vlalud
Новичок
  • Content Count
  • Joined
  • Last visited
About vlalud
  • Rank
    Абитуриент
  1. Здравствуйте! Роутер DIR 300 B3 от билайн в результате ошибки при прошивке (залил прошивку от ревизии B5) умер. При подключении питания загорается на короткое время зеленым цветом лампа питания и тухнет. В аварийный режим не заходит, на нажатие reset не реагирует. При подключении USB UART выдает: U-Boot 1.1.3 (Feb 24 2011 - 11:12:27) Board: Ralink APSoC DRAM: 32 MB relocate_code Pointer at: 81fb0000 config usb..*** Error: D+/D- is 1/1, config usb failed. ..*** Error: D+/D- is 1/1, config usb failed. Set info->start[0]=BF000000 flash_protect ON: from 0xBF000000 to 0xBF01E727 flash_protect ON: from 0xBF030000 to 0xBF030FFF ============================================ Ralink UBoot Version: 3.5.2.0 -------------------------------------------- ASIC 3052_MP2 (Port5<->None) DRAM component: 256 Mbits SDR DRAM bus: 16 bit Total memory: 32 MBytes Flash component: NOR Flash Date:Feb 24 2011 Time:11:12:27 ============================================ icache: sets:256, ways:4, linesz:32 ,total:32768 dcache: sets:128, ways:4, linesz:32 ,total:16384 ##### The CPU freq = 320 MHZ #### estimate memory size =32 Mbytes Please choose the operation: 1: Load system code to SDRAM via TFTP. 2: Load system code then write to Flash via TFTP. 3: Boot system code via Flash (default). 4: Entr boot command line interface. 7: Load Boot Loader code then write to Flash via Serial. 9: Load Boot Loader code then write to Flash via TFTP. 0 3: System Boot system code via Flash. ## Booting image at bf050000 ... Image Name: DIR_300NRUB5 Created: 2011-04-15 7:56:52 UTC Image Type: MIPS Linux Kernel Image (lzma compressed) Data Size: 2949056 Bytes = 2.8 MB Load Address: 80000000 Entry Point: 8024e000 Verifying Checksum ... OK Uncompressing Kernel Image ... OK No initrd ## Transferring control to Linux (at address 8024e000) ... ## Giving linux memsize in MB, 32 Starting kernel ... bXО\╘З8гтпбp\ТтГн╟bЄ.КТхrдф0NжыжфЄєd!pN7nL8c┌oФїGрфЄ─1]З=дТ┬уaЫcжфЄР│ЪMдяM≤|р.f▌cжфЄТаЧюёbд ддющ;/~жТД1bб6NдлЇФL≤j=т+└жТД1bбЖN╦{зG┘Й╪wO rФДю·)еЦ~©уaЫcрфЄдXlЮс╦7┐Чn[rОSРж*Ш[v│БOмяaЩGрфЄтl█jЄwпэcюп Ні?╡3КТхrдф~l╘j зs │glпkL3╘ш╗▌cжфЄтэoNAAд╦vN·bMMXFЮсzълТ9rДдaNЪcі"┌зw ]ЭБOеЧL╨r,f▌cжфЄпщфXrд\аkф5FджыжфЄ■│nLlаЦO+Fю≤Цт8Fп│з═▌cжфЄп╨│Ш°вюТ┴rФдЄ.КТхVдф╡БMа~Дб╟x─жхШ-┬~жx Дд┌#│bаЦ╩Фї■д┬~ПЗКпЭ├mО_│РІЧлТ9rддв~пmж;є>]ДПrДД╚fL ЬХТД5bфьL╨vlmж;Й°Нёb·ОбтCb-ПХТД┐bфьbтДОЙТдoіДюВN\LфЦ_f,ф└k█уХТДхbфдтдб фддw^ялТ9rдддДдб фдд3БЬчХтФ9Vд1дтдф ддд?|│яХтФ9FддтдфдддsO█ялТ9rДддТдб ддд;k,Ч}{ждф╬г ЬL█y·ЧL~ЬХТДлbфЇОЮ╦З ТТ#fJ ТL≤Б;▐.пюVХТД▄Fфт·w ЧБ] і,аn,ПлТ9rфдaь~б8c╪Fn│ШMПЗфжюХТДёFф@Тwj]AЭлТД╚Fф│jЮдюдддVФї■Д┬~жКП·WШMДdю╬jфаг бx ПХТД╚b├█VбфдтЮДюYCЭФї■Тё~Баk<MoNфдфдюрРВk╦^дд1bЮ└жm█Й]чёFЭжЫkфЄю┘c■fLЭС|НІЄYж╬zGЄдддТдфдю■уХТД┬Fфдддб ддд█уХТДхbфдтдб фддw^ялТ9rдддДдб фдд3БЬчХтФ9Vд1дтдф ддд?|│яХтФ9FддтдфдддsO█ялТ9rДддТдб ддд;k,Ч}{ждф╬г ЬL█y·ЧL~ЬХТДлbфЇОЮ╦З ТТ#fJ ТL≤Б;▐.пюVХТД▄Fфт·w │znН_А<ТХтфФдЄТ?>дяд┬Ф_┴C>ДюbТС6дП^рwїСлТ9rДдQ]зbдФп[дёbдп7гжпюYф╩ХТДддэ█rТд┴&3n д┐rэфяп# хJПХтфрдЄРXРM│zЮЭН/ЧХТД1Fф3y~ёFІЧХТД╠bфР·7gLцгЄЧХТД1bфIР│oП≤lLН{MТХтфр9FA 6й·Нm{m│⌠КMПХТДДдл ░АoL7sРиг]MмшЧЖКLагаbДр╪Fра`l<?шЧХТYДДд╠аk[╛mавБ·Gl┘zтq^▀ФїJbдбЖN≤r╛ m^б9Ф░цє}\cc~╬ъ~j-ПL|╩Фї■тё~рWЗM╦3Ьш~жхъТёZПьG ьSшЧ}_ж:cЄжcN7{,·y{ж:GЄю─0_з7~N█З╩ХТД9FфюЮMР│,]cПлТДфдюЗЭОM┌ХтфЖ┬F!ґС°w\█З ^FТ─КM+bдзчХтфр▄FKl█Рёчд═o│НLЖ╦j&ТсjMП~ЭлТ9rФдяІ 8{l-ЧФNФыфдСL;r░дb *÷·УХТ=VддI\╔bLХТД1bф▓Ц3і4OЗЦmnЄ>Ж▄_дЄ╡b)]│Ф|?boNЭХТДддэ3l█ЦН_А,ЧлТ9rдд▒д╨BРТ|3одv\7bж7]srmL{~.oжzGКLагаbДр╪Fра`l<?шЧХТYДДд╠аk[╛mавБ·Gl┘zтq^▀ФїJbдбЖN≤r╛ m^б9Ф░цє}\cc~╬ъ~j-П При входе в режим 4 и команде printenv выдает: You choosed 4 0 4: System Enter Boot Command Line Interface. U-Boot 1.1.3 (Feb 24 2011 - 11:12:27) RT3052 # printenv bootcmd=tftp bootdelay=1 baudrate=57600 serverip=10.10.10.3 preboot=echo;echo ramargs=setenv bootargs root=/dev/ram rw addip=setenv bootargs $(bootargs) ip=$(ipaddr):$(serverip):$(gatewayip):$(netmask):$(hostname):$(netdev):off addmisc=setenv bootargs $(bootargs) console=ttyS0,$(baudrate) ethaddr=$(ethaddr) panic=1 flash_self=run ramargs addip addmisc;bootm $(kernel_addr) $(ramdisk_addr) kernel_addr=BFC40000 u-boot=u-boot.bin load=tftp 8A100000 $(u-boot) u_b=protect off 1:0-1;era 1:0-1;cp.b 8A100000 BC400000 $(filesize) loadfs=tftp 8A100000 root.cramfs u_fs=era bc540000 bc83ffff;cp.b 8A100000 BC540000 $(filesize) test_tftp=tftp 8A100000 root.cramfs;run test_tftp ethact=Eth0 (10/100-M) ipaddr=10.10.10.123 stdin=serial stdout=serial stderr=serial Environment size: 755/4092 bytes RT3052 # Дефолтный ip вообще не определялся и я руками прописал ipaddr=10.10.10.123 но это ни к чему не привело и через tftp прошивки не заливаются так как сеть неопознанная и не пингуется. Подскажите пожалуйста как оживить роутер!!!!!
