Используем в качестве PPPoE-терминатора cisco7201, в качестве биллинга (радиус-сервера) LanBilling v1.8. Всё работает нормально, но иногда возникают следующие проблемы, вот вывод с браса:
3w1d: RADIUS(00001D6A): Send Access-Request to xxx.xxx.xxx.xxx:1812 id 1645/89, len 214
3w1d: RADIUS: authenticator 4D 78 81 72 74 E4 4D 8A - AB 6F D8 90 32 58 6E 71
3w1d: RADIUS: Framed-Protocol [7] 6 PPP [1]
3w1d: RADIUS: User-Name [1] 11 "w107u0508"
3w1d: RADIUS: Vendor, Microsoft [26] 24
3w1d: RADIUS: MSCHAP_Challenge [11] 18
3w1d: RADIUS: 4D 78 81 72 74 E4 4D 8A AB 6F D8 90 32 58 6E 71 [ MxrtMo2Xnq]
3w1d: RADIUS: Vendor, Microsoft [26] 58
3w1d: RADIUS: MS-CHAP-V2-Response[25] 52 *
3w1d: RADIUS: NAS-Port-Type [61] 6 Virtual [5]
3w1d: RADIUS: Vendor, Cisco [26] 18
3w1d: RADIUS: cisco-nas-port [2] 12 "0/0/1/4001"
3w1d: RADIUS: NAS-Port [5] 6 0
3w1d: RADIUS: NAS-Port-Id [87] 12 "0/0/1/4001"
3w1d: RADIUS: Vendor, Cisco [26] 41
3w1d: RADIUS: Cisco AVpair [1] 35 "client-mac-address=00e0.4c99.4c05"
3w1d: RADIUS: Service-Type [6] 6 Framed [2]
3w1d: RADIUS: NAS-IP-Address [4] 6 yyy.yyy.yyy.yyy
3w1d: RADIUS: Received from id 1645/89 xxx.xxx.xxx.xxx:1812, Access-Accept, len 483
3w1d: RADIUS: authenticator 54 40 7B 59 E2 3C A9 17 - D9 C2 41 12 03 10 DC 9C
3w1d: RADIUS: Session-Timeout [27] 6 86400
3w1d: RADIUS: Framed-IP-Address [8] 6 172.16.232.4
3w1d: RADIUS: Framed-IP-Netmask [9] 6 255.255.255.255
3w1d: RADIUS: Class [25] 7
3w1d: RADIUS: 31 31 33 39 35 [ 11395]
3w1d: RADIUS: Vendor, Microsoft [26] 51
3w1d: RADIUS: MS-CHAP-V2-Success [26] 45 "S=592B57B20F5E584A251095767814D34707A1516E"
3w1d: RADIUS: Vendor, Microsoft [26] 12
3w1d: RADIUS: MS-MPPE-Enc-Policy [7] 6
3w1d: RADIUS: 00 00 00 01
3w1d: RADIUS: MS-MPPE-Enc-Type [8] 6
3w1d: RADIUS: 00 00 00 06
3w1d: RADIUS: Vendor, Microsoft [26] 42
3w1d: RADIUS: MS-MPPE-Send-Key [16] 36 *
3w1d: RADIUS: MS-MPPE-Recv-Key [17] 36 *
3w1d: RADIUS: Acct-Interim-Interva[85] 6 60
3w1d: RADIUS: Vendor, Cisco [26] 126
3w1d: RADIUS: Cisco AVpair [1] 120 "lcp:interface-config#4=rate-limit input access-group 111 135000 25312 50625 conform-action transmit exceed-action drop"
3w1d: RADIUS: Vendor, Cisco [26] 127
3w1d: RADIUS: Cisco AVpair [1] 121 "lcp:interface-config#3=rate-limit output access-group 110 135000 25312 50625 conform-action transmit exceed-action drop"
3w1d: RADIUS: Filter-Id [11] 8
3w1d: RADIUS: 31 36 30 2E 69 6E [ 160.in]
3w1d: RADIUS(00001D6A): Received from id 1645/89
3w1d: RADIUS/ENCODE(00001D6B):Orig. component type = PPoE
3w1d: RADIUS(00001D6B): Config NAS IP: yyy.yyy.yyy.yyy
3w1d: RADIUS/ENCODE(00001D6B): acct_session_id: 7859
3w1d: RADIUS(00001D6B): sending
3w1d: RADIUS(00001D6B): Send Access-Request to xxx.xxx.xxx.xxx:1812 id 1645/90, len 214
3w1d: RADIUS: authenticator 2A 9D 1D 65 5D C0 6A 62 - AB 05 3A 4A FF 37 05 DB
3w1d: RADIUS: 2A 9D 1D 65 5D C0 6A 62 AB 05 3A 4A FF 37 05 DB [ *e]jb:J7]
3w1d: RADIUS: Received from id 1645/90 xxx.xxx.xxx.xxx:1812, Access-Reject, len 38
3w1d: RADIUS: authenticator 02 85 BB 85 21 3D C9 1E - 8A 8D 68 CB B7 D5 21 B2
3w1d: RADIUS: Vendor, Microsoft [26] 18
3w1d: RADIUS: MS-CHAP-ERROR [2] 12
3w1d: RADIUS: 01 45 3D 36 39 31 20 52 3D 31 [ E=691 R=1]
Т.е. клиент подключается, получает от радиуса Access-Accept, но почему-то клиент подключается ещё раз, т.е. делает сразу же Access-Request, естественно радиус-сервер отвечает ему Access-Reject, т.к. такой логин уже зарегистрирован и пользователь получает ошибку 691. Почему так получается? Сталкивался ли кто-нибудь с этим?
Какая у Вас версия сборки ланбиллинга?
У нас была такая проблема на 12й из-за неработающих скриптов. Суть проблемы сводилась к тому что радиус не дожидался ответа и посылал повторный запрос.
Наша версия Lanbilling 1.8.0014, а поподробнее можно, что со скриптами? или проще обратиться в техподдержку Lanbilling?
Edited by tuzhila
Если скрипт выполняется долго, то радиус не дожидается ответа и шлет повторный запрос. В 12й сборке была проблема с запуском скриптов.
