Flopster
Пользователи-
Posts
42 -
Joined
Last visited
About Flopster
Rank
Абитуриент
Контакты
ICQ
Array
Информация
Пол
Array
accel pptpd
Flopster replied to kisa's topic in Программное обеспечение, биллинг и *unix системы
accel pptpd
да. а что? -
accel pptpd
Oct 6 08:14:38 atlanta pptpd[1527]: CTRL: Starting call (launching pppd, opening GRE) Oct 6 08:14:38 atlanta pppd[1528]: Plugin /usr/lib/pptpd/pptpd-logwtmp.so loaded. Oct 6 08:14:38 atlanta pppd[1528]: pptpd-logwtmp: $Version$ Oct 6 08:14:38 atlanta pptp[1528]: Plugin pptp.so loaded. Oct 6 08:14:38 atlanta pptp[1528]: PPTP plugin version 0.8.4 compiled for pppd-, linux-2.6.18-164.11.1.el5xen Oct 6 08:14:38 atlanta pptp[1528]: pppd options in effect: Oct 6 08:14:38 atlanta pptp[1528]: debug # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: nodetach # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: nologfd # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: dump # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: plugin /usr/lib/pptpd/pptpd-logwtmp.so # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: plugin pptp.so # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: require-mschap-v2 # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: refuse-pap # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: refuse-mschap # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: name pptpd # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: pptp_client 188.4.49.173 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: pptp_sock 6 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: pptpd-original-ip 188.4.49.173 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: pptp_client 188.4.49.173 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: pptp_sock 6 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: asyncmap 0 # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: mru 800 # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: mtu 800 # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: novj # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: novjccomp # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: ipparam 188.4.49.173 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: ms-dns xxx # [don't know how to print value] # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: noproxyarp # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: 98.148.181.232:10.100.1.9 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: ms-dns xxx # [don't know how to print value] # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: noproxyarp # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: 98.148.181.232:10.100.1.9 # (from command line) Oct 6 08:14:38 atlanta pptp[1528]: nobsdcomp # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: require-mppe-128 # (from /etc/ppp/options.pptpd) Oct 6 08:14:38 atlanta pptp[1528]: pppd 2.4.4 started by root, uid 0 Oct 6 08:14:38 atlanta pptp[1528]: Using interface ppp8 Oct 6 08:14:38 atlanta pptp[1528]: Connect: ppp8 <--> pptp (188.4.49.173) Oct 6 08:14:41 atlanta pptpd[1527]: CTRL: Ignored a SET LINK INFO packet with real ACCMs! Oct 6 08:14:41 atlanta pptp[1528]: MPPE 128-bit stateless compression enabled Oct 6 08:14:44 atlanta pptp[1528]: Unsupported protocol 'IPv6 Control Protovol' (0x8057) received Oct 6 08:14:44 atlanta pptp[1528]: local IP address 98.148.181.232 Oct 6 08:14:44 atlanta pptp[1528]: remote IP address 10.100.1.9 Oct 6 08:14:44 atlanta pptp[1528]: pptpd-logwtmp.so ip-up ppp8 lefteris.a 188.4.49.173 Oct 6 08:14:44 atlanta kernel: ADDRCONF(NETDEV_CHANGE): ppp8: link becomes ready -
accel pptpd
вроде MPPC нету..стоит оригинальный акцел 0.8.4 после yum update & reboot начал тормозит и без MPPE. может дело в центосе? -
accel pptpd
скорость до наса нормалная. Abramm подсказал что если викенуть require-mppe-128 то все работаыет очень быстро. Проблема в том что из продакшена викенуть MPPE не могу. Есть идеи? -
accel pptpd
Так и не смог исправить проблему скоростей клиентов. Может ли кто нибудь помочь? Готов заплатить. -
accel pptpd
Если я в ручную опускаю MTU какого либо интерфейса до 500 (ifconfig ppp18 mtu 500) - его скорость резко прыгает до максимума (~600к). Если после этого я поднимаю MTU обратно до ~1200 все продолжает работать быстро. Но вот если просто виставить сначала 1200 или 1400 тормозит (~20к). -
accel pptpd
не 1500 а 500 очень странно что при очень низком MTU работает быстро а когда поднимаю резко падает скорость на низком MTU не могу остаться поскольку не работают сайти типа paypal. -
accel pptpd
Оказалось что если я вписываю в /etc/ppp/ip-up: ifconfig "$1" mtu 500 все работает очень бистро, но некоторые сайты не поднимаются.. ест идеи в чем дело? -
accel pptpd
первым делом просто - ethtool <iface> карточка-то на гиг поднялась или может только на 100? мало ли - глюкануло что-то при перезагрузке... первым делом снял image ubuntu через wget на сервер по гигабитному downlink-у сошло очень быстро [root@atlanta ~]# ethtool eth0 Settings for eth0: Link detected: yes -
accel pptpd
шейпера нету. подклучен на карточке 1гиг -
accel pptpd
cat /etc/ppp/options.pptpd name pptpd refuse-pap refuse-chap refuse-mschap require-mschap-v2 require-mppe-128 ms-dns 208.67.222.222 ms-dns 208.67.220.220 proxyarp nobsdcomp novj novjccomp nologfd -
Accel тормозит?
Flopster replied to Flopster's topic in Программное обеспечение, биллинг и *unix системы
accel pptpd
[root@atlanta ~]# ethtool -k eth0 Offload parameters for eth0: Cannot get device rx csum settings: Operation not supported Cannot get device udp large send offload settings: Operation not supported rx-checksumming: off tx-checksumming: on scatter-gather: on tcp segmentation offload: on udp fragmentation offload: off generic segmentation offload: off generic-receive-offload: off [root@atlanta ~]# ethtool -g eth0 Ring parameters for eth0: Cannot get device ring settings: Operation not supported [root@atlanta ~]# -
Accel тормозит?
[root@atlanta ~]# uname -r 2.6.18-164.11.1.el5xen
