Mikrotik RB951G-2HnD+l2tp(билайн) разрыв соединения каждые 3 часа
После подключения к интернету ровно через 3 часа рвется соединение.
лог разрыва
13:02:50 wireless,info 7C:F9:0E:59:90:49@wlan1: connected
13:20:44 l2tp,ppp,info Beeline: terminating...
13:20:44 l2tp,ppp,info Beeline: disconnected
13:20:44 l2tp,ppp,info Beeline: initializing...
13:20:44 l2tp,ppp,info Beeline: connecting...
13:20:44 l2tp,ppp,info Beeline: terminating... - session closed
13:20:45 l2tp,ppp,info Beeline: initializing...
13:20:45 l2tp,ppp,info Beeline: connecting...
13:20:45 l2tp,ppp,info Beeline: terminating... - session closed
13:20:45 l2tp,ppp,info Beeline: disconnected
13:20:46 l2tp,ppp,info Beeline: initializing...
13:20:46 l2tp,ppp,info Beeline: connecting...
13:20:47 l2tp,ppp,info Beeline: authenticated
13:20:47 l2tp,ppp,info Beeline: connected
14:15:35 wireless,info C8:3A:35:C4:19:63@wlan1: connected
14:15:36 dhcp,info defconf assigned 192.168.1.242 to C8:3A:35:C4:19:63
14:16:30 wireless,info C8:3A:35:C4:19:63@wlan1: disconnected, extensive data loss
14:25:36 dhcp,info defconf deassigned 192.168.1.242 from C8:3A:35:C4:19:63
16:20:46 l2tp,ppp,info Beeline: terminating... - session closed
16:20:46 l2tp,ppp,info Beeline: disconnected
16:20:46 l2tp,ppp,info Beeline: initializing...
16:20:46 l2tp,ppp,info Beeline: connecting...
16:20:47 l2tp,ppp,info Beeline: initializing...
16:20:47 l2tp,ppp,info Beeline: connecting...
16:20:47 l2tp,ppp,info Beeline: terminating... - failed to authenticate ourselves
to peer
16:20:47 l2tp,ppp,info Beeline: disconnected
16:20:49 l2tp,ppp,info Beeline: initializing...
16:20:49 l2tp,ppp,info Beeline: connecting...
16:20:49 l2tp,ppp,info Beeline: terminating... - session closed
16:20:49 l2tp,ppp,info Beeline: disconnected
16:20:52 l2tp,ppp,info Beeline: initializing...
16:20:52 l2tp,ppp,info Beeline: connecting...
16:21:00 l2tp,ppp,info Beeline: authenticated
16:21:00 l2tp,ppp,info Beeline: connected
17:06:05 wireless,info 74:E2:8C:DD:71:88@wlan1: connected
лог l2tp
21:23:54 l2tp,debug,packet tunnel-id=4, session-id=0, ns=2, nr=183
21:24:54 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 10.26.
209.114:1701
21:24:54 l2tp,debug,packet tunnel-id=60174, session-id=0, ns=183, nr=2
21:24:54 l2tp,debug,packet (M) Message-Type=HELLO
21:24:54 l2tp,debug,packet rcvd control message (ack) from 10.255.255.240:1701 to
10.26.209.114:1701
21:24:54 l2tp,debug,packet tunnel-id=4, session-id=0, ns=2, nr=184
21:24:56 l2tp,ppp,debug,packet Beeline: rcvd LCP TermReq id=0x41
21:24:56 l2tp,ppp,debug Beeline: LCP closed
21:24:56 l2tp,ppp,debug Beeline: CCP lowerdown
21:24:56 l2tp,ppp,debug Beeline: BCP lowerdown
21:24:56 l2tp,ppp,debug Beeline: BCP down event in starting state
21:24:56 l2tp,ppp,debug Beeline: IPCP lowerdown
21:24:56 l2tp,ppp,debug Beeline: IPCP closed
21:24:56 l2tp,ppp,debug Beeline: IPV6CP lowerdown
21:24:56 l2tp,ppp,debug Beeline: IPV6CP down event in starting state
21:24:56 l2tp,ppp,debug Beeline: MPLSCP lowerdown
21:24:56 l2tp,ppp,debug,packet Beeline: sent LCP TermAck id=0x41
21:24:56 l2tp,ppp,debug Beeline: LCP lowerdown
21:24:56 l2tp,ppp,info Beeline: terminating...
21:24:56 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 10.26.
209.114:1701
21:24:56 l2tp,debug,packet tunnel-id=60174, session-id=28680, ns=184, nr=2
21:24:56 l2tp,debug,packet (M) Message-Type=CDN
21:24:56 l2tp,debug,packet (M) Result-Code=1
21:24:56 l2tp,debug,packet (M) Assigned-Session-ID=1
21:24:56 l2tp,debug session 1 entering state: stopping
21:24:57 l2tp,ppp,debug Beeline: LCP lowerdown
21:24:57 l2tp,ppp,debug Beeline: LCP down event in starting state
21:24:57 l2tp,ppp,info Beeline: disconnected
21:24:57 l2tp,debug,packet rcvd control message from 10.255.255.240:1701 to 10.26.
209.114:1701
21:24:57 l2tp,debug,packet tunnel-id=4, session-id=1, ns=2, nr=184
21:24:57 l2tp,debug,packet (M) Message-Type=CDN
21:24:57 l2tp,debug,packet (M) Assigned-Session-ID=28680
21:24:57 l2tp,debug,packet PPP-Disconnect-Cause-Code=0x00:01:00:00:00:53:65:73
:73:69:6f:6e:20:63:6c:65
21:24:57 l2tp,debug,packet 61:72:65:64:20:62:79:20:61:64:6d:69:6e:69:73:74
21:24:57 l2tp,debug,packet 72:61:74:6f:72
21:24:57 l2tp,debug,packet (M) Result-Code=3
21:24:57 l2tp,debug,packet Error-Code=0
21:24:57 l2tp,debug,packet Error-Message="Session cleared by administrator
21:24:57 l2tp,debug,packet sent control message (ack) to 10.255.255.240:1701 from
10.26.209.114:1701
21:24:57 l2tp,debug,packet tunnel-id=60174, session-id=0, ns=185, nr=3
21:24:57 l2tp,debug session 1 entering state: stopping
21:24:57 l2tp,debug session 1 entering state: dead
21:24:57 l2tp,debug tunnel 4 entering state: stopping
21:24:57 l2tp,debug,packet rcvd control message (ack) from 10.255.255.240:1701 to
10.26.209.114:1701
21:24:57 l2tp,debug,packet tunnel-id=4, session-id=0, ns=3, nr=185
21:24:57 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 10.26.
209.114:1701
21:24:57 l2tp,debug,packet (M) Message-Type=StopCCN
21:24:57 l2tp,debug,packet (M) Result-Code=1
21:24:57 l2tp,debug,packet (M) Assigned-Tunnel-ID=4
10.26.209.114:1701
21:24:57 l2tp,debug,packet tunnel-id=4, session-id=0, ns=3, nr=186
21:24:57 l2tp,debug tunnel 4 entering state: dead
21:24:57 l2tp,ppp,info Beeline: initializing...
21:24:57 l2tp,ppp,info Beeline: connecting...
21:24:57 l2tp,debug tunnel 5 entering state: wait-ctl-reply
21:24:57 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 0.0.0.
0:1701
21:24:57 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
21:24:57 l2tp,debug,packet (M) Message-Type=SCCRQ
21:24:57 l2tp,debug,packet (M) Protocol-Version=0x01:00
21:24:57 l2tp,debug,packet (M) Framing-Capabilities=0x1
21:24:57 l2tp,debug,packet (M) Bearer-Capabilities=0x0
21:24:57 l2tp,debug,packet Firmware-Revision=0x1
21:24:57 l2tp,debug,packet (M) Host-Name="MikroTik"
21:24:57 l2tp,debug,packet Vendor-Name="MikroTik"
21:24:57 l2tp,debug,packet (M) Assigned-Tunnel-ID=5
21:24:57 l2tp,debug,packet (M) Receive-Window-Size=4
209.114:1701
21:24:57 l2tp,debug,packet tunnel-id=5, session-id=0, ns=0, nr=0
21:24:57 l2tp,debug,packet (M) Assigned-Tunnel-ID=37501
21:24:57 l2tp,debug,packet Error-Message="Reached configured max-tunnels l
imit"
10.26.209.114:1701
21:24:57 l2tp,debug,packet tunnel-id=37501, session-id=0, ns=0, nr=1
21:24:58 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 0.0.0.
0:1701
21:24:58 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
21:24:58 l2tp,debug,packet (M) Message-Type=SCCRQ
21:24:58 l2tp,debug,packet (M) Protocol-Version=0x01:00
21:24:58 l2tp,debug,packet (M) Framing-Capabilities=0x1
21:24:58 l2tp,debug,packet (M) Bearer-Capabilities=0x0
21:24:58 l2tp,debug,packet Firmware-Revision=0x1
21:24:58 l2tp,debug,packet (M) Host-Name="MikroTik"
21:24:58 l2tp,debug,packet Vendor-Name="MikroTik"
21:24:58 l2tp,debug,packet (M) Assigned-Tunnel-ID=5
21:24:58 l2tp,debug,packet (M) Receive-Window-Size=4
21:24:58 l2tp,debug,packet rcvd control message from 10.255.255.240:1701 to 10.26.
209.114:1701
21:24:58 l2tp,debug,packet tunnel-id=5, session-id=0, ns=0, nr=0
21:24:58 l2tp,debug,packet (M) Message-Type=StopCCN
21:24:58 l2tp,debug,packet (M) Assigned-Tunnel-ID=37509
21:24:58 l2tp,debug,packet (M) Result-Code=1
21:24:58 l2tp,debug,packet Error-Code=0
21:24:58 l2tp,debug,packet Error-Message="Reached configured max-tunnels l
imit"
21:24:58 l2tp,debug,packet sent control message (ack) to 10.255.255.240:1701 from
10.26.209.114:1701
21:24:58 l2tp,debug,packet tunnel-id=37509, session-id=0, ns=0, nr=1
21:24:59 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 0.0.0.
0:1701
21:24:59 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
21:24:59 l2tp,debug,packet (M) Message-Type=SCCRQ
21:24:59 l2tp,debug,packet (M) Protocol-Version=0x01:00
21:24:59 l2tp,debug,packet (M) Framing-Capabilities=0x1
21:24:59 l2tp,debug,packet (M) Bearer-Capabilities=0x0
21:24:59 l2tp,debug,packet Firmware-Revision=0x1
21:24:59 l2tp,debug,packet (M) Host-Name="MikroTik"
21:24:59 l2tp,debug,packet Vendor-Name="MikroTik"
21:24:59 l2tp,debug,packet (M) Assigned-Tunnel-ID=5
21:24:59 l2tp,debug,packet (M) Receive-Window-Size=4
21:24:59 l2tp,debug,packet rcvd control message from 10.255.255.240:1701 to 10.26.
209.114:1701
21:24:59 l2tp,debug,packet tunnel-id=5, session-id=0, ns=0, nr=0
21:24:59 l2tp,debug,packet (M) Message-Type=StopCCN
21:24:59 l2tp,debug,packet (M) Assigned-Tunnel-ID=37518
21:24:59 l2tp,debug,packet (M) Result-Code=1
21:24:59 l2tp,debug,packet Error-Code=0
21:24:59 l2tp,debug,packet Error-Message="Reached configured max-tunnels l
imit"
21:24:59 l2tp,debug,packet sent control message (ack) to 10.255.255.240:1701 from
10.26.209.114:1701
21:24:59 l2tp,debug,packet tunnel-id=37518, session-id=0, ns=0, nr=1
21:25:01 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 0.0.0.
0:1701
21:25:01 l2tp,debug,packet tunnel-id=0, session-id=0, ns=0, nr=0
21:25:01 l2tp,debug,packet (M) Message-Type=SCCRQ
21:25:01 l2tp,debug,packet (M) Protocol-Version=0x01:00
21:25:01 l2tp,debug,packet (M) Framing-Capabilities=0x1
21:25:01 l2tp,debug,packet (M) Bearer-Capabilities=0x0
21:25:01 l2tp,debug,packet Firmware-Revision=0x1
21:25:01 l2tp,debug,packet (M) Host-Name="MikroTik"
21:25:01 l2tp,debug,packet Vendor-Name="MikroTik"
21:25:01 l2tp,debug,packet (M) Assigned-Tunnel-ID=5
21:25:01 l2tp,debug,packet (M) Receive-Window-Size=4
21:25:01 l2tp,debug,packet rcvd control message (ack) from 10.255.255.240:1701 to
10.26.209.114:1701
21:25:01 l2tp,debug,packet tunnel-id=5, session-id=0, ns=0, nr=1
21:25:02 l2tp,debug,packet rcvd control message from 10.255.255.240:1701 to 10.26.
209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=5, session-id=0, ns=0, nr=1
21:25:02 l2tp,debug,packet (M) Message-Type=SCCRP
21:25:02 l2tp,debug,packet (M) Protocol-Version=0x01:00
21:25:02 l2tp,debug,packet (M) Framing-Capabilities=0x3
21:25:02 l2tp,debug,packet 46(vendor-id=2352)=0x00:00:00:08
21:25:02 l2tp,debug,packet (M) Bearer-Capabilities=0x0
21:25:02 l2tp,debug,packet Firmware-Revision=0x600
21:25:02 l2tp,debug,packet (M) Host-Name="vpn250.krasnodar"
21:25:02 l2tp,debug,packet Vendor-Name="RedBack Networks"
21:25:02 l2tp,debug,packet (M) Assigned-Tunnel-ID=37533
21:25:02 l2tp,debug,packet (M) Receive-Window-Size=8
21:25:02 l2tp,debug tunnel 5 entering state: established
21:25:02 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 10.26.
209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=37533, session-id=0, ns=1, nr=1
21:25:02 l2tp,debug,packet (M) Message-Type=SCCCN
21:25:02 l2tp,debug session 1 entering state: wait-reply
21:25:02 l2tp,debug,packet rcvd control message (ack) from 10.255.255.240:1701 to
10.26.209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=5, session-id=0, ns=1, nr=2
209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=37533, session-id=0, ns=2, nr=1
21:25:02 l2tp,debug,packet (M) Message-Type=ICRQ
21:25:02 l2tp,debug,packet (M) Assigned-Session-ID=1
21:25:02 l2tp,debug,packet (M) Call-Serial-Number=7
21:25:02 l2tp,debug,packet (M) Bearer-Type=0x0
10.26.209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=5, session-id=0, ns=1, nr=3
209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=5, session-id=1, ns=1, nr=3
21:25:02 l2tp,debug,packet (M) Message-Type=ICRP
21:25:02 l2tp,debug,packet (M) Assigned-Session-ID=27177
21:25:02 l2tp,debug session 1 entering state: established
209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=37533, session-id=27177, ns=3, nr=2
21:25:02 l2tp,debug,packet (M) Message-Type=ICCN
21:25:02 l2tp,debug,packet (M) Framing-Type=0x1
21:25:02 l2tp,debug,packet (M) Tx-Connect-Speed-BPS=100000000
10.26.209.114:1701
21:25:02 l2tp,debug,packet tunnel-id=5, session-id=0, ns=2, nr=4
21:25:02 l2tp,ppp,debug Beeline: LCP lowerup
21:25:02 l2tp,ppp,debug,packet Beeline: sent LCP ConfReq id=0x4
21:25:02 l2tp,ppp,debug,packet <magic 0x4d7f3103>
21:25:02 l2tp,ppp,debug Beeline: LCP open
21:25:02 l2tp,ppp,debug,packet Beeline: rcvd LCP ConfAck id=0x4
21:25:03 l2tp,ppp,debug Beeline: LCP timer
21:25:03 l2tp,ppp,debug,packet Beeline: sent LCP ConfReq id=0x5
21:25:03 l2tp,ppp,debug,packet <magic 0x4d7f3103>
21:25:03 l2tp,ppp,debug,packet Beeline: rcvd LCP ConfAck id=0x5
21:25:05 l2tp,ppp,debug Beeline: LCP timer
21:25:05 l2tp,ppp,debug,packet Beeline: sent LCP ConfReq id=0x6
21:25:05 l2tp,ppp,debug,packet <magic 0x4d7f3103>
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd LCP ConfAck id=0x6
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd LCP ConfReq id=0x6f
21:25:05 l2tp,ppp,debug,packet <mru 1456>
21:25:05 l2tp,ppp,debug,packet <magic 0x441d84>
21:25:05 l2tp,ppp,debug,packet <auth chap>
21:25:05 l2tp,ppp,debug,packet Beeline: sent LCP ConfAck id=0x6f
21:25:05 l2tp,ppp,debug Beeline: LCP opened
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd CHAP Challenge id=0x1
21:25:05 l2tp,ppp,debug,packet <challenge len=16>
21:25:05 l2tp,ppp,debug,packet <name vpn250.krasnodar>
21:25:05 l2tp,ppp,debug,packet Beeline: sent CHAP Response id=0x1
21:25:05 l2tp,ppp,debug,packet <response len=16>
21:25:05 l2tp,ppp,debug,packet <name 0897076668>
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd CHAP Success id=0x1
21:25:05 l2tp,ppp,debug,packet CHAP authentication success, unit 210
21:25:05 l2tp,ppp,info Beeline: authenticated
21:25:05 l2tp,ppp,debug Beeline: IPCP lowerup
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfReq id=0x7
21:25:05 l2tp,ppp,debug,packet <addr 0.0.0.0>
21:25:05 l2tp,ppp,debug Beeline: IPCP open
21:25:05 l2tp,ppp,debug Beeline: IPV6CP open
21:25:05 l2tp,ppp,debug Beeline: MPLSCP lowerup
21:25:05 l2tp,ppp,debug,packet Beeline: sent MPLSCP ConfReq id=0x1f
21:25:05 l2tp,ppp,debug Beeline: MPLSCP open
21:25:05 l2tp,ppp,debug Beeline: BCP open
21:25:05 l2tp,ppp,debug Beeline: CCP lowerup
21:25:05 l2tp,ppp,debug Beeline: CCP open
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfReq id=0xfd
21:25:05 l2tp,ppp,debug,packet <addr 95.30.0.1>
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfNak id=0xfd
21:25:05 l2tp,ppp,debug,packet <addr 192.168.255.254>
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfNak id=0x7
21:25:05 l2tp,ppp,debug,packet <addr 95.30.50.176>
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfReq id=0x8
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfReq id=0xfe
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfNak id=0xfe
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfAck id=0x8
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfReq id=0xff
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfNak id=0xff
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfReq id=0x0
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfNak id=0x0
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfReq id=0x1
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfNak id=0x1
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfReq id=0x2
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfRej id=0x2
21:25:05 l2tp,ppp,debug,packet Beeline: rcvd IPCP ConfReq id=0x3
21:25:05 l2tp,ppp,debug,packet Beeline: sent IPCP ConfAck id=0x3
21:25:05 l2tp,ppp,debug Beeline: IPCP opened
21:25:05 l2tp,ppp,info Beeline: connected
21:26:02 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 10.26.
209.114:1701
21:26:02 l2tp,debug,packet tunnel-id=37533, session-id=0, ns=4, nr=2
21:26:02 l2tp,debug,packet (M) Message-Type=HELLO
21:26:02 l2tp,debug,packet rcvd control message (ack) from 10.255.255.240:1701 to
10.26.209.114:1701
21:26:02 l2tp,debug,packet tunnel-id=5, session-id=0, ns=2, nr=5
21:27:02 l2tp,debug,packet sent control message to 10.255.255.240:1701 from 10.26.
209.114:1701
  • 6 years later...
