Добрый день.
Есть проблема с SCE-2020.
SM manager держит 3203 сабскрайбера
su pcube -c 'cd ~;/opt/pcube/sm/server/bin/p3subsdb --show-num'
Total number of subscribers: 3203
Command terminated successfully
При этом на sce при синхронизации попадают не все
SCE2000#>sh interface L 0 subscriber all-names
There are 3144 subscribers in the data-base:
При ручной синхронизации
su pcube -c 'cd ~;/opt/pcube/sm/server/bin/p3sm --resync -n 001'
Error - Failed to synchronize 001
SCE 001 had errors during subscribers synchronization: failed to synchronize 176 subscribers
еще инфа...
su pcube -c 'cd ~;/opt/pcube/sm/server/bin/p3net --show -n 001'
Network Element Information:
Host:        192.168.1.100
Ip:          192.168.1.100
Port:        14374
Status:      Connection ready
Type:        SCE2000
Domain:      subscribers
Synchronization Status: Not-done(5% failures)
Redundancy Status: Standalone
Quarantine Status: ok
Лог sm-manager
"31-дек 2014", "15:01:30.927 YEKT","[mcn.SM[async-dispatcher]]",INFO ,"com.pcube.logger.userlog.UserLog","SM: 998 - operation failure (Subscribers database is full) on 001 (domain: subscribers)."
"31-дек 2014", "15:01:30.928 YEKT","[mcn.SM[async-dispatcher]]",ERROR,"com.pcube.management.smm.SePushSynchronizationTask","Error: Subscribers database is full (originalCode=20), while sync of 999 into 001/subscribers"
"31-дек 2014", "15:01:30.928 YEKT","[mcn.SM[async-dispatcher]]",INFO ,"com.pcube.logger.userlog.UserLog","SM: 999 - operation failure (Subscribers database is full) on 001 (domain: subscribers)."
"31-дек 2014", "15:01:31.027 YEKT","[smmSync(10)-001]",INFO ,"com.pcube.logger.userlog.UserLog","SM: Finished SM subscriber synchronization of 001 in subscribers domain (3115 subscribers, 88 failures)."
"31-дек 2014", "15:01:31.027 YEKT","[smmSync(10)-001]",INFO ,"com.pcube.management.smm.SePushSynchronizationTask","SMM synchronization of 001(192.168.1.100) finished. successful logins:3115 failed:88 rate:515.8138764696142 subscribers per second (88 relogins)"
"31-дек 2014", "15:01:31.027 YEKT","[smmSync(10)-001]",WARN ,"com.pcube.management.smm.SeSynchronizationTask","Failed to synchronize 001 - SCE 001 had errors during subscribers synchronization: failed to synchronize 176 subscribers"
Из него вычитал
Прошу подсказать почему так...
Такое началось после обесточивания sce.
Команду давал.. не помогает
SCE2000(config if)#>subscriber max-subscribers 40k
Сабскрайберов добавляю банально
su pcube -c 'cd ~;/opt/pcube/sm/server/bin/p3subs --set --subscriber=3404 --ip=172.16.167.12/30 --property=packageId=16 --overwrite'
Да, у меня в конфиге p3sm.conf разрешены сети, может они занимают много памяти в sce.
А может планка памяти RAM не определяется? Не хватает ОЗУ чтоб всех разместить...
Уж не знаю что думать.
Да, пару недель назад залил pp44. Но после все работало исправно.
SCE2000#>sh ver
System version: Version 4.0.0-classic Build 316
Build time: Jun 13 2013, 21:01:05 (Change-list 731199)
Software version is: Version 4.0.0-classic Build 316
Cryptography class: K9
Hardware information is:
rx            : 0x0079
dp            : 0x1d08
tx            : 0x1712
ff            : 0x0077
cls           : 0x1e05
cpld          : 0x0025
lic           : 0x0202
lic-drv       : 0x02020000
lic-prm       : 0x02020000
rev           : G001
Bootrom       : 2.1.0
L2 cache      : Samsung 0.5
lic type      : 4GBE
optic mode    : MM
Product S/N   : CAT09470XMF
Product ID    :
Version ID    :
Deviation     :
Part number       : 800-26601-03
Revision          : A0
Software revision : G001
LineCard S/N      : CAT09490X88
Power Supply type : AC
SML Application information is:
Application file: /tffs0/release_.sli
Application name: Engage SML Version 4.0.0 build 65 (Protocol Pack 44 build 28)
Using Lib - PL_V4.0.0PP_B316
Using Lib - Classifier_V4.0.0_B316
Application help: Entry point of Engage
Original source file: /auto/srbu-proj1-bgl/apps/users/uandhava/Autobuild400/App/SML/Engage/V4.0.0/src/com/pcube/AppTemplate/Main/template_app_main.san
Compilation date: Tue, December 02, 2014 at 15:38:41
Compiler version: SANc v3.20 Build 14 built on: Tue 08/04/2009 06:58:22.;SME plugin v1.1
Default capacity option used.
Logger status: Enabled
Platform: SCE2000 - 4xGBE
Management agent interface version: SCE Agent 4.0.0 Build 115
Software package file: ftp://ftpserver/F:\sce\scos-v400-b316-sce2000-classic-k9.pkg
SCE2000  uptime is 16 hours, 13 minutes, 39 seconds
Вот еще нарыл
SCE2000#>sh interf L 0 subscriber db counters
Current values:
Subscribers: 3143 used out of 199999 max.
Introduced/Pulled subscribers: 3143.
Anonymous subscribers: 0.
Subscribers with mappings: 3115 used out of 3115 max.
Single non-VPN IP mappings: 32.
Non-VPN IP Range mappings: 3083.
IP Range over VPN mappings: 0.
Single IP over VPN mappings: 0.
VLAN based VPNs with subscribers: 0 used out of 2047.
Subscribers with open sessions: 0.
Subscribers with TIR mappings: 0.
Sessions mapped to the default subscriber: 0.
Вижу что уперся в ограничение 3115. Подскажите что это?
Edited by sekuzz
На тестовой сейчас, сети не разрешены, все сабскрайберы в анонимной группе.
Current values:
Subscribers: 1231 used out of 199999 max.
Introduced/Pulled subscribers: 1.
Anonymous subscribers: 1230.
Subscribers with mappings: 1231 used out of 79999 max.
Single non-VPN IP mappings: 1231.
Non-VPN IP Range mappings: 0.
Subscribers with open sessions: 1007.
3.8.5 старушка. Мне кажется надо для начала ребутнуть да p3subsdb --clear-all накатить...
  • 2 weeks later...
Обновился до 4.1.0. стало все нормально. Видимо обновлением исправился где-то глюк.
DVM-Avgoor, спасибо за участие в решении проблемы.
