Озадачились сделать bgp сессию с quagga (для dns серверов c резервированием)
ipv4 сессия успешно установилась, а вот ipv6 никак не хочет
Mar 29 14:06:48.127: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:06:56.364: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:07:09.735: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:07:15.053: %BGP-3-NOTIFICATION: sent to neighbor 2A07:yyyy::xx passive 2/7 (unsupported/disjoint capability) 0 bytes
Mar 29 14:07:15.053: %BGP-4-MSGDUMP: unsupported or mal-formatted message received from 2A07:yyyy::xx:
FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 001D 0104 FDDF 00B4 5BD6 4405 00
Mar 29 14:07:17.972: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:07:33.448: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:07:46.801: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:07:58.117: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:08:09.441: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:08:23.843: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:08:31.040: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:08:42.363: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:08:43.060: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Capability changed
Mar 29 14:08:43.060: %BGP-3-NOTIFICATION: sent to neighbor 2A07:yyyy::xx passive 2/8 (no supported AFI/SAFI) 3 bytes 000101
Mar 29 14:08:56.766: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:09:06.034: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:09:13.240: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:09:27.659: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:09:41.037: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:09:52.353: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:10:00.581: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:10:13.960: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:10:22.197: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:10:35.568: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:10:45.868: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Peer closed the session
Mar 29 14:10:49.064: %BGP_SESSION-5-ADJCHANGE: neighbor 2A07:yyyy::xx IPv6 Unicast topology base removed from session Capability changed
Mar 29 14:10:49.064: %BGP-3-NOTIFICATION: sent to neighbor 2A07:yyyy::xx passive 2/8 (no supported AFI/SAFI) 3 bytes 000101
конфиг cisco
neighbor 2A07:yyyy::xx remote-as 64991
neighbor 2A07:yyyy::xx activate
neighbor 2A07:yyyy::xx send-community
neighbor 2A07:yyyy::xx route-map IN-BGP-ACCESS-IPv6 in
neighbor 2A07:yyyy::xx route-map OUT-BGP-DEFAULT-IPv6 out
конфиг quagga:
neighbor 2A07:yyyy::zz remote-as 65070
neighbor 2A07:yyyy::zz soft-reconfiguration inbound
кто сталкивался ?
и да - ipv4/ipv6 bgp сессии внутри одного int vlan. но между cisco-cisco такая схема работает.
и вот лог с кваги
2017/03/29 14:10:49 BGP: message index 8 not found in bgp_notify_open_msg (max is 8)
2017/03/29 14:12:57 BGP: message index 8 not found in bgp_notify_open_msg (max is 8)
2017/03/29 14:14:03 BGP: message index 8 not found in bgp_notify_open_msg (max is 8)
2017/03/29 14:15:36 BGP: message index 8 not found in bgp_notify_open_msg (max is 8)
2017/03/29 14:17:14 BGP: message index 8 not found in bgp_notify_open_msg (max is 8)
2017/03/29 14:19:57 BGP: message index 8 not found in bgp_notify_open_msg (max is 8)
router bgp X
neighbor Y::Z remote-as 12345
no neighbor Y::Z activate
address-family ipv6
neighbor Y::Z route-map RM in
neighbor Y::Z route-map RM out
Кстати в BGP-сессии на v4 адресах можно анонсировать и v6 префиксы чтобы не поднимать вторую сессию.
победил сам - оказывается в кваге по умолчанию в разделе ipv4 не создается запись вида no neighbor 2A07:yyyy::zz activate
добавил ее в раздел ipv4 и всё заработало
это через set ipv6 next-hop
Да, через next-hop, решение нестандартное но иногда бывает полезным.
но вопрос как 3750 справиться с большими объемами?
Трафик-то причем? Раут-мап в BGP работает исключительно в control-plane.
