boot system flash:/c181x-advipservicesk9-mz.124-15.T17.bin
ip dhcp pool local
   network 192.168.30.0 255.255.255.0
   default-router 192.168.30.1
   dns-server 172.17.1.30 8.8.8.8
ip dhcp pool ats
   network 192.168.90.0 255.255.255.0
   default-router 192.168.90.1
   dns-server 8.8.8.8
vtp mode transparent
crypto keyring D-VTI
  pre-shared-key address 0.0.0.0 0.0.0.0 key xxx
crypto isakmp policy 113
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto ipsec transform-set D-VTY esp-aes esp-sha-hmac
crypto ipsec profile D-VTY
 set transform-set D-VTY
archive
 log config
  hidekeys
vlan 90,99-100,3120
ip ssh maxstartups 2
interface Loopback0
 ip address 10.2.2.30 255.255.255.255
interface Tunnel2
 bandwidth 90
 ip unnumbered Loopback0
 ip tcp adjust-mss 1448
 tunnel source FastEthernet0.1433
 tunnel destination xxx
 tunnel mode ipsec ipv4
 tunnel protection ipsec profile D-VTY
interface FastEthernet0
 no ip address
 speed 100
 full-duplex
interface FastEthernet0.1433
 description WAN-INTERNET
 encapsulation dot1Q 1433
 ip address nnn
 ip nat outside
 ip virtual-reassembly
interface FastEthernet0.3120
 encapsulation dot1Q 3120
 ip address dhcp
 ip nat outside
interface FastEthernet1
 no ip address
 duplex auto
 speed auto
interface FastEthernet2
 switchport access vlan 100
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
 switchport access vlan 99
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan99
 ip address 192.168.90.1 255.255.255.0
 ip nat inside
interface Vlan100
 ip address 192.168.30.1 255.255.255.0
 ip nat inside
interface Async1
 no ip address
 encapsulation slip
router eigrp 1
 passive-interface default
 no passive-interface Tunnel2
 network 10.2.2.30 0.0.0.0
 auto-summary
no ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 nnn
ip route 10.0.0.0 255.255.255.0 FastEthernet0.3120
ip http server
no ip http secure-server
ip nat inside source list 3 interface FastEthernet0.1433 overload
ip nat inside source list 100 interface FastEthernet0.3120 overload
access-list 1 permit nnn
access-list 3 deny   192.168.90.0 0.0.0.255
access-list 3 permit 192.168.30.0 0.0.0.255
access-list 100 permit ip 192.168.90.0 0.0.0.255 any
Провайдер подаёт мне две услуги по транку. Влан 1433 интернет и влан 3120 воип.
На рутере грубо говоря 10 инт.
Cisco 1811
Принимаю на рутер:
int fa0.1433
IP address xxx
IP Nat outside
Int fa0.3120
no IP address
vtp version 2
Инет настроил по 1433. Робит.
int fa6
switchport access vlan 3120
Порт смотрит в Ван порт АТС, который должен по dhcp словить айпи от провайдера и подсоединить воип транки.
По dhcp он ничего не получает.
Но когда я прописываю на 6 интерфейса акссесс, то выдаёт ошибку.
#switchport access vlan 3120
% Warning: port will be inactive in non-ethernet VLAN
Не знаю то ли из-за нее не ловит, то ли по какой другой причине. На TP-Link все отлично работает. Не знаю уже куда копать и что делать.
После выдачи ошибки:
sh int fa6 switchport
Switchport: Enabled
Administrative Mode: static access
Operational Mode: static access
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: native
Negotiation of Trunking: Disabled
Access Mode VLAN: 3120 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 3120
Protected: false
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
А если сделать так, то:
#shut
#no shut
#do sh int fa6 switchport
Switchport: Enabled
Access Mode VLAN: 3120 (VLAN3120)
Protected: false
Voice VLAN: none
Access mode vlan в первом случае Disabled, а во втором случае уже нет, но от этого ни холодно ни жарко.
После этого я попробовал по другому. Словил по DHCP адрес на влане 3120, поставил АТС в свой влан и попытался сделать трансляцию. Не знаю правильно или нет. Номера телефонов должны регистрироваться по воип-транку на айпи 10.0.0.20, но не регистрируются.
Я получаю от провайдера айпи 10.4.52.9 . Пинг с АТСки на 10.4.52.10 идёт. На 10.0.0.20 не идёт, хотя они вполне могли исмп заблочить.
Собственно вопрос в том правильно ли я настроил или где-то накосячил?
sh ip nat translations | include 192.168.90
udp 10.4.52.9:1024        192.168.90.2:5060     10.0.0.20:5060        10.0.0.20:5060
udp 10.4.52.9:35404       192.168.90.2:35404    8.8.8.8:53            8.8.8.8:53
udp 10.4.52.9:52984       192.168.90.2:52984    8.8.8.8:53            8.8.8.8:53
udp 10.4.52.9:53759       192.168.90.2:53759    8.8.8.8:53            8.8.8.8:53
udp 10.4.52.9:55475       192.168.90.2:55475    8.8.8.8:53            8.8.8.8:53
sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.0.0.20               0   Incomplete           ARPA
Internet  10.4.52.1              35   001e.f7f7.11c0    ARPA   FastEthernet0.3120
Internet  10.4.52.9               -   0026.cb26.7bb0    ARPA   FastEthernet0.3120
Internet  10.4.52.10             11   000b.82c4.a660  ARPA   FastEthernet0.3120
Edited by Endspiel
Fa0 и Fa1 - роутинговые порты, 2-9 свитч. Они между собой просто так не связаны.
И конструкция вида:
int f0.3120
 encapsulation dot1q 3120
int vlan 3120
желаемого эффекта их объединения не даст, это разные виланы
поэтому, если хочется, нужно городить бридж.
ЗЫ: ну и чтобы вилан в системе встроенного свича появился, нужно его создать в режиме vlan database
Еще проще содать провайдерские виланы, воткнуть его в Fa2-9 в режиме транка. Линк с АТС сунуть аксесом в нужный вилан.
3 минуты назад, ShyLion сказал:
И конструкция вида:
int f0.3120
int vlan 3120
#vlan database
#vlan 3120
% Invalid input detected at '^' marker.
#vlan ?
  <1-1005>  ISL VLAN index
У меня vtp 2 версии.
vtp должен быть в transparent режиме, но за вашу конкретную железку не ручаюсь, по моему у вас какая-то древность.
просите провайдера поменять виланы на ниже 1000, вполне могут пойти на встречу, если не конченые м.ки
12 минут назад, ShyLion сказал:
Если не в режиме vlan database создавать, то можно. К сожалению с провайдером все глухо.
#interface vlan ?
  <1-4094>  Vlan interface number
А если натить? Я сейчас подумываю натить мою вланку через айпи, который получил от их влана по дхсп, но все равно странно как-то. Соседний со мной айпишник пингуется, а нужный для регистрации воип-транка нет.
interface vlan xxx
Это не создание вилана! Это настройка его SVI части. Т.е. это виртуальный интерфейс на внутреннем соединении "роутера" со "свичем".
На самом "свиче" вилан создается отдельно. Так сделано потому что "свич" может получать список виланов по VTP с другого свича.
Покажb уже show ver.
6 минут назад, ShyLion сказал:
interface vlan xxx
#sh ver
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(15)T17, RELEASE SOFTWARE (fc2)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 24-Jan-12 12:46 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH13, RELEASE SOFTWARE (fc1)
kz.alke-group.com uptime is 1 day, 21 hours, 5 minutes
System returned to ROM by Reload Command at 00:01:46 UTC Fri Apr 4 2003
System image file is "flash:/c181x-advipservicesk9-mz.124-15.T17.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 1811 (MPC8500) processor (revision 0x400) with 118784K/12288K bytes of memory.
Processor board ID FHK133972PF, with hardware revision 0000
10 FastEthernet interfaces
1 Serial interface
1 terminal line
63808K bytes of ATA CompactFlash (Read/Write)
Configuration register is 0x2102
Вот у нас есть:
talakan-hotel-1811#show ver
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version 15.1(4)M12a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 04-Oct-16 02:58 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH9, RELEASE SOFTWARE (fc1)
talakan-hotel-1811 uptime is 5 days, 16 hours, 45 minutes
System returned to ROM by power-on
System restarted at 00:52:11 KYA Sat Aug 4 2018
System image file is "flash:c181x-adventerprisek9-mz.151-4.M12a.bin"
Last reload type: Normal Reload
export@cisco.com.
Cisco 1811 (MPC8500) processor (revision 0x400) with 354304K/38912K bytes of memory.
Processor board ID FHK123628KC, with hardware revision 0000
1 Serial interface
1 terminal line
1 Virtual Private Network (VPN) Module
62720K bytes of ATA CompactFlash (Read/Write)
Виланы создаются так:
talakan-hotel-1811(config)#vlan 3333
talakan-hotel-1811(config-vlan)#exit
% Failed to create VLANs 3333
Extended VLAN(s) not allowed in current VTP mode.
%Failed to commit extended VLAN(s) changes.
talakan-hotel-1811(config)#vtp mode transparent
Setting device to VTP TRANSPARENT mode.
talakan-hotel-1811(config-vlan)#name test
talakan-hotel-1811(config-vlan)#^Z
talakan-hotel-1811#
7 минут назад, ShyLion сказал:
Вот у нас есть:
export@cisco.com.
1 Serial interface
1 terminal line
talakan-hotel-1811#
Так я уже создавал, но сделал еще раз.
#vlan 3120
#exit
#int vlan 3120
#bridge-group 1
#int fastEthernet 0.3120
#no ip address
#bridge-group 1
#exit
#int fa6
Так надо?
Попробуй без бриджа.
Воткни провайдера в порт Fa2
vlan 1433
 name Inet
vlan 3120
 name VoIP
interface Vlan1433
 ip address nnn
 ip nat outside
interface Vlan3120
 ip address dhcp
interface Fa2
 descr Provider uplink
 switchport trunk encap dot1q
 switchport mode trunk
 switchport trunk allowed vlan 1433,3120
interface Fa6
 descr ATS
Таким образом твоя АТС попадет в вилан провайдера, плюс у тебя будет роутинговый интерфейс в нем-же.
