Добрый день
кто нибудь прикручивал этот рэйд контролер?
драйвера которые даются на сайте не собираются
../../../dev/mfi/mfi.c: In function 'mfi_alloc_skinny_memory':
../../../dev/mfi/mfi.c:688: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:722: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:723: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:728: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:728: warning: format '%lld' expects type 'long long int', but argument 3 has type 'uint64_t'
../../../dev/mfi/mfi.c:766: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:769: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:807: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:811: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:821: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c: In function 'mfi_free_skinny_memory':
../../../dev/mfi/mfi.c:1142: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:1146: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c:1156: warning: cast to pointer from integer of different size
../../../dev/mfi/mfi.c: In function 'mfi_bio_command':
../../../dev/mfi/mfi.c:2104: warning: cast from pointer to integer of different size
../../../dev/mfi/mfi.c:2106: warning: cast from pointer to integer of different size
../../../dev/mfi/mfi.c: In function 'mfi_ioctl':
../../../dev/mfi/mfi.c:2955: warning: cast to pointer from integer of different size
Видимо код не приспособлен для amd64. Такие ошибки возникают из-за попытки присвоения 64-битному указателю значения 32-битной переменной. Если других проблем нет, то можно и самому допилить.
