спорить не буду. в /usr/lib есть две папки питона: 2.4 и 2.5. но.... в системе есть только питон 2.5собсно с модулями разобрался.
как оказалось, при установке были созданы папки и файлы с правами только на рута и маской 700. устанавливались при помощи easy_install2.5 .
по модулям вопросов на данный момент не имею.
остается только ошибка при запуске post-update:
noc@test-serv:~$ ./scripts/post-update
Traceback (most recent call last):
File "manage.py", line 11, in <module>
execute_manager(settings)
File "/var/lib/python-support/python2.5/django/core/management/__init__.py", line 340, in execute_manager
utility.execute()
File "/var/lib/python-support/python2.5/django/core/management/__init__.py", line 295, in execute
self.fetch_command(subcommand).run_from_argv(self.argv)
File "/var/lib/python-support/python2.5/django/core/management/base.py", line 192, in run_from_argv
self.execute(*args, **options.__dict__)
File "/var/lib/python-support/python2.5/django/core/management/base.py", line 218, in execute
self.validate()
File "/var/lib/python-support/python2.5/django/core/management/base.py", line 246, in validate
num_errors = get_validation_errors(s, app)
File "/var/lib/python-support/python2.5/django/core/management/validation.py", line 28, in get_validation_errors
for (app_name, error) in get_app_errors().items():
File "/var/lib/python-support/python2.5/django/db/models/loading.py", line 128, in get_app_errors
self._populate()
File "/var/lib/python-support/python2.5/django/db/models/loading.py", line 57, in _populate
self.load_app(app_name, True)
File "/var/lib/python-support/python2.5/django/db/models/loading.py", line 72, in load_app
mod = __import__(app_name, {}, {}, ['models'])
File "/opt/noc/main/models.py", line 107, in <module>
report_registry.register_all()
File "/opt/noc/lib/registry.py", line 51, in register_all
__import__(mb+f[:-3],{},{},self.classname)
ValueError: Empty module name
utility.execute()
File "/var/lib/python-support/python2.5/django/core/management/__init__.py", line 249, in fetch_command
klass = load_command_class(app_name, subcommand)
File "/var/lib/python-support/python2.5/django/core/management/__init__.py", line 67, in load_command_class
{}, {}, ['Command']), 'Command')()
File "/opt/noc/fm/management/commands/sync-rules.py", line 13, in <module>
from noc.fm.rules.classes import EventClass
File "/opt/noc/fm/rules/classes/__init__.py", line 10, in <module>
from noc.fm.models import EventCategory,EventPriority,EventClassVar,event_trigger_registry
File "/opt/noc/fm/models.py", line 10, in <module>
from noc.sa.models import ManagedObject
File "/opt/noc/sa/models.py", line 19, in <module>
profile_registry.register_all()
utility.execute()
self.validate()
self._populate()
руки конечно не оттуда растут. пойду пока что дальше ковыряццо. может опять гдето напортачил.
