Добрый деньуважаемый форумчанины,
Может кому то пригодится:
Это настройки Мастера:
/interface ethernet
set find default-name=sfp1 name=WAN
set find default-name=ether9 name=ether9
/interface vrrp
add interface=WAN name=vrrp1 priority=254 vrid=49
add interface=ether9 name=vrrp2 priority=254 vrid=49
/interface vlan
add interface=vrrp2 l2mtu=1576 name=vlan1111 vlan-id=1111
add interface=vrrp2 l2mtu=1576 name=vlan1112 vlan-id=1112
/ip address
add address=XXX.XXX.XXX.XXX/XX network=217.8.44.0
add address=10.1.1.2/29 comment=DOWN interface=ether9 \
network=10.1.1.0
add address=10.1.1.1 comment="VRRP-FOR-DOWN" interface=vrrp2 \
network=10.1.1.1
add address=XXX.XXX.XXX.XXX/XX comment=POOL-PRIVATE-IP-FOR-CUSTOMER interface=\
vlan1112
add address=192.168.7.252/29 comment=UP interface=WAN\
network=192.168.7.248
add address=192.168.7.250 comment="VRRP-FOR-UP" interface=vrrp1 \
network=192.168.7.250
/system scheduler
add interval=10s name=UP on-event="/ system script run UP" policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive start-date=\
sep/18/2015 start-time=12:17:00
/system script
add name=UP owner=admin policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive source=": if ([\
/interface get ether9 running]=false) do={\
\n: if ([/interface vrrp get vrrp1 priority]=254) do={\
\n/interface vrrp set vrrp1 priority=90\
\n}\
\n}\
\n: if ([/interface get ether9 running]=true) do={\
\n: if ([/interface vrrp get vrrp1 priority]=90) do={\
\n/interface vrrp set vrrp1 priority=254\
\n}\
\n}"
Стороне Слейва:
Меняем только ip Down и UP:
