Всем добрый день !
Есть проблема с получением Клиентским компьютером после ONU-шки DHCP адреса.
Если что то не так ткните носом.
железка :BDCOM P3310C Software, Version 10.1.0D Build 33463
Настройка :
epon onu-config-template T1
cmd-sequence 1 epon onu port 1 ctc vlan mode tag 1505
cmd-sequence 2 epon onu port 1 ctc mcst mc-vlan add 730
cmd-sequence 3 epon onu port 1 ctc mcst tag-stripe enable
cmd-sequence 4 switchport port-security mode dynamic
cmd-sequence 5 switchport port-security dynamic maximum 2
cmd-sequence 6 epon onu port 1 ctc rate-limit 1024 ingress
cmd-sequence 7 epon onu port 1 ctc rate-limit 1024 egress
cmd-sequence 8 epon fec enable
cmd-sequence 9 exit
cmd-sequence 10 exit
cmd-sequence 11 write
interface GigaEthernet0/3
description ==== UP - OFFICE ====
switchport trunk vlan-allowed 50,730,999,1505-1508
switchport trunk vlan-untagged none
switchport mode trunk
switchport pvid 730
dhcp snooping trust
arp inspection trust
ip-source trust
fiber-auto-config
interface EPON0/1
epon onu-authen-method manual
epon mpcp-registration-mode ctc 30
epon pre-config-template T1 binded-onu-llid 1-64
epon bind-onu mac fcfa.f7c5.49d1 1
epon bind-onu mac c8e7.d8f6.5fea 2
epon bind-onu mac e067.b30b.2f54 3
epon bind-onu mac a0c6.ec03.8bcd 4
epon bind-onu mac 1c87.7911.d90d 5
epon bind-onu mac 1c87.7911.d90a 6
switchport trunk vlan-allowed 50,730,1505
switchport pvid 1505
ip-source trust
ip access-group Clients-Netbios
switchport protected
epon fec-rx
epon fec-tx
epon error-frame-alarm
interface EPON0/1:4
epon fec enable
epon onu port 1 ctc rate-limit 61440 ingress
epon onu port 1 ctc rate-limit 61440 egress
epon sla upstream pir 61440 cir 1000
epon sla downstream pir 61440 cir 1000
ip dhcp-relay snooping
ip dhcp-relay snooping vlan 50,999,1505-1508
ip arp inspection vlan 50,999,1505-1508
ip verify source vlan 50,999,1505-1508
ip dhcp-relay snooping information option format hn-type host
ip dhcp-relay agent
ip dhcp-relay helper-address 10.255.253.7 vlan 50,999,1505-1508
ip dhcp-relay snooping log
на сервере вижу запросы и ответы по DHCP, а вот до клиента не доходят.
P.s. причем в работе стоит "B" версия - там полет нормальный
