Добрый день!
Столкнули с проблемой пропаданием EPON интерфейса на OLT. Для восстановление работоспособности помогает перезагрузка.
Вот последние 2 ЛОГА, перед тем как пропадали EPON:
Лог 10 марта
Mar 10 12:13:42 192.168.10.3 Hello TO, OLT deregistration: Device ID 0x00000000
Mar 10 12:13:42 192.168.10.3 %OLT-STATUS: OLT index 0, slot 0, device 0x03000000 is hello timed out.
Mar 10 12:13:42 192.168.10.3 OIR-6-BUILD_CONFIGURATION: Building running-configurations for slot 0
Mar 10 12:13:42 192.168.10.3 %hal_oir_channel_dettach: slot = 0, chip = 0
Mar 10 12:13:45 192.168.10.3 %LINE-5-UPDOWN: Line on Interface EPON0/1, changed state to down
Mar 10 12:13:45 192.168.10.3 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/1, changed state to down
Mar 11 14:07:57 192.168.10.3 Hello TO, OLT deregistration: Device ID 0x00000000
Mar 11 14:07:57 192.168.10.3 %OLT-STATUS: OLT index 0, slot 0, device 0x03000000 is hello timed out.
Mar 11 14:07:57 192.168.10.3 OIR-6-BUILD_CONFIGURATION: Building running-configurations for slot 0
Mar 11 14:07:57 192.168.10.3 %hal_oir_channel_dettach: slot = 0, chip = 0
Mar 11 14:08:02 192.168.10.3 %LINE-5-UPDOWN: Line on Interface EPON0/1, changed state to down
Mar 11 14:08:02 192.168.10.3 %LINEPROTO-5-UPDOWN: Line protocol on Interface EPON0/1, changed state to down
Конфигурация:
Скрытый текст
!version 10.1.0D build 33463
service timestamps log date
service timestamps debug date
service password-encryption
logging 89.221.226.7
logging buffered 4096
logging buffered informational
logging monitor alerts
hostname Drugba
port-protected 1
ip default-gateway 192.168.10.1
no spanning-tree
aaa authentication login default local
aaa authentication enable default none
username admin password 7 154933444A1369343F6561137A
enable password 7 154933444A1369343F6561137A level 15
epon oam-version 1 0x21
epon oam-version 2 0x20
epon onu-config-template G1
 cmd-sequence 1 switchport port-security mode dynamic
 cmd-sequence 2 switchport port-security dynamic maximum 10
 cmd-sequence 3 epon onu all-port ctc vlan mode tag %1
 cmd-sequence 4 epon onu all-port ctc loopback detect
!!slot 0 89
interface GigaEthernet0/1
 description UPLINK
 switchport trunk vlan-allowed 10,101,103-104
 switchport mode trunk
  dhcp snooping trust
  arp inspection trust
  ip-source trust
interface GigaEthernet0/2
 shutdown
interface GigaEthernet0/3
 shutdown
interface GigaEthernet0/4
 shutdown
interface GigaEthernet0/5
 shutdown
interface GigaEthernet0/6
 shutdown
interface EPON0/1
 epon pre-config-template G1 binded-onu-llid 1-64 param 103
 epon bind-onu mac 1c87.7912.e71d 1
 epon bind-onu mac 1c87.7912.e727 2
 epon bind-onu mac 8479.73ed.270c 3
 epon bind-onu mac 8479.73ed.250b 4
 epon bind-onu mac 8479.73ed.2631 5
 epon bind-onu mac 8479.73ed.10fb 6
 epon bind-onu mac 8479.73ed.2680 7
 switchport trunk vlan-allowed 103
 switchport trunk vlan-untagged none
 switchport protected 1
interface EPON0/1:1
interface EPON0/1:2
interface EPON0/1:3
interface EPON0/1:4
interface EPON0/1:5
interface EPON0/1:6
interface EPON0/1:7
interface EPON0/2
 shutdown
interface EPON0/3
 shutdown
interface EPON0/4
 shutdown
!!slot end
interface VLAN10
 ip address 192.168.10.3 255.255.255.0
vlan 1,10,103-104
ip dhcp-relay snooping
ip dhcp-relay snooping vlan  101,103-104
ip dhcp-relay snooping information option format hn-type
ip http server
snmp-server community 0 public RO R0
snmp-server location Optimist_Sov_Arm_Drugba
banner message
 text Hello to DRUGBA !!!
line vty 0
 exec-timeout 0
line vty 1
 exec-timeout 0
line vty 2
 exec-timeout 0
line vty 3
 exec-timeout 0
line vty 4
 exec-timeout 0
line vty 5
 exec-timeout 0
line vty 6
 exec-timeout 0
line vty 7
 exec-timeout 0
line vty 8
 exec-timeout 0
line vty 9
 exec-timeout 0
line vty 10
 exec-timeout 0
line vty 11
 exec-timeout 0
line vty 12
 exec-timeout 0
line vty 13
 exec-timeout 0
line vty 14
 exec-timeout 0
line vty 15
 exec-timeout 0
line vty 16
 exec-timeout 0
line vty 17
 exec-timeout 0
line vty 18
 exec-timeout 0
line vty 19
 exec-timeout 0
line vty 20
 exec-timeout 0
line vty 21
 exec-timeout 0
line vty 22
 exec-timeout 0
line vty 23
 exec-timeout 0
line vty 24
 exec-timeout 0
line vty 25
 exec-timeout 0
line vty 26
 exec-timeout 0
line vty 27
 exec-timeout 0
line vty 28
 exec-timeout 0
line vty 29
 exec-timeout 0
line vty 30
 exec-timeout 0
line vty 31
 exec-timeout 0
time-zone Moscow 3 0
ntp server 192.168.99.1
ntp server 91.207.136.50
!Pending configurations for absent linecards:
!No configurations pending global
В чем может быть проблема?
1 час назад, rdmitrich сказал:
Может у вас просто SFP приказал долго жить ??
Вчера поменял на новый модуль. Раньше не сталкивался с тем как SFP "умирают", 20 часов полет нормальный. Наблюдаю.
А может подобное возникнуть из-за плохого контакта SFP и OLT ? Может старый модуль был недовставлен ?
За неделю до появления проблемы, установили эти модули в новый OLT. Но сами модули отработали уже около года.
Вполне могут, законы физики никто не отменял, могут закиснуть контакты, у коллег из РТК Модули таки умирали, правда причину я не выяснял
Поменял модули, на Agear PX20+ Gepon. В логах BDCOM появилось следующее и постоянно сыпит эту ошибку:
Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1
Что бы это могло быть?
Заказал модули с НАГа, посмотрим на них.
Edited by divxl
  • 1 year later...
В 20.03.2018 в 10:25, divxl сказал:
epon onu-always-laser-on disable
отключение уведомления об данной ошибки тяжело назвать стабильностью
появились данные сообщения на sfp foxgate gepon c+ , относительно новая, в работе месяцев 2-3, стоит попробовать другую поставить? дерево не отваливается, пока только сыпятся сообщения в логи
19 часов назад, WideAreaNetwork сказал:
Добрый день!
Данное сообщение обычно уведомляет о присутствии постоянно светящего лазера со стороны абонентов. Причиной излучения может быть неисправная ONU или посторонний источник(например медиаконвертер).  Начать искать стоит со списка неактивных ONU полученных командой sh epon inactive-onu interface e0/X. ОNU из данного списка физически отключаем от сети. Если не нашли источник, производим посекторное отключение.
Добрый день!
данные сообщения поступают от конкретной одной onu, наверное стоит ее заменить для начала, а далее по описанным выше действиям
Скрытый текст
Jan 15 07:14:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:14:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:14:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:13:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:13:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:13:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:12:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:12:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:12:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:11:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:11:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:11:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:10:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:10:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:10:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:09:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:09:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:09:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:08:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:08:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:08:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:07:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:07:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:07:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:06:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:06:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:06:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:05:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:05:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:05:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:04:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:04:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:04:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:03:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:03:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:03:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:02:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:02:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:02:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:01:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:01:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:01:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 07:00:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 07:00:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 07:00:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 06:59:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 06:59:47 timestamp 0, window 0, threshold 0, value 0
Jan 15 06:59:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
Jan 15 06:58:47 %ONU-LAO-DETECT: ONU EPON0/2:5 may be laser always on.
Jan 15 06:58:47 timestamp 0, window 0, threshold 0, value 0
а нет, таки даже на всех портах
Скрытый текст
warnings(4) JAN 15 9:32:47 timestamp 0, window 0, threshold 0, value 0
warnings(4) JAN 15 9:32:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/2 pon_diID 8
warnings(4) JAN 15 9:32:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
warnings(4) JAN 15 9:31:47 timestamp 0, window 0, threshold 0, value 0
warnings(4) JAN 15 9:31:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/2 pon_diID 8
warnings(4) JAN 15 9:31:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
warnings(4) JAN 15 9:30:47 timestamp 0, window 0, threshold 0, value 0
warnings(4) JAN 15 9:30:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/2 pon_diID 8
warnings(4) JAN 15 9:30:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
warnings(4) JAN 15 9:29:47 timestamp 0, window 0, threshold 0, value 0
warnings(4) JAN 15 9:29:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/2 pon_diID 8
warnings(4) JAN 15 9:29:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
warnings(4) JAN 15 9:28:47 timestamp 0, window 0, threshold 0, value 0
warnings(4) JAN 15 9:28:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/2 pon_diID 8
warnings(4) JAN 15 9:28:47 Alarm LASER_ALWAYS_ON from OLT 0x03000000 port EPON0/1 pon_diID 7
попробую сфп сменить на другого вендора
В 18.01.2020 в 17:14, WideAreaNetwork сказал:
таки sfp foxgate проблемные, вставил bdcom sfp проблемы на порту ушли, там где осталась sfp foxgate проблемы остались
Тоже с такой проблемой встречались, теперь используем sfp bdcom или snr, полет нормальный :)
  • 5 years later...
epon onu-always-laser-on disable  - эта команда только уведомления отключает?
Где найти разъяснения по различным  сообщениям, которые выдаются в лог BDCOMa? В имеющейся документации нет о логах ничего.
Добрый день.
epon onu-always-laser-on enable - не только уведомления, также OLT пытается "забанить" проблемную ONU.
Так как это происходит, как правило, при "глюке" ОНУ или при установке медиаконвертера в линию, в таких случаях, этот функционал больше как оповещение о проблеме.
Руководства подобного у BDCOM нет.
Спасибо! так эта же команда прописывается на весь epon. Т.е. "банятся" все проблемные ONU на EPONe? Как понять, какие именно? Они ведь не должны тогда регистрироваться?
Очень жаль, что нет руководства с разъяснениями подобных сообщений. Еще есть различные непонятные сообщения в логах. Как понять, о чем там речь...
