Добрый день.
rfw - debian8
core  - debian7
На rfw логи при запуске
Jul 13 14:43:08  f3944740  System version:  5.3-006-update1-debian_jessie_x64
Jul 13 14:43:08  Info  : f3944740 FileAppender: Using '/netup/utm5/log/rfw.log' file
Jul 13 14:43:08  Notice: f3944740 UTM5 RFW: Version 5.3-006-update1-debian_jessie_x64 starting.
Jul 13 14:43:08 ?Debug : f3944740 StreamConnectionManager: registering message handlers:
Jul 13 14:43:08 ?Debug : f3944740 StreamConnectionManager: ID <0x4003> handler <0x0x1c14b30>
Jul 13 14:43:08 ?Debug : f3944740 StreamConnectionManager: ID <0x4000> handler <0x0x1c14b30>
Jul 13 14:43:08 ?Debug : f3944740 StreamConnectionManager: ID <0x4001> handler <0x0x1c14b30>
Jul 13 14:43:08 ?Debug : f3944740 StreamConnectionManager: ID <0x4004> handler <0x0x1c14b30>
Jul 13 14:43:08 ?Debug : f3944740 StreamConnectionManager: ID <0x4002> handler <0x0x1c14b30>
Jul 13 14:43:08 ?Debug : f3944740 StreamConnectionManager: Socket connected to: host <10.50.0.3> port <12758>
Jul 13 14:43:08  Info  : ef435700 StreamConnection: Connection thread started. Peer [10.50.0.3]:12758
Jul 13 14:43:08  ERROR : ef435700 StreamConnection: SSL_connect failed: error:00000001:lib(0):func(0):reason(1)
Jul 13 14:43:08  ERROR : ef435700 StreamConnection: Unable to maintain connection. Error code <22>
Jul 13 14:43:08 ?Debug : ef435700 StreamConnection: closing connection [2]
Jul 13 14:43:08  Info  : ef435700 StreamConnection: Connection from 10.50.0.3/12758 closed
Jul 13 14:43:09  ERROR : f3944740 StreamConnectionManager: set_auth: connection closed
Jul 13 14:43:09 *CRIT  : f3944740 UTM5 RFW: Unable to login, check you configuration file settings
Jul 13 14:43:09  Info  : f3944740 RFW Config: Pid file found: /var/run/utm5_rfw.pid; Overwriting
На core логи в этот момент
140611340924672:error:1408A0C1:SSL routines:SSL3_GET_CLIENT_HELLO:no shared cipher:s3_srvr.c:1440:
Jul 13 14:43:08  ERROR : a106f700 StreamConnection: SSL_accept failed: error:00000001:lib(0):func(0):reason(1)
Jul 13 14:43:08  ERROR : a106f700 StreamConnection: Unable to maintain connection. Error code <22>
Что может быть?
ssl не такой ? Ну или нет доступа от rfw до core хоста, глупо нет маршрута или firewall, но скорее вот это
 Проверить в rfw.cfg логины-пароли, описать в коре этот firewall, ну и вот это посмотреть там
## rfw_ssl_type        ##  Description: SSL connection type. If 'none' is set, the connection is       ##   unencrypted.                                                               ##  Possible values: tls1, ssl3, none                                           ##  Default value: none                                                         #rfw_ssl_type=none
В rfw.cfg rfw_ssl_type не прописан, прописывал жестко rfw_ssl_type=none. Логины пароли проверял. В ютм админ firewall создан, параметры его прописаны в  rfw.cfg. Логин пароль верный. Маршруты есть....
 Надеюсь что в системных пользователях этого юзера не забыли, с поролем и ип-сетями ?
 Ну и если поддержка утм оплачена, то их попинать.
Нее, все настроил. Нет поддержки(( Проблема где то  в SSL это 100% . Только я не пойму имеено в чем. То что разные версии на машинах что ли....
