siniy1388
Новичок-
Публикации
6 -
Зарегистрирован
Посещение
О siniy1388
Звание
Абитуриент
Mikrotik конфигурация белой сети, proxy ARP
тему ответил в iSasha пользователя siniy1388 в Mikrotik коммутаторы и маршрутизаторы
[siniy1388_1@budka_troll_24_2] > export compact # nov/12/2019 12:38:28 by RouterOS 6.43 # # model = 750GL /interface bridge add fast-forward=no mtu=1500 name=bridge1 protocol-mode=none /interface ethernet set [ find default-name=ether1 ] arp=proxy-arp speed=100Mbps set [ find default-name=ether2 ] speed=100Mbps set [ find default-name=ether3 ] rx-flow-control=on speed=100Mbps tx-flow-control=on set [ find default-name=ether4 ] advertise=10M-half,10M-full,100M-half rx-flow-control=on speed=100Mbps tx-flow-control=on set [ find default-name=ether5 ] auto-negotiation=no speed=100Mbps /interface vlan add interface=ether1 name=vlan101 vlan-id=101 add interface=ether1 name=vlan104 vlan-id=104 add interface=ether1 name=vlan105 vlan-id=105 /interface ethernet switch port set 0 default-vlan-id=0 vlan-mode=fallback set 1 default-vlan-id=0 vlan-mode=fallback set 2 default-vlan-id=0 vlan-mode=fallback set 3 default-vlan-id=0 vlan-mode=fallback set 5 default-vlan-id=0 vlan-mode=fallback /interface wireless security-profiles set [ find default=yes ] supplicant-identity=MikroTik /ip ipsec proposal set [ find default=yes ] enc-algorithms=3des /ppp profile add change-tcp-mss=yes local-address=10.2.0.1 name=Tariff_1/0.5 only-one=yes rate-limit=512k/1024k use-compression=no use-encryption=no use-mpls=no add change-tcp-mss=yes local-address=10.2.0.1 name=Traff_2/1 only-one=yes rate-limit=1M/2M use-compression=no use-encryption=no use-mpls=no add change-tcp-mss=yes local-address=10.2.0.1 name=Tarif_5/3 only-one=yes rate-limit=3M/5M use-compression=no use-encryption=no use-mpls=no add change-tcp-mss=yes comment="Tarif_100/100 admin" local-address=10.2.0.1 name=Tarif_100/100 only-one=yes rate-limit=15M/15M use-compression=no \ use-encryption=no use-mpls=no add change-tcp-mss=yes local-address=10.2.0.1 name=Traff_3/2 only-one=yes rate-limit=2M/3M use-compression=no use-encryption=no use-mpls=no add change-tcp-mss=yes comment=Tarif_5/5 local-address=10.2.0.1 name=Tarif_5/5 only-one=yes rate-limit=6M/6M use-compression=no use-encryption=no use-mpls=no add change-tcp-mss=yes comment=Tarif_10. local-address=10.2.0.1 name=Tarif_10./10 only-one=yes rate-limit=10M/10M use-compression=no use-encryption=no \ use-mpls=no add change-tcp-mss=yes local-address=10.2.0.1 name=Tarif_6/3 only-one=yes rate-limit=3M/6M use-compression=no use-encryption=no use-mpls=no add change-tcp-mss=yes local-address=10.2.0.1 name=Traff_0 only-one=yes rate-limit=0M/0M use-compression=no use-encryption=no use-mpls=no add change-tcp-mss=yes comment=Tarif_15 local-address=10.2.0.1 name=Tarif_15./15 only-one=yes rate-limit=15M/15M use-compression=no use-encryption=no \ use-mpls=no add change-tcp-mss=yes comment=Tarif_20 local-address=10.2.0.1 name=Tarif_20./20 only-one=yes rate-limit=20M/20M use-compression=no use-encryption=no \ use-mpls=no /queue type set 0 pfifo-limit=500 set 1 pfifo-limit=500 set 9 pfifo-limit=500 /snmp community set [ find default=yes ] addresses=0.0.0.0/0 /system logging action set 0 memory-lines=10000 /interface bridge port add bridge=bridge1 hw=no interface=ether3 add bridge=bridge1 hw=no interface=ether4 add bridge=bridge1 hw=no interface=ether2 add bridge=bridge1 hw=no interface=ether5 /interface pppoe-server server add default-profile=Tariff_1/0.5 disabled=no interface=bridge1 keepalive-timeout=30 max-mru=1480 max-mtu=1480 one-session-per-host=yes service-name=service1 /interface pptp-server server set authentication=pap,chap,mschap1,mschap2 enabled=yes /ip address add address=192.168.1.2/24 interface=bridge1 network=192.168.1.0 add address=xxx.xxx.222.138/29 interface=ether1 network=xxx.xxx.222.136 add address=192.168.2.1/24 disabled=yes network=192.168.2.0 add address=xxx.xxx.217.130 disabled=yes interface=ether1 network=xxx.xxx.217.130 add address=xxx.xxx.217.1 interface=vlan101 network=xxx.xxx.217.130 add address=xxx.xxx.217.1 interface=vlan104 network=xxx.xxx.217.131 add address=xxx.xxx.217.1 interface=vlan105 network=xxx.xxx.217.132 /ip dhcp-client add default-route-distance=2 dhcp-options=hostname,clientid interface=ether1 /ip dns set servers=83.149.24.244,83.149.24.243 /ip firewall filter add action=drop chain=input dst-port=445 in-interface=ether1 protocol=tcp add action=drop chain=input dst-port=53 in-interface=ether1 protocol=udp add action=drop chain=input dst-port=53 in-interface=ether1 protocol=tcp add action=drop chain=input dst-port=445 in-interface=ether1 protocol=udp add action=drop chain=input comment=Dudiki src-address-list=Dudiki add action=add-src-to-address-list address-list="" address-list-timeout=none-dynamic chain=input disabled=yes protocol=tcp add action=drop chain=forward comment=spammer1 dst-port=25 protocol=tcp src-address-list=spammer add action=add-dst-to-address-list address-list=spammer address-list-timeout=1d chain=forward comment=spaamer2 connection-limit=30,32 disabled=yes dst-port=\ 25 limit=50,5:packet protocol=tcp src-address-list=!spammer add action=accept chain=forward comment="Access Internet From VLAN" disabled=yes src-address=xxx.xxx.217.0/24 /ip firewall nat add action=accept chain=srcnat src-address=xxx.xxx.222.139 add action=accept chain=srcnat src-address=xxx.xxx.222.141 add action=accept chain=srcnat src-address=xxx.xxx.222.140 add action=accept chain=srcnat src-address=xxx.xxx.222.142 add action=accept chain=srcnat disabled=yes src-address=xxx.xxx.217.131 add action=accept chain=srcnat disabled=yes src-address=xxx.xxx.217.132 add action=accept chain=srcnat disabled=yes src-address=xxx.xxx.217.130 add action=masquerade chain=srcnat add action=dst-nat chain=dstnat comment="Off Trooleyb 1.108" dst-port=8108 protocol=tcp to-addresses=192.168.1.108 to-ports=443 add action=dst-nat chain=dstnat comment="Off Trooleyb 1.109" dst-port=8109 protocol=tcp to-addresses=192.168.1.109 to-ports=443 add action=netmap chain=dstnat comment="AMD Vertikal" dst-port=3389 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3389 add action=netmap chain=dstnat comment="AMD BUH" dst-port=3390 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3390 add action=netmap chain=dstnat comment="AMD pallet" dst-port=3391 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3491 add action=netmap chain=dstnat comment=Metall dst-port=3392 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3392 add action=netmap chain=dstnat comment=14 dst-port=3397 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3397 add action=netmap chain=dstnat comment="my 7 043" dst-port=3398 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3398 add action=netmap chain=dstnat comment=temp1 dst-port=3396 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3396 add action=netmap chain=dstnat comment=09 dst-port=3393 in-interface=ether1 protocol=tcp to-addresses=192.168.1.42 to-ports=3393 add action=src-nat chain=srcnat comment="AP Troll-Off" dst-address=192.168.1.108 dst-port=443 protocol=tcp to-addresses=192.168.1.2 add action=src-nat chain=srcnat comment="AP Troll-Off 109" dst-address=192.168.1.109 dst-port=443 protocol=tcp to-addresses=192.168.1.2 add action=src-nat chain=srcnat comment="Router Buxx" dst-address=10.2.0.3 dst-port=80 protocol=tcp to-addresses=192.168.1.2 /ip proxy set cache-path=web-proxy1 enabled=yes /ip proxy access add action=deny redirect-to="ui-company.ru/index.php\?option=com_content&view=article&id=89&catid=10" /ip route add disabled=yes distance=2 gateway=xxx.xxx.217.129 routing-mark=conn_29 add distance=1 gateway=xxx.xxx.222.137 set enabled=yes primary-ntp=79.165.63.245 secondary-ntp=91.206.16.3 /system routerboard settings set silent-boot=no отключен-удален -
Я прописываю адреса # ADDRESS NETWORK INTERFACE 0 192.168.1.2/24 192.168.1.0 bridge1 1 xx.xxx.222.138/29 xx.xxx.222.136 ether1 -- /29 - рабочая --/28 - новые 11 xx.xxx.217.1/32 xx.xxx.217.130 ether1.vlan101 12 xx.xxx.217.1/32 xx.xxx.217.131 ether1.vlan104 13 xx.xxx.217.1/32 xx.xxx.217.132 ether1.vlan105 маршруты добавляются автоматом # DST-ADDRESS PREF-SRC GATEWAY DISTANCE 1 A S 0.0.0.0/0 xx.xxx.222.137 1 8 ADC xx.xxx.217.130/32 xx.xxx.217.1 ether1.vlan101 0 9 ADC xx.xxx.217.131/32 xx.xxx.217.1 ether1.vlan104 0 10 ADC xx.xxx.217.132/32 xx.xxx.217.1 ether1.vlan105 0 11 ADC xx.xxx.222.136/29 xx.xxx.222.138 ether1 0 12 ADC xx.xxx.222.139/32 10.2.0.1 <pppoe-webs2> 0 13 ADC xx.xxx.222.140/32 10.2.0.1 <pppoe-20340101... 0 14 ADC 192.168.1.0/24 192.168.1.2 bridge1 0 С моего оборудования шлюз xx.xxx.217.129 пингуется. Адреса xx.xxx.217.13х на вланах не доступны. Создаю ether1.vlan105 на 2 mikrotike - клиенте. подключен ether1 к bridge1 на 1-м. Прописываю статикой ip # ADDRESS NETWORK INTERFACE 0 192.168.0.211/24 192.168.0.0 ether2 1 192.168.1.211/24 192.168.1.0 ether1 2 xx.xxx.217.1/32 xx.xxx.217.132 ether1.vlan105 # DST-ADDRESS PREF-SRC GATEWAY DISTANCE 0 A S 0.0.0.0/0 192.168.1.2 5 1 ADC xx.xxx.217.132/32 xx.xxx.217.1 ether1.vlan105 0 2 ADC 192.168.0.0/24 192.168.0.211 ether2 0 3 ADC 192.168.1.0/24 192.168.1.211 ether1 0 шлюз xx.xxx.217.129 пингуется. xx.xxx.217.132 не пингуется. Что-то мне подсказывает, что я чего-то не дописал. Помогите плз. -
Вы не поверите. Я понимаю что это элементарные вещи. Но увы я программист а не сетевик. Не обучен. Но вот надо. Заказывал у трех человек написать конфиг. Взялись и ушли в туман). Так что буду пытаться. Спасибо Вам за участие. -
Обе сети смаршрутизированы на мой 1 порт. Мне нужно пробросить белые IP на вланы. Без nat желательно. Первая (/29) уже работает. Нужно пробросить вторую (/28). -
По такой схеме делаю. На втором mikrotike на vlan поднимаю dhcp-client. Адрес не получает. Связаноость м/у vlan не нужна. -
Добрый день. Прошу прощения за возврат к устаревшей теме. Уважаемый Saab95. У меня примерно такая-же задача, но уже есть одна подсеть от провайдера. /29 На 2-3-4-5 порт -бридж. На нем PPPoE Белые и серые IP Раздаются по PPPoE. Все прекрасно работает. Пров выделил еще подсеть- /28. Необходимо раздать по vlan. На каждый vlan - белый IP/ КАК лучше сдлелать или на бридже поднять вланы и по dhcp Спасибо.
