добрый день  настраиваю  caps-man в итоге клиент когда подключется в wifi  не получает ip  клиенты должны бsть в 19 vlan
на сервере caps-man
caps-man export
/caps-man channel
add band=2ghz-b/g/n name="channel_2.4 Ghz_1" tx-power=28
add band=2ghz-b/g/n name="channel2.4 Ghz_6" tx-power=28
add band=5ghz-a/n/ac extension-channel=Ce name="channel_ 5 Ghz_36" tx-power=28
add band=5ghz-a/n/ac extension-channel=Ce name="channel_ 5 Ghz_44" tx-power=28
/caps-man datapath
add client-to-client-forwarding=yes local-forwarding=no name=datapath1
/caps-man interface
add disabled=no mac-address=CC:2D:E0:92:20:48 master-interface=none name=cap1 radio-mac=CC:2D:E0:92:20:48 radio-name=CC2DE0922048
add disabled=no mac-address=CC:2D:E0:92:20:49 master-interface=none name=cap2 radio-mac=CC:2D:E0:92:20:49 radio-name=CC2DE0922049
add disabled=no mac-address=CC:2D:E0:92:20:6C master-interface=none name=cap3 radio-mac=CC:2D:E0:92:20:6C radio-name=CC2DE092206C
add disabled=no mac-address=CC:2D:E0:92:20:6D master-interface=none name=cap4 radio-mac=CC:2D:E0:92:20:6D radio-name=CC2DE092206D
/caps-man security
add authentication-types=wpa2-psk encryption=aes-ccm group-encryption=aes-ccm group-key-update=1h name=security1 passphrase=123qweasd
/caps-man configuration
add channel="channel_ 5 Ghz_36" country=russia datapath=datapath1 datapath.vlan-id=19 datapath.vlan-mode=use-tag mode=ap name=cfg_5G rx-chains=0,1,2,3 security=security1 ssid="Mikrotik caps 5G" tx-chains=0,1,2,3
add channel="channel_2.4 Ghz_1" country=russia datapath=datapath1 datapath.vlan-id=19 datapath.vlan-mode=use-tag mode=ap name=cfg_2.4G rx-chains=0,1,2,3 security=security1 ssid="Mikrotik caps" tx-chains=0,1,2
/caps-man access-list
add action=reject allow-signal-out-of-range=10s disabled=no interface=any signal-range=-120..-80 ssid-regexp=""
add action=accept allow-signal-out-of-range=10s disabled=no interface=any signal-range=-80..120 ssid-regexp=""
/caps-man manager
set enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=an,ac master-configuration=cfg_5G
add action=create-dynamic-enabled hw-supported-modes=b,gn master-configuration=cfg_2.4G
/interface> export
add name=bridge_vlan
/interface ethernet
set [ find default-name=ether1 ] comment=Wan mac-address=00:12:36:15:17:01 speed=100Mbps
set [ find default-name=ether2 ] comment=LAN mac-address=00:12:36:15:17:02 speed=100Mbps
set [ find default-name=ether3 ] mac-address=00:12:36:15:17:03 speed=100Mbps
set [ find default-name=ether4 ] mac-address=00:12:36:15:17:04 speed=100Mbps
set [ find default-name=ether5 ] mac-address=00:12:36:15:17:05 speed=100Mbps
set [ find default-name=ether6 ] mac-address=00:12:36:15:17:06 speed=100Mbps
set [ find default-name=ether7 ] mac-address=00:12:36:15:17:07 speed=100Mbps
set [ find default-name=ether8 ] mac-address=00:12:36:15:17:08 speed=100Mbps
/interface vlan
add comment=WIFI interface=bridge_vlan name=vlan19 vlan-id=19
/interface bridge port
add bridge=bridge_vlan interface=ether3
add bridge=bridge_vlan interface=ether2
add bridge=bridge_vlan interface=ether4
add bridge=bridge_vlan interface=cap1
add bridge=bridge_vlan interface=cap2
add bridge=bridge_vlan interface=cap3
add bridge=bridge_vlan interface=cap4
/interface vrrp
add interface=vlan19 interval=10s name=vlan19_vrrp_master priority=254 vrid=19
/ip dhcp-server
add address-pool=vlan19 disabled=no interface=vlan19_vrrp_master name=vlan19
/ip dhcp-server network
add address=10.0.19.0/24 dns-server=10.0.19.1 gateway=10.0.19.1
на  точке доступа
# model = RBcAPGi-5acD2nD
# serial number = BECD08A571C3
/interface bridge
add admin-mac=CC:2D:E0:92:20:5A auto-mac=no comment=defconf name=bridgeLocal
/interface wireless
# managed by CAPsMAN
# channel: 2447/20-Ce/gn(20dBm), SSID: Mikrotik caps, CAPsMAN forwarding
set [ find default-name=wlan1 ] ssid=MikroTik
# channel: 5765/20-Ce/ac(20dBm), SSID: Mikrotik caps 5G, CAPsMAN forwarding
set [ find default-name=wlan2 ] ssid=MikroTik
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip hotspot profile
set [ find default=yes ] html-directory=flash/hotspot
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
/interface wireless cap
set bridge=bridgeLocal caps-man-addresses=10.0.19.1 discovery-interfaces=bridgeLocal enabled=yes interfaces=wlan1,wlan2
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=bridgeLocal
/system clock
set time-zone-name=Europe/Moscow
/system identity
set name=caps3
VLAN прокидывают между двумя управляемыми свичами у Вас
CAPsMAN forwarding
То есть трафик разруливает сам CAPsMAN,  между чем и чем он должен прокладывать vlan?
Cap интерфейсы уже прокинуты до роутера.
За настройку WIFI Вам двойка. Это ж надо вывалить мощность на 28.
Вот статья, с которой нужно было ознакомиться до покупки оборудования. https://habr.com/ru/article/456918/
Edited by Корпич
