dancer21 Posted January 18, 2022 Posted January 18, 2022 Добрый день коллеги! Есть такая проблема никак не могу подружить свою OLT с китайской онушкой. Можете подсказать в чем проблема? Мак онухи вижу, вижу ARP онухи, вижу что она нормально зарегалась, но траффика нету. Онуха вставлена в epon0/1, аплинк g6 Вот конфиг: Current configuration: ! !version 10.1.0F build 69083 service timestamps log date service timestamps debug date logging buffered 4096 ! port-protected 1 ! ! ! ! ip default-gateway 192.168.20.1 ! ! spanning-tree mode rstp ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! aaa authentication login default local aaa authentication enable default none aaa authorization exec default local ! username admin password 0 admin ! ! epon oam-version 1 0x30 epon oam-version 2 0x21 epon oam-version 3 0x20 ! epon onu-config-template T1 cmd-sequence 001 switc cmd-sequence 002 switcport port-security dynamic maximum 6 cmd-sequence 003 epon onu all-port ctc vlan mode tag %1 cmd-sequence 004 epon onu all-port loopback detect ! epon onu-config-template T2 cmd-sequence 001 switchport port-security dinamic maximum 6 ! epon onu-config-template T3 cmd-sequence 001 switchport port-security dynamic maximum 6 cmd-sequence 002 switchport port-security mode dynamic cmd-sequence 003 epon onu all-port ctc vlan mode tag %1 cmd-sequence 004 epon onu all-port loopback detect ! epon onu-config-template user1 cmd-sequence 001 epon onu port 1 ctc vlan mode tag 301 cmd-sequence 002 epon onu port 1 ctc loopback detect ! ! !!slot 0 89 unknow CARD interface GigaEthernet0/1 ! interface GigaEthernet0/2 description TEST switchport trunk vlan-allowed 1,301 switchport trunk vlan-untagged 301 ! interface GigaEthernet0/3 ! interface GigaEthernet0/4 ! interface GigaEthernet0/5 description TEST switchport trunk vlan-allowed 1,301 switchport trunk vlan-untagged none switchport mode trunk ! interface GigaEthernet0/6 description UPLINK switchport trunk vlan-allowed 1,301 switchport trunk vlan-untagged 1 switchport pvid 1451 switchport protected 1 flow-control on ! interface EPON0/1 epon pre-config-template T3 binded-onu-llid 1-32 epon pre-config-template user1 binded-onu-llid 33-64 epon bind-onu mac e0e8.e6fa.2901 1 filter bpdu filter dhcp switchport trunk vlan-allowed 301 switchport trunk vlan-untagged none switchport pvid 1451 switchport protected 1 ! interface EPON0/1:1 epon onu port 1 ctc vlan mode tag 1451 priority 0 epon onu port 1 ctc loopback detect ! interface EPON0/2 switchport pvid 1451 switchport protected 1 ! interface EPON0/3 switchport pvid 1451 switchport protected 1 ! interface EPON0/4 switchport pvid 1451 switchport protected 1 ! !!slot end ! interface VLAN1 description managment ip address 192.168.96.198 255.255.255.0 ! interface VLAN1451 description V1451 ip address 192.168.20.222 255.255.255.0 ! ! ! vlan 1451 name V1451 ! vlan 1,1451 ! ! ! ! ! ! ! ip http server ! ! ! ! ! time-zone Moscow 3 0 ntp query-interval 1800 ntp server 192.168.96.1 ! !Pending configurations for absent linecards: ! !No configurations pending global Вставить ник Quote
passer Posted January 19, 2022 Posted January 19, 2022 В 18.01.2022 в 18:43, dancer21 сказал: interface GigaEthernet0/6 description UPLINK switchport trunk vlan-allowed 1,301 switchport trunk vlan-untagged 1 switchport pvid 1451 switchport protected 1 flow-control on ! interface EPON0/1 epon pre-config-template T3 binded-onu-llid 1-32 epon pre-config-template user1 binded-onu-llid 33-64 epon bind-onu mac e0e8.e6fa.2901 1 filter bpdu filter dhcp switchport trunk vlan-allowed 301 switchport trunk vlan-untagged none switchport pvid 1451 switchport protected 1 ! Вы порты изолировали и теперь спрашиваете почему трафик не ходит? Может пора инструкцию по настройке почитать или сисадмина нанять? Вставить ник Quote
dancer21 Posted January 19, 2022 Author Posted January 19, 2022 В 19.01.2022 в 10:30, passer сказал: Вы порты изолировали и теперь спрашиваете почему трафик не ходит? Может пора инструкцию по настройке почитать или сисадмина нанять? Ну я не знаю как мне самого себя нанять)) Мне эта эелезка впервые в руки попала, наша сетка вся на активке была, решили одно место пассивкой сделать, покурил маны, посмотрел примеры первоначальной настройки и во всех примерах была изоляция портов В 19.01.2022 в 10:30, passer сказал: Вы порты изолировали и теперь спрашиваете почему трафик не ходит? Может пора инструкцию по настройке почитать или сисадмина нанять? Тем более я патчем втыкался в g2 приход на g6 и норм трафик бегал, из под epon интерфейся нифига Вставить ник Quote
dancer21 Posted January 19, 2022 Author Posted January 19, 2022 Проблема решилась заменой онухи, изоляция портов не причем. У онухи вероятно нету dhcp клиента Вставить ник Quote
passer Posted January 19, 2022 Posted January 19, 2022 В 18.01.2022 в 18:43, dancer21 сказал: Онуха вставлена в epon0/1, аплинк g6 Ваша цитата? В приведенном конфиге изоляция портов включена для указанных интерфейсов. Я не знаю, что и как вы настраивали, но в приведенном вами выше случае трафик между epon 0/1 и g0/6 ходить не должен. В 19.01.2022 в 15:02, dancer21 сказал: У онухи вероятно нету dhcp клиента Ага В 18.01.2022 в 18:43, dancer21 сказал: interface EPON0/1 epon pre-config-template T3 binded-onu-llid 1-32 epon pre-config-template user1 binded-onu-llid 33-64 epon bind-onu mac e0e8.e6fa.2901 1 filter bpdu filter dhcp switchport trunk vlan-allowed 301 switchport trunk vlan-untagged none switchport pvid 1451 switchport protected 1 Вставить ник Quote
dancer21 Posted January 19, 2022 Author Posted January 19, 2022 В 19.01.2022 в 16:00, passer сказал: Ваша цитата? В приведенном конфиге изоляция портов включена для указанных интерфейсов. Я не знаю, что и как вы настраивали, но в приведенном вами выше случае трафик между epon 0/1 и g0/6 ходить не должен. Ага но трафик ходит, если онушка без управления Вставить ник Quote
dancer21 Posted January 20, 2022 Author Posted January 20, 2022 В 19.01.2022 в 16:00, passer сказал: Ваша цитата? В приведенном конфиге изоляция портов включена для указанных интерфейсов. Я не знаю, что и как вы настраивали, но в приведенном вами выше случае трафик между epon 0/1 и g0/6 ходить не должен. Ага убрал filter dhcp, но та онушка (которая с управлением так и не заработала) Вставить ник Quote
Iskatel_S Posted February 1, 2022 Posted February 1, 2022 Аналогичная ситуация. Есть BDCOM P3310 и GR-EP-ONU1-1 (оба сброшены в дефолт), никаких настроек не делаю, кроме "no shutdown" на Epon-портах P3310. Порты тупо не поднимаются, счётчик пакетов говорит, что пакеты ходят от базовой станции к клиентской, но в обратную сторону нет, на GR-EP-ONU1-1 тоже счётчик TX в 0 стоит. Что не так? Кстати почему-то на GR-EP-ONU1-1 невозможно зайти по telnet по admin-admin, пишет что неверный пароль, хотя в web-интерфейс с ним пускает. Вставить ник Quote
