pepperoni Posted September 11, 2023 Posted September 11, 2023 (edited) Что-то очень сильно грузит проц джунипера, что именно не совсем понятно. show chassis fpc 0 Temp CPU Utilization (%) Memory Utilization (%) Slot State (C) Total Interrupt DRAM (MB) Heap Buffer 0 Online 35 100 1 1953 0 93 ................ show chassis routing-engine Routing Engine status: Slot 0: Current state Master Temperature 35 degrees C / 95 degrees F CPU temperature 35 degrees C / 95 degrees F DRAM 1953 MB Memory utilization 93 percent CPU utilization: User 4 percent Background 0 percent Kernel 94 percent Interrupt 1 percent Idle 0 percent Model QFX Routing Engine Serial ID BUILTIN Uptime 1660 days, 5 hours, 9 minutes, 13 seconds Last reboot reason 0x4000:VJUNOS reboot Load averages: 1 minute 5 minute 15 minute 15.73 16.58 17.10 .......................... show system processes brief last pid: 38884; load averages: 15.97, 16.29, 16.94 up 1660+05:11:58 10:16:42 132 processes: 13 running, 101 sleeping, 18 waiting Mem: 1378M Active, 4796K Inact, 478M Wired, 22M Cache, 69M Buf, 2840K Free Swap: 1106M Total, 1106M Used, K Free, 100% Inuse ............................... show system processes extensive last pid: 38885; load averages: 21.53, 17.56, 17.37 up 1660+05:12:25 10:17:09 132 processes: 7 running, 107 sleeping, 18 waiting Mem: 1335M Active, 52M Inact, 479M Wired, 17M Cache, 69M Buf, 2844K Free Swap: 1106M Total, 1106M Used, K Free, 100% Inuse PID USERNAME THR PRI NICE SIZE RES STATE TIME WCPU COMMAND 33 root 1 132 0 0K 12K RUN 735:36 94.58% pagedaemon 1507 root 2 44 -52 1059M 190M ll_blo ??? 1.81% fxpc 1653 root 1 101 0 62148K 1928K RUN 845.4H 0.44% jdhcpd 1061 root 1 101 0 5600K 932K RUN 32.1H 0.39% eventd 10 root 1 171 52 0K 12K RUN ??? 0.00% idle 1498 root 1 96 0 51904K 2456K select 618.0H 0.00% chassisd 13 root 1 -40 -159 0K 12K WAIT 157.1H 0.00% swi2: netisr 0 1646 root 1 4 0 118M 7564K kqread 144.9H 0.00% rpd последняя команда 33 root 1 132 0 0K 12K RUN 735:36 94.58% pagedaemon что это такое не понятно, но весь проц забирает, причем это базовый какой-то процесс, так как pid маленький Edited September 12, 2023 by pepperoni Вставить ник Quote
Умник Posted September 11, 2023 Posted September 11, 2023 1 час назад, pepperoni сказал: что это такое не понятно, но весь проц забирает, причем это базовый какой-то процесс, так как pid маленький Это следствие. У вас память кончилась. 1 час назад, pepperoni сказал: Mem: 1335M Active, 52M Inact, 479M Wired, 17M Cache, 69M Buf, 2844K Free Swap: 1106M Total, 1106M Used, K Free, 100% Inuse Вставить ник Quote
pepperoni Posted September 11, 2023 Author Posted September 11, 2023 Теперь и управление пропало даже через консоль. Только ребут? Вставить ник Quote
pepperoni Posted September 12, 2023 Author Posted September 12, 2023 Спасибо, после ребута всё в норме. Вставить ник Quote
Умник Posted September 12, 2023 Posted September 12, 2023 (edited) 1 час назад, pepperoni сказал: Спасибо, после ребута всё в норме. Мониторьте использование оперативной памяти. Аптайм системы был 1660 дней и если после перезагрузки все ОК, то возможно память все эти годы медленно утекала из-за какого-то бага в JunOS. Сколько сейчас памяти использует процесс fxpc? Edited September 12, 2023 by Умник Вставить ник Quote
pepperoni Posted September 12, 2023 Author Posted September 12, 2023 Спаcибо за рекомендации PID USERNAME THR PRI NICE SIZE RES STATE TIME WCPU COMMAND 1507 root 2 44 -52 1059M 318M select 269:43 15.04% fxpc Вставить ник Quote
