Добрый день!
Имеем цыску 2691 вот с таким софтом:
slot0:c2691-adventerprisek9_ivs-mz.124-15.T10.bin
Вот с таким конфигом:
version 12.4
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname C2691-UME
boot-start-marker
boot-end-marker
logging buffered 4096
aaa new-model
aaa session-id common
no network-clock-participate slot 1
ip cef
no ip dhcp use vrf connected
ip dhcp pool PHONES
  network 192.168.3.0 255.255.255.0
  default-router 192.168.3.1
  dns-server 8.8.8.8
multilink bundle-name authenticated
archive
log config
 hidekeys
track 1 rtr 10 reachability
delay down 10 up 10
track 2 rtr 20 reachability
delay down 10 up 10
interface FastEthernet0/0
description UPLINK-1
ip address xxx.yyy.1.106 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
load-interval 30
speed 100
full-duplex
hold-queue 4096 in
hold-queue 4096 out
interface FastEthernet0/1
description UPLINK-2
ip address www.zzz.21.66 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
load-interval 30
duplex auto
speed auto
hold-queue 4096 in
hold-queue 4096 out
interface FastEthernet1/0
description INSIDE
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip policy route-map track-nat
load-interval 30
speed 100
full-duplex
hold-queue 4096 in
hold-queue 4096 out
interface FastEthernet1/1
description INSIDE PHONES
ip address 192.168.3.1 255.255.255.0
ip nat inside
load-interval 30
speed 100
full-duplex
hold-queue 4096 in
hold-queue 4096 out
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 xxx.yyy.1.105 200 track 1
ip route 0.0.0.0 0.0.0.0 www.zzz.21.1 250 track 2
ip http server
no ip http secure-server
ip nat inside source route-map UPLINK-1 interface FastEthernet0/0 overload
ip nat inside source route-map UPLINK-2 interface FastEthernet0/1 overload
ip access-list extended NAT-UPLINK-1
permit ip 192.168.2.0 0.0.0.255 any
permit ip 192.168.3.0 0.0.0.255 any
permit ip 192.168.1.0 0.0.0.255 any
ip access-list extended NAT-UPLINK-2
ip sla 10
icmp-echo xxx.yyy.1.105
frequency 5
ip sla schedule 10 life forever start-time now
ip sla 20
icmp-echo www.zzz.21.1
frequency 5
ip sla schedule 20 life forever start-time now
snmp-server community xxxxxxxxx RW
snmp-server ifindex persist
snmp-server location UME
route-map UPLINK-1 permit 10
match interface FastEthernet0/0
route-map track-nat permit 10
match ip address NAT-UPLINK-1
set ip next-hop verify-availability xxx.yyy.1.105 10 track 1
set ip next-hop verify-availability www.zzz.21.1 20 track 2
route-map track-nat permit 20
match ip address NAT-UPLINK-2
set ip next-hop verify-availability www.zzz.21.1 10 track 2
set ip next-hop verify-availability xxx.yyy.1.105 20 track 1
route-map UPLINK-2 permit 10
match interface FastEthernet0/1
control-plane
gatekeeper
shutdown
line con 0
line aux 0
event manager applet UPLINK1_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 1.5 cli command "clear ip nat translation *"
action 1.8 cli command "end"
action 1.9 cli command "exit"
event manager applet UPLINK1_UP
event track 1 state up
Собственно ниче необычного обычная энтерпрайз цыска с двумя аплинками, делает нат для компов и сип-телефонов.
Стоит задача зарезервировать аплинк.
Была создана конструкция с роутмпами и трекерами
Пингуется шлюз первого аплинка, если пинг пропал то переключается на второго.
Теперь проблема: интет отрабатывает замечательно, а вот сип-телефоны не регаются с нового адреса на атс оператора, через нат на этой цыске. Дело втом что таблице нат повисает старая сессия и помогает только команда clear ip nat translations *
Что бы этот трюк провернуть воспользовались EEM с привязкой к трекеру (продублирую строчки конфига):
Однако данный функционал не отрабатывает потому что сессии так и висят, сбросить можно тока руками.
Вопрос в какую сторону рыть?
Заранее спасибо!
