Это решается:
/ip firewall mangle
add action=mark-connection chain=prerouting comment=Incoming_LN_connection connection-state=new in-interface=ether5-gateway new-connection-mark=LN_Route passthrough=no
add action=mark-connection chain=prerouting comment=Incoming_KS_connection connection-state=new in-interface=ether1-gateway new-connection-mark=KS_Route passthrough=no
add action=mark-routing chain=output comment=Mark_Out_LN_routing connection-mark=LN_Route new-routing-mark=LN_Route passthrough=no
add action=mark-routing chain=output comment=Mark_Out_KS_routing connection-mark=KS_Route new-routing-mark=KS_Route passthrough=no
/ip route
add distance=1 gateway="ln_gw" routing-mark=LN_Route
add distance=1 gateway="ks_gw" routing-mark=KS_Route
(1 и 5 порты на разных провайдеров)
/ip firewall mangle
add action=mark-connection chain=postrouting comment=Outgoing_LN_connection connection-state=new new-connection-mark=LN_Route out-interface=ether5-gateway passthrough=no
add action=mark-connection chain=postrouting comment=Outgoing_KS_connection connection-state=new new-connection-mark=KS_Route out-interface=ether1-gateway passthrough=no
add action=mark-routing chain=prerouting comment=Mark_from_bridge_LN_routing connection-mark=LN_Route in-interface=bridge-local new-routing-mark=LN_Route passthrough=no
add action=mark-routing chain=prerouting comment=Mark_from_bridge_KS_routing connection-mark=KS_Route in-interface=bridge-local new-routing-mark=KS_Route passthrough=no
/ip route
add comment="yandex test route LN" distance=1 dst-address=213.180.193.3/32 gateway="ln_gw"
add comment="yandex blackhole" distance=20 dst-address=213.180.193.3/32 type=unreachable
add comment="yandex test route KS" distance=1 dst-address=213.180.204.3/32 gateway="ks_gw"
add comment="yandex blackhole" distance=20 dst-address=213.180.204.3/32 type=unreachable
/tool netwatch
add comment="yandex 213.180.193.3 over LN route" down-script="/system script run router0_down" host=213.180.193.3 interval=10s timeout=5s up-script="/system script run router0_up"
add comment="yandex 213.180.203.3 over KS route" down-script="/system script run router1_down" host=213.180.204.3 interval=10s timeout=5s up-script="/system script run router1_up"
/system script
add name=router1_down policy=ftp,read,write,policy,test,password source="
\n:if ([/ping 213.180.204.3 count=5] = 0) do={\
\n:log warning (\"KS router \$KSgateway DOWN, route is BAD, change route!!! :-(\");\
\n/tool sms send usb1 +xxx message=\"\$[/system clock get date]_\$[/system clock get time] :-( KS router \$KSgateway DOWN, route is BAD, change route!!! :-(\"\
\n:global router1 \"Down\";\
\n/ip dhcp-client set 0 default-route-distance=20;\ у меня маршруты по dhcp, у вас может быть статическим, тогда вы на нем меняете distance
\n:foreach i in=[/ip firewall connection find connection-mark=\"KS_Route\"] do={/ip firewall connection remove \$i};\ пристреливаются все сессии
\n/ip dhcp-client renew 0;\
\n:if ([:pick [/system clock get time] 0 2]>7) do={\
\n:beep frequency=900 length=200ms;\
\n:delay 200ms;\
\n:beep frequency=600 length=200ms;\
\n:delay 200ms;\
\n:beep frequency=300 length=200ms;\
\n}}"
аналогично скрипты router0_down router0_up router1_up
