Здравствуйте!
Есть две 7206 с NPE-G1. Обе визуально в отличном состоянии, последние года два пылятся на складе.
1. Конфигурация: шасси, один блок питания, NPE-G1. Ушей нет. Цена 15 тр
Router#sho version
Cisco Internetwork Operating System Software
IOS 7200 Software (C7200-IS-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Technical Support: http://www.cisco.com/techsupport
Copyright © 1986-2005 by cisco Systems, Inc.
Compiled Tue 24-May-05 19:38 by ssearch
Image text-base: 0x60008AF4, data-base: 0x61CB6000
ROM: System Bootstrap, Version 12.3(4r)T3, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-KBOOT-M), Version 12.3(15), RELEASE SOFTWARE (fc3)
Router uptime is 5 minutes
System returned to ROM by reload at 00:39:49 UTC Wed Jun 29 2016
System image file is "disk2:c7200-is-mz.123-15.bin"
Last reload reason: Reload command
cisco 7206VXR (NPE-G1) processor (revision B) with 983040K/65536K bytes of memory.
Processor board ID 35027724
SB-1 CPU at 700MHz, Implementation 1, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.11
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port
Adaptor Hardware Configuration Guidelines" on CCO <www.cisco.com>,
for c7200 bandwidth points oversubscription/usage guidelines.
3 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62720K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x2102
2. Комлпектация: шасси, уши, модуль NPE-G1, 2 блока питания, модуль Multi-channel E1/PRI-120 OHM Цена 21,5 тр. Можно перекинуть модуль в первый вариант, тогда эта 20, первая 16,5. Отдельно модуль 1,5
Router#sho version
Cisco IOS Software, 7200 Software (C7200-ADVENTERPRISEK9_SNA-M), Version 12.4(24)T6, RELEASE SOFTWARE (fc2)
Copyright © 1986-2011 by Cisco Systems, Inc.
Compiled Tue 23-Aug-11 04:16 by prod_rel_team
ROM: System Bootstrap, Version 12.2(8r)B, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System returned to ROM by power-on
System image file is "disk2:c7200-adventerprisek9_sna-mz.124-24.T6.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
Cisco 7206VXR (NPE-G1) processor (revision A) with 983040K/65536K bytes of memory.
Processor board ID 30470150
SB-1 CPU at 700MHz, Implementation 1025, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.7
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
3 Gigabit Ethernet interfaces
8 Serial interfaces
8 Channelized/Clear E1/PRI ports
509K bytes of NVRAM.
251904K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
Визуально железо выглядит отлично, когда было в работе проблем не было. Доставка ДЛ или ПЭК за счет покупателя. Оплата на карту СБ. На тест пару дней с момента получения. Фото могу кинуть на вотсап, связь ЛС.
UPD: железо находится в Ростове-на-Дону, +79613037961, Геннадий.
Edited by garryfisher
  • 2 months later...
