Добрый день, коллеги
подскажите как в таком окружении посмотреть текущую утилизацию шейпера?
03.16.08.S
#show subscriber session username 100.64.4.248
Type: DHCPv4, UID: 2883, State: authen, Identity: 100.64.4.248
IPv4 Address: 100.64.4.248
Session Up-time: 08:14:30, Last Changed: 08:14:30
Switch-ID: 20898104
Policy information:
  Authentication status: authen
  Active services associated with session:
    name "IPoE10Mbps1SLA", applied before account logon
  Rules, actions and conditions executed:
    subscriber rule-map IPoE-SUBSCRIBER-CONTROL
      condition always event session-restart
        10 authorize aaa list IPoE-AAA identifier source-ip-address
    subscriber rule-map default-internal-rule
      condition always event service-start
        1 service-policy type service identifier service-name
Classifiers:
Class-id    Dir   Packets    Bytes                  Pri.  Definition
0           In    920627     231996802              0    Match Any
1           Out   1762368    2205745378             0    Match Any
Template Id : 10
Features:
Idle Timeout:
Class-id   Dir  Timeout value   Idle-Time            Source
1          Out  43300           00:00:00             Peruser
Accounting:
Class-id   Dir  Packets    Bytes                 Source
0          In   920625     211742640             Peruser
0          In   920625     211742640             IPoE10Mbps1SLA
1          Out  1670470    2031493289            Peruser
1          Out  1670470    2031493289            IPoE10Mbps1SLA
Policing:
Class-id   Dir  Avg. Rate   Normal Burst  Excess Burst Source
0          In   10485500    1966080       3932160      IPoE10Mbps1SLA
1          Out  10485500    1966080       3932160      IPoE10Mbps1SLA
Configuration Sources:
Type  Active Time  AAA Service ID  Name
USR   08:14:30     -               Peruser
SVC   08:14:30     1560283644      IPoE10Mbps1SLA
INT   08:14:30     -               TenGigabitEthernet0/0/1.502
Сервисы на CISCO залетают через RADIUS
Attributes:
  Acct-Interim-Interval=240
  Framed-IP-Address=100.64.4.248
  Idle-Timeout=43300
  cisco-avpair=subscriber:accounting-list=IPoE-AAA
  cisco-SSG-Account-Info=AIPoE10Mbps1SLA
Acct-Interim-Interval=900
Idle-Timeout=3600
cisco-SSG-Service-Info=QU;;1048576;;196608;;393216;;D;;1048576;;196608;;393216
Сабы терминируются так:
interface TenGigabitEthernet0/0/1.502
 description "== ACCESS SUBSCRIBERS INTERFACE SVLAN:502 =="
 encapsulation dot1Q 502 second-dot1q any
 ip dhcp relay information option server-id-override
 ip dhcp relay information option-insert
 ip dhcp relay information policy-action replace
 ip unnumbered Loopback0
 ip helper-address 10.1.1.1
 ip nat inside
 ip flow monitor NETFLOW-TO-COLLECTOR input
 no ip route-cache same-interface
 arp timeout 43200
 service-policy type control IPoE-SUBSCRIBER-CONTROL
 ip subscriber l2-connected
  initiator unclassified mac-address
  initiator dhcp
end
