Добрый день!
Кто нибудь может подсказать, как можно получить информацию по Read/Write community, имея полный доступ к железке, если эти комюнити в зашифрованном виде
К примеру:
dis snmp-agent community
   Community name:CE$7@!87<[+Q=^Q`MAF4<<"TX$_S#6.NM(0=0\)*5WU!
       Group name:CE$7@!87<[+Q=^Q`MAF4<<"TX$_S#6.NM(0=0\)*5WU!
       Acl:2002
       Storage-type: nonVolatile
   Community name:%50A@NK/aF*,YWX*NZ55OL"TX$_S#6.NM(0=0\)*5WU!
       Group name:%50A@NK/aF*,YWX*NZ55OL"TX$_S#6.NM(0=0\)*5WU!
       Acl:2002
попробуйте такую команду undo system snmp-user password security
Function
The system snmp-user password security command is used to enable the Simple Network Management Protocol (SNMP) password security function. To check the complexity of SNMPv1 and SNMPv2 community names and SNMPv3 authentication password and encryption password or lock IP addresses when the SNMP authentication fails, run this command. The function is enabled by default.
The undo system snmp-user password security command is used to disable the SNMP password security function.
