Коллеги, добрый день. Есть Juniper MX5, принимает две таблицы Full View. При поднятии сессии bgp в момент загрузки таблицы в логах следующие ошибки:
rpd[1352]: RPD_KRT_Q_RETRIES: Route Update: No buffer space available
/kernel: rt_pfe_veto: Too many delayed route/nexthop unrefs. Op 2, rtsm_id 5, msg type 2
В таблицу префиксы загружаются очень медленно. В чём может быть проблема?
1 час назад, sda_1 сказал:
добрый день
видимо память забита
покажите
show chassis routing-engine
show krt state
show krt queue
По поводу памяти, тоже посещала такая мысль.
Routing Engine status:
    Temperature                 43 degrees C / 109 degrees F
    CPU temperature             57 degrees C / 134 degrees F
    DRAM                      2048 MB
    Memory utilization          83 percent
    CPU utilization:
      User                       4 percent
      Background                 0 percent
      Kernel                     7 percent
      Interrupt                  1 percent
      Idle                      88 percent
    Model                          RE-MX5-T
    Start time                     2018-06-27 04:31:21 EET
    Uptime                         1 day, 9 hours, 11 minutes, 39 seconds
    Last reboot reason             Router rebooted after a normal shutdown.
    Load averages:                 1 minute   5 minute  15 minute
                                       0.02       0.06       0.07
show krt state
General state:
        Options: <>
        Install job is not running
        Number of operations queued: 0
                Routing table adds: 0
                Interface routes: 0
                High pri multicast   Adds/Changes: 0
                Indirect Next Hop    Adds/Changes: 0       Deletes: 0
                MPLS        Adds: 0       Changes: 0
                High pri    Adds: 0       Changes: 0       Deletes: 0
                Normal pri Indirects: 0
                Normal pri  Adds: 0       Changes: 0       Deletes: 0
                Routing Table deletes: 0
        Number of operations deferred: 0
        Number of operations canceled: 0
        Time until next queue run: 0
        Routes learned from kernel: 25
Routing socket lossage:
        Time until next scan: 32
show krt queue
Routing table add queue: 0 queued
Interface add/delete/change queue: 0 queued
High-priority multicast add/change: 0 queued
Indirect next hop add/change: 0 queued
MPLS add queue: 0 queued
Indirect next hop delete: 0 queued
High-priority deletion queue: 0 queued
MPLS change queue: 0 queued
High-priority change queue: 0 queued
High-priority add queue: 0 queued
Normal-priority indirect next hop queue: 0 queued
Normal-priority deletion queue: 0 queued
Normal-priority composite next hop deletion queue: 0 queued
Normal-priority change queue: 0 queued
Normal-priority add queue: 0 queued
Routing table delete queue: 0 queued
Low priority route retry queue: 0 queued
т.е. проблема возникает при флапе BGP, когда маршрутизатор формирует таблицу. Исходя из текущего вывода проблемы на текущий момент нет.
а нужно ли на такой коробке иметь 2 фула?
3 минуты назад, sda_1 сказал:
Всё верно, просто я не могу понять почему так медленно загружаются префиксы и сыпятся ошибки в логе. На текущий момент проблема не наблюдается.
Да, у меня два апстрима с одинаковой шириной канала, загрузка при этом равномерная, примерно 45/55
39 минут назад, swat11 сказал:
может тогда просто от апстримов принять только дефолты и сделать multipath multiple-as ?
set protocols bgp group ХХХ multipath multiple-as
это сильно облегчит жизнь для MX
18 часов назад, sda_1 сказал:
По другому не получиться? Либо multipath multiple-as, либо замена железки?
а что должно быть по другому?
вам джун пишет что ему ресурсов не хватает.
ну можно смириться и наблюдать такое в логах, правда может при очередном флапе сессии просто RPD приложить.
Если вам так нужен фулл что стоит вопрос смены коробки, тогда меняйте.
Но всёже, вам действительно настолько нужен фулл?
3 часа назад, sda_1 сказал:
Я понял, буду тогда думать в сторону дефолтных маршрутов. Спасибо за помощь!
Тему можно закрывать.
