louki2007 Posted January 18, 2022 Posted January 18, 2022 Здравствуйте. Появилось новое железо BDCOM(tm) GP3600-16B Software, Version 10.3.0D Build 89045 Пытаюсь , для начала, настроить на нем соединение с ACS-сервером . Много чего насовал в конфиг, читая интернет, но успеха нет. Не пинайте сильно, подскажите - что лишнее или чего не хватает. gpon profile onu-tcont tcont-prof-test-max-1G id 2 gpon-profile tcont-type 4 pir 1024000 ! gpon profile onu-virtual-port virtual-port-default id 1 gpon-profile encryption disable gpon-profile upstream queue 8 gpon-profile downstream queue 8 ! gpon profile onu-tcont-virtual-port-bind tvbind-default id 1 gpon-profile virtual-port 1 profile virtual-port-default tcont 1 profile tcont-default ! gpon profile onu-tcont-virtual-port-bind tcont-vport-bind-test id 2 gpon-profile virtual-port 1 profile virtual-port-test tcont 1 profile tcont-prof-test-max-1G ! gpon profile onu-flow-mapping flow-mapping-tr069-test id 5 gpon-profile entry 1 uni type eth-uni all gpon-profile entry 1 vlan 4078 gpon-profile entry 1 virtual-port 1 ! gpon profile onu-vlan ONU-VLAN-4078 id 5 gpon-profile vlan mode tag gpon-profile vlan pvid 4078 0 ! gpon profile onu-veip veip_test id 1 gpon-profile tr-069 url http://10.13.x.x:7547 gpon-profile tr-069 username **** password **** gpon-profile tr-069 vlan 4078 0 ! gpon onutype-template onutype-default-hgu gpon-onutype match ctc-onu-type HGU gpon-onutype config tcont-virtual-port-bind-profile tvbind-default gpon-onutype config flow-mapping-profile flow-mapping-default-hgu ! gpon onutype-template onutype-default gpon-onutype config tcont-virtual-port-bind-profile tvbind-default gpon-onutype config flow-mapping-profile flow-mapping-default ! gpon onu-config-template tr069test cmd-sequence 001 gpon onu tcont-virtual-port-bind-profile tcont-vport-bind-test cmd-sequence 002 gpon onu flow-mapping-profile flow-mapping-tr069-test cmd-sequence 003 gpon onu wan 1 cmd-sequence 004 gpon onu wan 1 admin-status enable cmd-sequence 005 gpon onu wan 1 connection-name TR069_WAN cmd-sequence 006 gpon onu wan 1 connection-type dhcp cmd-sequence 007 gpon onu wan 1 service-type tr069 cmd-sequence 008 gpon onu wan 1 tci vlan 4078 cmd-sequence 009 gpon onu veip 1 veip-profile veip_test cmd-sequence 010 gpon onu ip-host 1 vlan-profile ONU-VLAN-4078 cmd-sequence 011 gpon onu ip-host 1 option dhcp cmd-sequence 012 gpon onu uni 1 vlan-profile ONU-VLAN-4078 ! interface GPON0/1 gpon pre-config-template tr069test bind-onuid 3 gpon bind-onutype onutype-default-hgu precedence 127 gpon bind-onutype onutype-default precedence 128 gpon bind-onu sn HWTC:EC653D32 3 gpon fec-tx filter dhcp switchport trunk vlan-allowed 4077-4078 switchport mode trunk switchport protected 1 storm-control broadcast threshold 5 storm-control multicast threshold 5 storm-control unicast threshold 5 pppoe intermediate-agent interface GPON0/1:3 gpon onu model-id 245H gpon onu tcont-virtual-port-bind-profile tcont-vport-bind-test gpon onu flow-mapping-profile flow-mapping-tr069-test gpon onu virtual-port 1 gem-port 258 gpon onu tcont 1 alloc-id 258 gpon onu uni 1 vlan-profile ONU-VLAN-4078 gpon onu veip 1 veip-profile veip_test gpon onu ip-host 1 vlan-profile ONU-VLAN-4078 gpon onu ip-host 1 option dhcp ! Ону - Huawei HG8245H Вставить ник Quote
louki2007 Posted January 24, 2022 Author Posted January 24, 2022 Поскольку все тихо, попробую переформулировать вопрос попроще. А реализована ли вообще поддержка TR-069 подключения к ACS серверу на этой железке? Может быть у кого -то есть рабочий вариант конфига? Вставить ник Quote
Nikita Devyatyarov Posted January 24, 2022 Posted January 24, 2022 Добрый день! На ОНУ реализована передача tr069 сервисов до ОНУ, но лично я с хуавей ОНУ не тестировал, да и вариантов хуавеевских прошивок крайне много, про все сказать сложно Попробуйте подобные настройки, для подтверждения зайдите на веб ону и проверьте применились ли настройки. gpon profile onu-veip veip-test id 1 gpon-profile mgmt bind ip-host 1 gpon-profile tr-069 url http://***** gpon-profile tr-069 username USER password PASSWORD gpon profile onu-vlan test gpon-profile vlan mode trunk gpon-profile vlan pvid 111 0 interface GPON0/2:4 gpon onu veip 1 veip-profile veip-test gpon onu ip-host 1 vlan-profile test gpon onu ip-host 1 address static 10.10.10.10 255.255.255.0 10.10.10.1 Вставить ник Quote
