Добрый день имеем большой парк данных олтов, на многих олтах часто ону падают с LOSi
К примеру из логов
 An alarm 35113 level major occurred at 12:02:46  Tue  Apr 16  2024  IRK  %s GPON alarm link olt losi: shelf 1 slot 1 olt 7 onu 3
8 level 1
5 level 1
4 level 1
0 level 1
 An alarm 35113 level major occurred at 12:02:46  Tue  Apr 16  2024  IRK  %s GPON alarm link olt losi: shelf 1 slot 1 olt 7 onu 2
8 level 1
7 level 1
5 level 1
3 level 1
2 level 1
 An alarm 35113 level major occurred at 12:02:46  Tue  Apr 16  2024  IRK  %s GPON alarm link olt losi: shelf 1 slot 1 olt 7 onu 1
7 level 1
4 level 1
2 level 1
0 level 1
 An alarm 35113 level major occurred at 12:02:46  Tue  Apr 16  2024  IRK  %s GPON alarm link olt losi: shelf 1 slot 1 olt 7 onu 9
 level 1
 An alarm 35113 level major occurred at 12:02:46  Tue  Apr 16  2024  IRK  %s GPON alarm link olt losi: shelf 1 slot 1 olt 7 onu 6
 level 1
 An alarm 35113 level major occurred at 12:02:46  Tue  Apr 16  2024  IRK  %s GPON alarm link olt losi: shelf 1 slot 1 olt 7 onu 5
 level 1
 An alarm 35113 level major occurred at 12:02:46  Tue  Apr 16  2024  IRK  %s GPON alarm link olt losi: shelf 1 slot 1 olt 7 onu 4
 level 1
 level 1
тут упал весь порт разом, но обычно ону падают и поднимаются.
terface:         gpon-onu_1/1/6:1
  Type:                ONT_1G2
  State:               ready
  Configured channel:  auto
  Current channel:     1(GPON)
  Admin state:         enable
  Phase state:         LOS
  Config state:        success
  Authentication mode: sn
  SN Bind:             enable with SN check
  Serial number:       RTEGC9AA1B65
  Password:
  Description:         3823070164
  Vport mode:          gemport
  DBA Mode:            Hybrid
  ONU Status:          enable
  OMCI BW Profile:
  Line Profile:        1000mb
  Service Profile:     N/A
  ONU Distance:        11110m
  Online Duration:     0h 0m 0s
  FEC:                 upstream
  FEC actual mode:     upstream
  1PPS+ToD:            disable
  Auto replace:        disable
  Multicast encryption:disable
  Multicast encryption current state:N/A
       Authpass Time          OfflineTime             Cause
   1   2024-04-16 06:00:16    2024-04-16 06:01:23     LOSi
   2   2024-04-16 06:01:26    2024-04-16 06:03:30     LOSi
   3   2024-04-16 06:03:54    2024-04-16 06:03:57     LOSi
   4   2024-04-16 06:04:41    2024-04-16 09:25:09     LOSi
   5   2024-04-16 09:25:12    2024-04-16 11:08:31     LOSi
   6   2024-04-16 11:08:31    2024-04-16 11:08:43     LOSi
   7   2024-04-16 11:10:33    2024-04-16 11:26:34     LOSi
   8   2024-04-16 11:28:40    2024-04-16 11:32:38     LOSi
   9   2024-04-16 11:32:38    2024-04-16 11:32:48     LOSi
  10   2024-04-16 11:35:02    2024-04-16 11:46:42     LOSi
Еще пример, это соседний порт, то есть лосят 6 и 7 порт, при этом 1-5 порты работают стабильно. Много где читал что все это физика, но уже поменяли магистральный делитель, сфп, распределительные муфты и почти все ону на пору всем абонентам, куда еще копать?
В целом готов поделится конфигом олта, и всей другой информацией которая может понадобиться в решении данной проблемы.
  • 2 weeks later...
