Добрый день, господа.
Нужен совет. Есть такая циска 1001x, говорят лицензия у нее rigth-to-use.
И предлагают нам купить железку и отдельно лицензию ipbase.
Вот собственно вопрос, а нужно ли покупать лицензию?
А на feature navigator про софт пишет
asr1001x-universalk9.03.14.00.S.155-1.S-std.SPA.bin
что он и Ipbase и ip services и ent services.
Спасибо!
http://www.cisco.com/c/en/us/products/collateral/routers/asr-1000-series-aggregation-services-routers/guide-c07-731639.html
With the Cisco ASR 1001, ASR 1001-X, and ASR 1002-X, the concept of a universal software image in combination with a technology package license to enforce a certain feature set by software activation, that is, with a PAK, has been introduced. However, for ASR 1001, as of Cisco IOS XE Software Release 3.6S, technology package licenses, and as of 3.7S, performance upgrade license to upgrade from 2.5 to 5 Gbps, are both honor-based. For ASR1001-X and ASR 1002-X, both technology package licenses and performance upgrade licenses are honor-based.
In summary:
● A PAK or license key enforces two types of licenses on the Cisco ASR 1001 prior to Cisco IOS XE Software Release 3.6S:
- Technology package licenses (feature set licenses); part numbers and descriptions follow:
- SLASR1-IPB: Cisco ASR 1000 IP Base license
- SLASR1-AIS: Cisco ASR 1000 Advanced IP Services license
- SLASR1-AES: Cisco ASR 1000 Advanced Enterprise Services license
- Performance Upgrade license; part number FLS-ASR1001-5G to upgrade from 2.5 to 5 Gbps.
● To enable a certain feature set on the Cisco ASR 1001, ASR 1001-X, or ASR 1002-X, you must order a universal image in combination with a technology package license.
Note: As of Cisco IOS XE Software Release 3.7S, the technology package licenses, the performance upgrade licenses, and all other licenses required for certain features on the Cisco ASR 1001, ASR 1001-X, and ASR 1002-X are not enforced.
вроде как не энфорсится... но кто его знает :)
