hiller Posted August 21, 2009 Posted August 21, 2009 Необходимо мониторить работоспособность аудио-потоков с Icecast сервера. Нашел вот такой пример, но он похоже, что не совместим с последними версиями Icecast :( #!/usr/bin/perl # # Try to connect to an Icecast server. # # Optionally, specify stream mountpoints to make sure they're # currently mounted. # # To accomplish this, just pass the mountpoints after the hostname # using a colon after the hostname and a comma to delimit mountpoints. # # Example: neptune:/seattletech,/seattletech-56k,/bdean,/drzzzzz # # Outputs hostname:<mountpoint> on failures, or prepends an '*' to the # hostname to indicate an inability to contact the icecast host in # general. # # Example: # # neptune:/seattletech (mountpoint is not mounted on server neptune) # *neptune (icecast server on neptune is not responding) # # # Written by Mark Rushing - rushing@orbislumen.net # # icecast.monitor 0.2 13-Jun-2001 # # Copyright (C) 2001, Mark Rushing # # This program is free software; you can redistribute it and/or modify # it under the terms of the GNU General Public License as published by # the Free Software Foundation; either version 2 of the License, or # (at your option) any later version. # # This program is distributed in the hope that it will be useful, # but WITHOUT ANY WARRANTY; without even the implied warranty of # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the # GNU General Public License for more details. # # You should have received a copy of the GNU General Public License # along with this program; if not, write to the Free Software # Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA use IO::Socket; use Getopt::Std; getopts("p:t:u:P:"); $ICport = "$opt_p" || 8000; $ICtimeout = "$opt_t" || 30; $ICadmin = "$opt_u" || "ADMIN"; $ICpasswd = "$opt_P"; ICHOST: foreach $ICarg (@ARGV) { # Separate hostname from stream mountpoints. ($IChost, $ICstreams) = split /:/, $ICarg, 2; # Create socket connection to hostname. ## Don't bother checking streams if failed. if (!openIcecastSock($IChost)) { push(@failed, "\*$IChost"); next; } # Don't bother checking streams if none given. if (!$ICstreams) { close $ICsock; next; } eval { # Check streams on connected host. ## Log into server. local $SIG{ALRM} = sub { die "Command Timeout" }; alarm $ICtimeout; print $ICsock "$ICadmin $ICpasswd\n\n"; while ( <$ICsock> ) { last if /^OK/; if (/ERROR - Bad Password/) { push(@failed, "$IChost\:Bad Password"); next ICHOST; } } ## Get stream data. @mountedStreams = (); print $ICsock "sources\n"; while (<$ICsock>) { last if /^End of source listing/; if (s/.*\[Mountpoint: (\S+)\].*\n/$1/) { push(@mountedStreams, $_); } } print $ICsock "quit Mon signoff\n"; close $ICsock; alarm 0; }; if ($@) { push(@failed, "$IChost\:$@"); next; } # Figure if monitored streams are actually mounted @checkStream = split /,/, $ICstreams; foreach $stream (@checkStream) { push(@failed, "$IChost\:$stream") if (!grep /^$stream/, @mountedStreams) } } if (scalar(@failed)) { print "@failed\n"; exit 1; } exit 0; sub openIcecastSock { my $IChost = $_[0]; $ICsock = new IO::Socket::INET ( PeerAddr => $IChost , PeerPort => $ICport , Proto => "tcp" , Timeout => $ICtimeout , ); ( return 0 ) unless $ICsock; $ICsock->autoflush(1); return 1; } Может кто-то решал эту задачу? Вставить ник Quote
hiller Posted August 21, 2009 Author Posted August 21, 2009 Неужели только у меня есть такая задача? :( Вставить ник Quote
