Доброго времени суток, коллеги.
имею следующую ситуацию:
есть ASR1k c последним IOS
asr1001-universalk9.03.13.01.S.154-3.S1-ext
Необходимо повесить service-policy output на Tunnel интерфейс.
Полиси собственно простая
class-map match-all SNMP
match access-group name SNMP
class-map match-all TELNET
match access-group name TELNET
class-map match-all WSUS
match access-group name WSUS
class-map match-all WINBOX
match access-group name WINBOX
class-map match-all EMULFR
match access-group name EMULFR
class-map match-all OSPF
match protocol ospf
class-map match-all OPEN
match access-group name OPEN
class-map match-all ICMP
match protocol icmp
class-map match-all HTTP
match access-group name HTTP
class-map match-all Web_Base
match access-group name Web_Base
class-map match-all ADM_SRV
match access-group name ADM_SRV
class-map match-all FTP
match access-group name FTP
class-map match-all RDP
match access-group name RDP-QOS
class-map match-all NTP
match access-group name NTP
class-map match-all SIP
match access-group name SIP
class-map match-all HTTPS
match access-group name HTTPS
class-map match-all MCAFE
match access-group name MCAFE
class-map match-all RTP
match protocol rtp
class-map match-all DNS
match access-group name DNS
class-map match-all 1C
match access-group name CITRIX
class-map match-any TunnelCls
match any
policy-map Tunnel-child
class OSPF
 bandwidth percent 2
class ICMP
 bandwidth percent 1
class NTP
 bandwidth percent 1
class TELNET
 bandwidth percent 1
class RDP
 bandwidth percent 5
class 1C
 bandwidth percent 10
class Web_Base
 bandwidth percent 20
class WINBOX
 bandwidth percent 2
class SNMP
 bandwidth percent 2
class SIP
 bandwidth percent 5
class DNS
 bandwidth percent 2
class HTTP
class HTTPS
class FTP
 bandwidth percent 2
class EMULFR
 bandwidth percent 2
class WSUS
 police cir percent 2
class MCAFE
class ADM_SRV
 bandwidth percent 15
class RTP
 bandwidth percent 2
class OPEN
 police cir 500000
  violate-action drop
class class-default
 fair-queue
 random-detect
policy-map Tunnel_2M
class class-default
 shape average 2048000
 police rate 2048000
  violate-action drop
  service-policy Tunnel-child
policy-map Tunnel_1M
class class-default
 shape average 1000000
 police rate 1000000
  violate-action drop
policy-map Tunnel_1M_IN
class TunnelCls
 police rate 1000000
  violate-action drop
policy-map Tunnel_2M_IN
class TunnelCls
 police rate 2000000
  violate-action drop
policy-map Tunnel_5M_IN
class TunnelCls
 police rate 5000000
  violate-action drop
policy-map [b]Tunnel_5M[/b]
class class-default
 shape average 5000000
 police rate 5000000
  violate-action drop
При попытки повесить её на интерфейс вижу в логах
(nbar): (err): NBAR is not supported on  TunnelХХХ
Туннель простой:
interface TunnelХХХ
ip address 172.20.2.5 255.255.255.252
ip mtu 1450
ip access-group DMZ_IN in
ip access-group DMZ_OUT out
ip policy route-map Forward_GlobalIP
ip ospf network point-to-point
ip ospf mtu-ignore
ip ospf cost 40
tunnel source 1.1.1.1
tunnel mode ipip
tunnel destination 2.2.2.2
tunnel protection ipsec profile IPSec-AES
service-policy input Tunnel_5M_IN
Собственно понятно что это ограничение платформы IOS XE (хотя почему не понятно).
Есть возможности отключить NBAR что бы можно было вешать политику Tunnel_5M на логические интерфейсы? На обычных IOS точно такая же service-policy прекрасно работает.
Раскурка документации ясности не принесла.
Edited by myst
Поправьте, если не прав, но полиси нужно вешать на физ. интрефейс, а на туннеле писать
qos pre-classify
Оно бы было так, НО, у туннелей разный BW,а полиси у меня с bandwidth percent я сомневаюсь что оно станет работать.
Темболее это направление output, тоесть трафика в туннель. Если я повешую полиси аутпут на физ интерфейс, направление будет инвертировано.
