Здравствуйте! Роутер DIR 300 B3 от билайн в результате ошибки при прошивке (залил прошивку от ревизии B5) умер. При подключении питания загорается на короткое время зеленым цветом лампа питания и тухнет. В аварийный режим не заходит, на нажатие reset не реагирует. При подключении USB UART выдает:
U-Boot 1.1.3 (Feb 24 2011 - 11:12:27)
Board: Ralink APSoC DRAM: 32 MB
relocate_code Pointer at: 81fb0000
config usb..*** Error: D+/D- is 1/1, config usb failed.
Set info->start[0]=BF000000
flash_protect ON: from 0xBF000000 to 0xBF01E727
flash_protect ON: from 0xBF030000 to 0xBF030FFF
Ralink UBoot Version: 3.5.2.0
ASIC 3052_MP2 (Port5<->None)
DRAM component: 256 Mbits SDR
DRAM bus: 16 bit
Total memory: 32 MBytes
Flash component: NOR Flash
Date:Feb 24 2011 Time:11:12:27
icache: sets:256, ways:4, linesz:32 ,total:32768
dcache: sets:128, ways:4, linesz:32 ,total:16384
##### The CPU freq = 320 MHZ ####
estimate memory size =32 Mbytes
Please choose the operation:
1: Load system code to SDRAM via TFTP.
2: Load system code then write to Flash via TFTP.
3: Boot system code via Flash (default).
4: Entr boot command line interface.
7: Load Boot Loader code then write to Flash via Serial.
9: Load Boot Loader code then write to Flash via TFTP. 0
3: System Boot system code via Flash.
## Booting image at bf050000 ...
Image Name: DIR_300NRUB5
Created: 2011-04-15 7:56:52 UTC
Image Type: MIPS Linux Kernel Image (lzma compressed)
Data Size: 2949056 Bytes = 2.8 MB
Load Address: 80000000
Entry Point: 8024e000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
No initrd
## Transferring control to Linux (at address 8024e000) ...
## Giving linux memsize in MB, 32
Starting kernel ...
bXО\╘З8гтпбp\ТтГн╟bЄ.КТхrдф0NжыжфЄєd!pN7nL8c┌oФїGрфЄ─1]З=дТ┬уaЫcжфЄР│ЪMдяM≤|р.f▌cжфЄТаЧюёbд
ддющ;/~жТД1bб6NдлЇФL≤j=т+└жТД1bбЖN╦{зG┘Й╪wO rФДю·)еЦ~©уaЫcрфЄдXlЮс╦7┐Чn[rОSРж*Ш[v│БOмяaЩGрфЄтl█jЄwпэcюп Ні?╡3КТхrдф~l╘j
зs
│glпkL3╘ш╗▌cжфЄтэoNAAд╦vN·bMMXFЮсzълТ9rДдaNЪcі"┌зw
]ЭБOеЧL╨r,f▌cжфЄпщфXrд\аkф5FджыжфЄ■│nLlаЦO+Fю≤Цт8Fп│з═▌cжфЄп╨│Ш°вюТ┴rФдЄ.КТхVдф╡БMа~Дб╟x─жхШ-┬~жx
Дд┌#│bаЦ╩Фї■д┬~ПЗКпЭ├mО_│РІЧлТ9rддв~пmж;є>]ДПrДД╚fL
ЬХТД5bфьL╨vlmж;Й°Нёb·ОбтCb-ПХТД┐bфьbтДОЙТдoіДюВN\LфЦ_f,ф└k█уХТДхbфдтдб
фддw^ялТ9rдддДдб
фдд3БЬчХтФ9Vд1дтдф
ддд?|│яХтФ9FддтдфдддsO█ялТ9rДддТдб
ддд;k,Ч}{ждф╬г ЬL█y·ЧL~ЬХТДлbфЇОЮ╦З
ТТ#fJ
ТL≤Б;▐.пюVХТД▄Fфт·w
ЧБ] і,аn,ПлТ9rфдaь~б8c╪Fn│ШMПЗфжюХТДёFф@Тwj]AЭлТД╚Fф│jЮдюдддVФї■Д┬~жКП·WШMДdю╬jфаг бx
ПХТД╚b├█VбфдтЮДюYCЭФї■Тё~Баk<MoNфдфдюрРВk╦^дд1bЮ└жm█Й]чёFЭжЫkфЄю┘c■fLЭС|НІЄYж╬zGЄдддТдфдю■уХТД┬Fфдддб
ддд█уХТДхbфдтдб
фддw^ялТ9rдддДдб
фдд3БЬчХтФ9Vд1дтдф
ТТ#fJ
ТL≤Б;▐.пюVХТД▄Fфт·w
│znН_А<ТХтфФдЄТ?>дяд┬Ф_┴C>ДюbТС6дП^рwїСлТ9rДдQ]зbдФп[дёbдп7гжпюYф╩ХТДддэ█rТд┴&3n
д┐rэфяп#
хJПХтфрдЄРXРM│zЮЭН/ЧХТД1Fф3y~ёFІЧХТД╠bфР·7gLцгЄЧХТД1bфIР│oП≤lLН{MТХтфр9FA 6й·Нm{m│⌠КMПХТДДдл ░АoL7sРиг]MмшЧЖКLагаbДр╪Fра`l<?шЧХТYДДд╠аk[╛mавБ·Gl┘zтq^▀ФїJbдбЖN≤r╛
m^б9Ф░цє}\cc~╬ъ~j-ПL|╩Фї■тё~рWЗM╦3Ьш~жхъТёZПьG
ьSшЧ}_ж:cЄжcN7{,·y{ж:GЄю─0_з7~N█З╩ХТД9FфюЮMР│,]cПлТДфдюЗЭОM┌ХтфЖ┬F!ґС°w\█З
^FТ─КM+bдзчХтфр▄FKl█Рёчд═o│НLЖ╦j&ТсjMП~ЭлТ9rФдяІ 8{l-ЧФNФыфдСL;r░дb
*÷·УХТ=VддI\╔bLХТД1bф▓Ц3і4OЗЦmnЄ>Ж▄_дЄ╡b)]│Ф|?boNЭХТДддэ3l█ЦН_А,ЧлТ9rдд▒д╨BРТ|3одv\7bж7]srmL{~.oжzGКLагаbДр╪Fра`l<?шЧХТYДДд╠аk[╛mавБ·Gl┘zтq^▀ФїJbдбЖN≤r╛
m^б9Ф░цє}\cc~╬ъ~j-П
При входе в режим 4 и команде printenv выдает:
You choosed 4
4: System Enter Boot Command Line Interface.
RT3052 # printenv
bootcmd=tftp
bootdelay=1
baudrate=57600
serverip=10.10.10.3
preboot=echo;echo
ramargs=setenv bootargs root=/dev/ram rw
addip=setenv bootargs $(bootargs) ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname):$(netdev):off
addmisc=setenv bootargs $(bootargs) console=ttyS0,$(baudrate) ethaddr=$(ethaddr) panic=1
flash_self=run ramargs addip addmisc;bootm $(kernel_addr) $(ramdisk_addr)
kernel_addr=BFC40000
u-boot=u-boot.bin
load=tftp 8A100000 $(u-boot)
u_b=protect off 1:0-1;era 1:0-1;cp.b 8A100000 BC400000 $(filesize)
loadfs=tftp 8A100000 root.cramfs
u_fs=era bc540000 bc83ffff;cp.b 8A100000 BC540000 $(filesize)
test_tftp=tftp 8A100000 root.cramfs;run test_tftp
ethact=Eth0 (10/100-M)
ipaddr=10.10.10.123
stdin=serial
stdout=serial
stderr=serial
Environment size: 755/4092 bytes
RT3052 #
Дефолтный ip вообще не определялся и я руками прописал ipaddr=10.10.10.123 но это ни к чему не привело и через tftp прошивки не заливаются так как сеть неопознанная и не пингуется.
Подскажите пожалуйста как оживить роутер!!!!!
