>/RockRing</local-mount>
</relay>
<relay>
<port>8239</port>
<mount>/</mount>
<local-mount>/TrashZone</local-mount>
</relay>
<relay>
<port>8241</port>
<mount>/</mount>
<local-mount>/RockRemakes</local-mount>
</relay>
<relay>
<port>8243</port>
<mount>/</mount>
<local-mount>/RockGuitar</local-mount>
</relay>
<relay>
<server>scfire-ntc-aa07.stream.aol.com</server>
<port>80</port>
<mount>/stream/1003</mount>
<local-mount>/tranceaol</local-mount>
</relay>
#------------------------------------------------------------------------------ Все, что ниже поменяй пути из своего конфига
<paths>
<basedir>/usr/share/icecast</basedir>
<logdir>/var/log/icecast</logdir>
<webroot>/usr/share/icecast/web</webroot>
<adminroot>/usr/share/icecast/admin</adminroot>
</paths>
<logging>
<loglevel>4</loglevel>
<logsize>10000</logsize>
</logging>
<security>
<chroot>0</chroot>
<changeowner>
<user>icecast</user>
<group>nogroup</group>
</changeowner>
</security>
</icecast>
Пробую.
Запахало!!!!!
колдовал с конфигом, потом совсем что то запутался в трех соснах )))
Удалил прогу и заново поставил.
Добавил ЛИМИТЫ с твоего конфига
РЕЛАЙ - свои.
заработало.
Вначале с одной радиостанцией.
Работает, ратранслирует. При очередном прослушивании плеер выдает ошибку о "Ошибка синхронизации"
Добавил еще несколько РЕЛАЙ радиостанций.
Работают, но ошибку о синзронизации также выдает.
Спасибо!
Edited by baramykin
  • 5 weeks later...
