Микротик с последней прошивкой
на ether1 приходят 2 vlan
на vlan2 прописана подсеть 1.1.1.146/30
на ether4 прописана подсеть 1.1.1.149/30
1.1.1.150 - клиент с freeswitch висит на ether4
2.2.2.164 - софтсвич провайдера
SIP ALG отключен
2.2.2.164 -посылает OPTIONS
1.1.1.150 получает OPTIONS от 1.1.1.149
Как я понимаю роутер подставляет вместо 2.2.2.164 1.1.1.149
Как победить это ......
Вот то что на vlan2
No.     Time        Source                Destination           Protocol Length Info
      1 0.000000    2.2.2.164        1.1.1.150         SIP      477    Request: OPTIONS sip:1.1.1.150:5060 |
Frame 1: 477 bytes on wire (3816 bits), 477 bytes captured (3816 bits)
    Encapsulation type: Ethernet (1)
    Arrival Time: Dec  9, 2018 10:03:41.353778000 Багдадское время (зима)
    [Time shift for this packet: 0.000000000 seconds]
    Epoch Time: 1544339021.353778000 seconds
    [Time delta from previous captured frame: 0.000000000 seconds]
    [Time delta from previous displayed frame: 0.000000000 seconds]
    [Time since reference or first frame: 0.000000000 seconds]
    Frame Number: 1
    Frame Length: 477 bytes (3816 bits)
    Capture Length: 477 bytes (3816 bits)
    [Frame is marked: False]
    [Frame is ignored: False]
    [Protocols in frame: eth:ethertype:ip:udp:sip]
    [Number of per-protocol-data: 1]
    [Session Initiation Protocol, key 6]
    [Coloring Rule Name: UDP]
    [Coloring Rule String: udp]
Ethernet II, Src: Cisco_b4:92:80 (00:1c:b0:b4:92:80), Dst: Routerbo_b6:37:04 (d4:ca:6d:b6:37:04)
    Destination: Routerbo_b6:37:04 (d4:ca:6d:b6:37:04)
        Address: Routerbo_b6:37:04 (d4:ca:6d:b6:37:04)
        .... ..0. .... .... .... .... = LG bit: Globally unique address (factory default)
        .... ...0 .... .... .... .... = IG bit: Individual address (unicast)
    Source: Cisco_b4:92:80 (00:1c:b0:b4:92:80)
        Address: Cisco_b4:92:80 (00:1c:b0:b4:92:80)
    Type: IP (0x0800)
Internet Protocol Version 4, Src: 2.2.2.164 (2.2.2.164), Dst: 1.1.1.150 (1.1.1.150)
    Version: 4
    Header Length: 20 bytes
    Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00: Not-ECT (Not ECN-Capable Transport))
        0000 00.. = Differentiated Services Codepoint: Default (0x00)
        .... ..00 = Explicit Congestion Notification: Not-ECT (Not ECN-Capable Transport) (0x00)
    Total Length: 463
    Identification: 0xec2e (60462)
    Flags: 0x00
        0... .... = Reserved bit: Not set
        .0.. .... = Don't fragment: Not set
        ..0. .... = More fragments: Not set
    Fragment offset: 0
    Time to live: 60
    Protocol: UDP (17)
    Header checksum: 0xa333 [validation disabled]
        [Good: False]
        [Bad: False]
    Source: 2.2.2.164 (2.2.2.164)
    Destination: 1.1.1.150 (1.1.1.150)
    [Source GeoIP: Unknown]
    [Destination GeoIP: Unknown]
User Datagram Protocol, Src Port: 5060 (5060), Dst Port: 5060 (5060)
    Source Port: 5060 (5060)
    Destination Port: 5060 (5060)
    Length: 443
    Checksum: 0x5cd1 [validation disabled]
        [Good Checksum: False]
        [Bad Checksum: False]
    [Stream index: 0]
Session Initiation Protocol (OPTIONS)
    Request-Line: OPTIONS sip:1.1.1.150:5060 SIP/2.0
        Method: OPTIONS
        Request-URI: sip:1.1.1.150:5060
            Request-URI Host Part: 1.1.1.150
            Request-URI Host Port: 5060
        [Resent Packet: False]
    Message Header
        Via: SIP/2.0/UDP 2.2.2.164:5060;branch=z9hG4bK4ztcoahgeacttbo6h3ev3tchz;Role=3;Hpt=8e48_16;X-HwDim=4
            Transport: UDP
            Sent-by Address: 2.2.2.164
            Sent-by port: 5060
            Branch: z9hG4bK4ztcoahgeacttbo6h3ev3tchz
            Role=3
            Hpt=8e48_16
            X-HwDim=4
        Record-Route: <sip:2.2.2.164:5060;transport=udp;lr;Hpt=8e48_16;CxtId=4;TRC=ffffffff-ffffffff>
            Record-Route URI: sip:2.2.2.164:5060;transport=udp;lr;Hpt=8e48_16;CxtId=4;TRC=ffffffff-ffffffff
                Record-Route Host Part: 2.2.2.164
                Record-Route Host Port: 5060
                Record-Route URI parameter: transport=udp
                Record-Route URI parameter: lr
                Record-Route URI parameter: Hpt=8e48_16
                Record-Route URI parameter: CxtId=4
                Record-Route URI parameter: TRC=ffffffff-ffffffff
        Call-ID: isbcqrqacuf1nfuquv78a41qnufnvqu9crau@SoftX3000
            SIP from address: sip:1.1.1.150:5060
                SIP from address Host Part: 1.1.1.150
                SIP from address Host Port: 5060
            SIP from tag: nb1qbctf
        To: <sip:1.1.1.150:5060>
            SIP to address: sip:1.1.1.150:5060
                SIP to address Host Part: 1.1.1.150
                SIP to address Host Port: 5060
        CSeq: 1 OPTIONS
            Sequence Number: 1
            Method: OPTIONS
        Max-Forwards: 69
        Content-Length: 0
Вот то что на ether4
      1 0.000000    1.1.1.149         1.1.1.150         SIP      477    Request: OPTIONS sip:1.1.1.150:5060 |
    Arrival Time: Dec  9, 2018 10:02:56.849730000 Багдадское время (зима)
    Epoch Time: 1544338976.849730000 seconds
    Frame Number: 1
Ethernet II, Src: Routerbo_b6:37:07 (d4:ca:6d:b6:37:07), Dst: AsustekC_48:23:41 (08:60:6e:48:23:41)
    Destination: AsustekC_48:23:41 (08:60:6e:48:23:41)
        Address: AsustekC_48:23:41 (08:60:6e:48:23:41)
    Source: Routerbo_b6:37:07 (d4:ca:6d:b6:37:07)
        Address: Routerbo_b6:37:07 (d4:ca:6d:b6:37:07)
    Type: IP (0x0800)
Internet Protocol Version 4, Src: 1.1.1.149 (1.1.1.149), Dst: 1.1.1.150 (1.1.1.150)
    Version: 4
    Total Length: 463
    Identification: 0x20ff (8447)
    Flags: 0x00
    Fragment offset: 0
    Time to live: 59
    Protocol: UDP (17)
    Header checksum: 0xf253 [validation disabled]
        [Good: False]
        [Bad: False]
    Source: 1.1.1.149 (1.1.1.149)
    Length: 443
    Checksum: 0x6a08 [validation disabled]
    [Stream index: 0]
        Method: OPTIONS
    Message Header
        Via: SIP/2.0/UDP 2.2.2.164:5060;branch=z9hG4bK8am5rv17871ee49ml1a4551se;Role=3;Hpt=8e58_16;X-HwDim=4
            Transport: UDP
            Sent-by port: 5060
            Branch: z9hG4bK8am5rv17871ee49ml1a4551se
            Role=3
            Hpt=8e58_16
            X-HwDim=4
        Record-Route: <sip:2.2.2.164:5060;transport=udp;lr;Hpt=8e58_16;CxtId=4;TRC=ffffffff-ffffffff>
            Record-Route URI: sip:2.2.2.164:5060;transport=udp;lr;Hpt=8e58_16;CxtId=4;TRC=ffffffff-ffffffff
                Record-Route URI parameter: Hpt=8e58_16
        Call-ID: isbcb7f4vbb78qq8nftuqi8aaqc9rc4rfa48@SoftX3000
            SIP from tag: 1ubq188v
        CSeq: 1 OPTIONS
            Sequence Number: 1
            Method: OPTIONS
        Max-Forwards: 69
        Content-Length: 0
SIP ALG отключен
src-nat(маскарад) на ether4 уберите
на ether4 нет маскарадинга, есть на ether1 где vlanы
но я пока включил свой софтсвич через упр. коммутатор и простой проводной роутер асус,
всё там отключено и запросы options пропали. )
может у них там ещё привязка к маку.
у себя такого не наблюдаю
конфиг можете показать ?
