Что то не так в работе кеша.
Схема такая:
Между сервером db2dhcp и клиентом стоит железяка с включенным dhcp_relay.
Клиент получает (51 Address Time 4 IP Address Lease Time)
code type value
51 2 60
UINT4 2 Четырёхбайтовое число.
%cat db2dhcp.conf
DHCPCacheTTL = 36000
DBType = MySQL
DBServerAddress = localhost
DBServerPort = 3306
log
2011-03-29 17:00:55 [40737:34376559296] Got DHCPDISCOVER (1) message from client 00:1B:11:B5:DE:D5 on em1/10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:00:55 [40737:34376559296] DEBUG: Adding DHCP message to empty queue 'DHCP requests'
2011-03-29 17:00:55 [40737:34376559296] DEBUG: Queue (DHCP requests) length now is: 1, new requests: 1
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Trying to get DHCP request from queue 'DHCP requests'.
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Parsing DHCP message and preparing SQL statement.
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Found network device variable: DEV-NETWORK-INT = "167843072"
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Found DHCP header variable: CLI-GIADDR = "0A010102"
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Found DHCP header variable: CLI-ETHER-ADDR = "001B11B5DED5"
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Found DHCP options variable: OPT82-REMOTE-ID = "001E58A92983"
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Found DHCP options variable: OPT82-PORT = "0F"
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Executing SQL statement "SELECT code, type, value FROM dhcp_subnets WHERE subnet = '167843072' and CONV('0A010102', 16, 10) = 0 UNION SELECT code, type, value FROM dhcp_clients_by_ether WHERE ether = '001B11B5DED5' AND '001E58A92983' = '' AND '0F' = '' UNION SELECT code, type, value FROM dhcp_clients_by_relay WHERE relay_id = '001E58A92983' AND relay_port = '0F' ORDER BY CODE"
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Fetched 4 rows, 3 fields from DB.
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Option 'DHCP server ID' is not set. Set server ID = 10.1.21.104 (interface IP address).
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Added response for client 00:1B:11:B5:DE:D5/10.1.1.252 (relay: 10.1.1.2) to DHCP cache.
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Adding DHCP message to empty queue 'Offers queue for device em1'
2011-03-29 17:00:55 [40737:34376865536] DEBUG: Queue (Offers queue for device em1) length now is: 1, new requests: 1
2011-03-29 17:00:55 [40737:34376865536] DEBUG: DHCP request removed from queue 'DHCP requests'. Queue len now is: 0, new requests: 0
2011-03-29 17:00:56 [40737:34376559296] Sending DHCPOFFER (2) to 00:1B:11:B5:DE:D5/10.1.1.252 via 10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:00:56 [40737:34376559296] DEBUG: DHCP request removed from queue 'Offers queue for device em1'. Queue len now is: 0, new requests: 0
2011-03-29 17:00:56 [40737:34376559296] Got DHCPREQUEST (3) message from client 00:1B:11:B5:DE:D5 on em1/10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:00:56 [40737:34376559296] DEBUG: Adding DHCP message to empty queue 'DHCP requests'
2011-03-29 17:00:56 [40737:34376559296] DEBUG: Queue (DHCP requests) length now is: 1, new requests: 1
2011-03-29 17:00:56 [40737:34376865088] DEBUG: Trying to get DHCP request from queue 'DHCP requests'.
2011-03-29 17:00:56 [40737:34376865088] Found response for client 00:19:5B:14:7D:82 from relay 10.1.1.2 in DHCP cache.
2011-03-29 17:00:56 [40737:34376865088] DEBUG: Adding DHCP message to empty queue 'Ack queue for device em1'
2011-03-29 17:00:56 [40737:34376865088] DEBUG: Queue (Ack queue for device em1) length now is: 1, new requests: 1
2011-03-29 17:00:56 [40737:34376865088] DEBUG: DHCP request removed from queue 'DHCP requests'. Queue len now is: 0, new requests: 0
2011-03-29 17:00:56 [40737:34376559296] DEBUG: Trying to get DHCP request from queue 'Ack queue for device em1'.
2011-03-29 17:00:56 [40737:34376559296] Sending DHCPACK (5) to 00:1B:11:B5:DE:D5/10.1.1.252 via 10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:00:56 [40737:34376559296] DEBUG: DHCP request removed from queue 'Ack queue for device em1'. Queue len now is: 0, new requests: 0
2011-03-29 17:01:57 [40737:34376559296] Got DHCPDISCOVER (1) message from client 00:1B:11:B5:DE:D5 on em1/10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:01:57 [40737:34376559296] DEBUG: Adding DHCP message to empty queue 'DHCP requests'
2011-03-29 17:01:57 [40737:34376559296] DEBUG: Queue (DHCP requests) length now is: 1, new requests: 1
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Trying to get DHCP request from queue 'DHCP requests'.
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Flushing cache: last flush ts - 1301396448, flush period - 60, now is 1301396517.
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Cache flushed. Total 0 nodes deleted.
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Parsing DHCP message and preparing SQL statement.
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Found network device variable: DEV-NETWORK-INT = "167843072"
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Found DHCP header variable: CLI-GIADDR = "0A010102"
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Found DHCP header variable: CLI-ETHER-ADDR = "001B11B5DED5"
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Found DHCP options variable: OPT82-REMOTE-ID = "001E58A92983"
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Found DHCP options variable: OPT82-PORT = "0F"
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Executing SQL statement "SELECT code, type, value FROM dhcp_subnets WHERE subnet = '167843072' and CONV('0A010102', 16, 10) = 0 UNION SELECT code, type, value FROM dhcp_clients_by_ether WHERE ether = '001B11B5DED5' AND '001E58A92983' = '' AND '0F' = '' UNION SELECT code, type, value FROM dhcp_clients_by_relay WHERE relay_id = '001E58A92983' AND relay_port = '0F' ORDER BY CODE"
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Fetched 4 rows, 3 fields from DB.
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Option 'DHCP server ID' is not set. Set server ID = 10.1.21.104 (interface IP address).
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Update cached data for client 00:1B:11:B5:DE:D5/10.1.1.252.
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Adding DHCP message to empty queue 'Offers queue for device em1'
2011-03-29 17:01:57 [40737:34376864640] DEBUG: Queue (Offers queue for device em1) length now is: 1, new requests: 1
2011-03-29 17:01:57 [40737:34376864640] DEBUG: DHCP request removed from queue 'DHCP requests'. Queue len now is: 0, new requests: 0
2011-03-29 17:01:57 [40737:34376559296] Sending DHCPOFFER (2) to 00:1B:11:B5:DE:D5/10.1.1.252 via 10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:01:57 [40737:34376559296] DEBUG: DHCP request removed from queue 'Offers queue for device em1'. Queue len now is: 0, new requests: 0
2011-03-29 17:01:58 [40737:34376559296] Got DHCPREQUEST (3) message from client 00:1B:11:B5:DE:D5 on em1/10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:01:58 [40737:34376559296] DEBUG: Adding DHCP message to empty queue 'DHCP requests'
2011-03-29 17:01:58 [40737:34376559296] DEBUG: Queue (DHCP requests) length now is: 1, new requests: 1
2011-03-29 17:01:58 [40737:34376864192] DEBUG: Trying to get DHCP request from queue 'DHCP requests'.
2011-03-29 17:01:58 [40737:34376864192] Found response for client 00:19:5B:14:7D:82 from relay 10.1.1.2 in DHCP cache.
2011-03-29 17:01:58 [40737:34376864192] DEBUG: Adding DHCP message to empty queue 'Ack queue for device em1'
2011-03-29 17:01:58 [40737:34376864192] DEBUG: Queue (Ack queue for device em1) length now is: 1, new requests: 1
2011-03-29 17:01:58 [40737:34376864192] DEBUG: DHCP request removed from queue 'DHCP requests'. Queue len now is: 0, new requests: 0
2011-03-29 17:01:58 [40737:34376559296] DEBUG: Trying to get DHCP request from queue 'Ack queue for device em1'.
2011-03-29 17:01:58 [40737:34376559296] Sending DHCPACK (5) to 00:1B:11:B5:DE:D5/10.1.1.252 via 10.1.21.104 (relay 10.1.1.2)
2011-03-29 17:01:58 [40737:34376559296] DEBUG: DHCP request removed from queue 'Ack queue for device em1'. Queue len now is: 0, new requests: 0
OS: FreeBSD 8.1-RELEASE
%ldd db2dhcp
libmysqlclient.so.16 => /usr/local/lib/mysql/libmysqlclient.so.16 (0x800658000)
libcrypt.so.5 => /lib/libcrypt.so.5 (0x8007ce000)
libm.so.5 => /lib/libm.so.5 (0x8008e7000)
libz.so.5 => /lib/libz.so.5 (0x800a06000)
libpcap.so.7 => /lib/libpcap.so.7 (0x800b1b000)
libthr.so.3 => /lib/libthr.so.3 (0x800c4c000)
libc.so.7 => /lib/libc.so.7 (0x800d64000)
