jahon55564 Posted February 21, 2022 Posted February 21, 2022 (edited) Добрый времени суток. Прошу помочь решением задачи SCE 1000. Subscribers with mappings: 39912 used out of 39999 max. 39999 max это глюк или действительно имеется ограничение linecard интерфейсе ? SCE_1000#show interface linecard 0 subscriber db counters Current values: =============== Subscribers: 39933 used out of 199999 max. Introduced/Pulled subscribers: 39933. Anonymous subscribers: 0. Subscribers with mappings: 39912 used out of 39999 max. Single non-VPN IP mappings: 42244. Non-VPN IP Range mappings: 33. IP Range over VPN mappings: 0. Single IP over VPN mappings: 0. VLAN based VPNs with subscribers: 0 used out of 2047. Subscribers with open sessions: 1067. Subscribers with TIR mappings: 0. Sessions mapped to the default subscriber: 1684. Peak values: ============ Peak number of subscribers with mappings: 39999 Peak number occurred at: 08:39:59 TJK TUE February 15 2022 Peak number cleared at: 09:04:23 TJK SUN January 9 2022 Event counters: =============== Subscriber introduced: 944523. Subscriber pulled: 0. Subscriber aged: 513000. Pull-request notifications sent: 0. Pull-request by ID notifications sent: 0. Subscriber pulled by ID: 0. State notifications sent: 0. Logout notifications sent: 0. Subscriber mapping TIR contradictions: 0. SCE_1000#>show version System version: Version 4.0.0-classic Build 316 Build time: Jun 13 2013, 21:01:05 (Change-list 731199) Software version is: Version 4.0.0-classic Build 316 Cryptography class: K9 Hardware information is: rx : 0x0079 dp : 0x1d08 tx : 0x1712 ff : 0x0077 cls : 0x1e05 cpld : 0x0025 lic : 0x0202 lic-drv : 0x02020000 lic-prm : 0x02020000 rev : G001 Bootrom : 2.1.0 L2 cache : Samsung 0.5 lic type : 4GBE_AS_2 optic mode : SM Product S/N : CAT10286DUM Product ID : Version ID : Deviation : Part number : 800-26617-03 Revision : A0 Software revision : G001 LineCard S/N : CAT10286XC4 Power Supply type : AC SML Application information is: Application file: /tffs0/release_.sli Application name: Engage SML Version 4.0.0 build 65 (Protocol Pack 40 build 38) Using Lib - PL_V4.0.0PP_B182 Using Lib - Classifier_V4.0.0_B182 Application help: Entry point of Engage Original source file: /auto/srbu-proj1-bgl/apps/users/pratgane/autoBuild/App/SML/Engage/V4.0.0/src/com/pcube/AppTemplate/Main/template_app_main.san Compilation date: Tue, March 25, 2014 at 12:54:27 Compiler version: SANc v3.20 Build 14 built on: Tue 08/04/2009 06:58:22.;SME plugin v1.1 Capacity option used: 'EngageDefaultSCE1000_2U'. Logger status: Enabled Platform: SCE1000 - 2xGBE Management agent interface version: SCE Agent 4.0.0 Build 115 Software package file: ftp://ftpserver/sce/scos-v400-b316-sce1000-classic-k9.pkg SCE_1000 uptime is 375 weeks, 3 days, 6 hours, 20 minutes, 20 seconds Edited February 22, 2022 by jahon55564 Вставить ник Quote
nixx Posted February 21, 2022 Posted February 21, 2022 нифигасе у вас запросы (сказала база и зависла). как вы туда столько напихали, а главное - зачем? )) на ваш же вопрос могу ответить просто - даташит посмотрите: Capacity and Performance Maximum Throughput 2 Gbps Number of Concurrent Subscribers Up to 40,000 Simultaneous Unidirectional Flows Up to 2,000,000 Вставить ник Quote
jahon55564 Posted February 23, 2022 Author Posted February 23, 2022 On 2/22/2022 at 2:15 AM, nixx said: нифигасе у вас запросы (сказала база и зависла). как вы туда столько напихали, а главное - зачем? )) на ваш же вопрос могу ответить просто - даташит посмотрите: Capacity and Performance Maximum Throughput 2 Gbps Number of Concurrent Subscribers Up to 40,000 Simultaneous Unidirectional Flows Up to 2,000,000 Понятно , спасибо. On 2/22/2022 at 2:15 AM, nixx said: Вставить ник Quote
snark Posted March 24, 2022 Posted March 24, 2022 В 21.02.2022 в 20:03, jahon55564 сказал: Subscribers with mappings: 39912 used out of 39999 max Вы SCE в датацентре как анти-DDoS используете что ли? Вставить ник Quote
