Пытаюсь настроить "Функционал IGMP Authentification"
Аутентификация проходит, мультикаст работает
Но возникли вопросы,
1) почему не шлется interim-update (имеется ввиду accounting) ?
2) можно ли сделать так, чтобы приходили запросы поля "User-Name" и "User-Password" вида "A8:F9:4B:22:9D:62"?
3) access-list - есть несколько листов, как задать конкретный лист? через радиус-атрибуты?
Edited by u.s.s.r
Конфиг
vlan 407
name multicast
multicast-vlan
multicast-vlan mode dynamic
multicast-vlan association 514
multicast destination-control
radius-server accounting-interim-update timeout 60
radius-server key 0 secret
radius-server authentication host 172.22.3.154
radius-server accounting host 172.22.3.154
aaa enable
radius nas-ipv4 172.22.6.19
Interface Ethernet1/1
ip multicast destination-control access-group 6002
switchport access vlan 514
loopback-detection specified-vlan 1
loopback-detection control shutdown
igmp snooping drop query
igmp snooping authentication enable
interface Vlan514
ip address 172.22.6.19 255.255.255.0
ip igmp snooping
ip igmp snooping authentication radius none
ip igmp snooping authentication forwarding-first
ip igmp snooping vlan 407
ip igmp snooping vlan 407 immediately-leave
ip igmp snooping vlan 407 l2-general-querier
ip default-gateway 172.22.6.254
в дебаг
%Jan 01 04:52:08 2006 authentication table timer is set value 600, and has been started
%Jan 01 04:52:10 2006 Send a authencation
%Jan 01 04:52:10 2006 Authencation Report Version: 2
%Jan 01 04:52:10 2006 Authencation Report Vlan: 407
%Jan 01 04:52:10 2006 Authencation Report Port: Ethernet1/1
%Jan 01 04:52:10 2006 Authencation Report Group: 224.1.0.7
%Jan 01 04:52:10 2006 Authencation Report SrcMac: A8:F9:4B:22:9D:62
%Jan 01 04:52:10 2006 Receive a authencation result
%Jan 01 04:52:10 2006 Authencation Version: 2
%Jan 01 04:52:10 2006 Authencation Vlan: 407
%Jan 01 04:52:10 2006 Authencation Port: Ethernet1/1
%Jan 01 04:52:10 2006 Authencation Group: 224.1.0.7
%Jan 01 04:52:10 2006 Authencation SrcMac: A8:F9:4B:22:9D:62
%Jan 01 04:52:10 2006 Authencation Result: AUTH_SUCCESS
%Jan 01 05:02:08 2006 global  authentication table timer expires
%Jan 01 05:02:08 2006 authentication table timer is stopped
%Jan 01 05:02:08 2006 authentication table timer is set value 600, and has been started
%Jan 01 05:02:38 2006 Authencation Report Version: 2
%Jan 01 05:02:38 2006 Authencation Report Vlan: 407
%Jan 01 05:02:38 2006 Authencation Report Port: Ethernet1/1
%Jan 01 05:02:38 2006 Authencation Report Group: 224.1.0.7
%Jan 01 05:02:38 2006 Authencation Report SrcMac: A8:F9:4B:22:9D:62
%Jan 01 05:02:38 2006 Receive a authencation result
%Jan 01 05:02:38 2006 Authencation Version: 2
%Jan 01 05:02:38 2006 Authencation Vlan: 407
%Jan 01 05:02:38 2006 Authencation Port: Ethernet1/1
%Jan 01 05:02:38 2006 Authencation Group: 224.1.0.7
%Jan 01 05:02:38 2006 Authencation SrcMac: A8:F9:4B:22:9D:62
%Jan 01 05:02:38 2006 Authencation Result: AUTH_SUCCESS
%Jan 01 05:12:08 2006 global  authentication table timer expires
%Jan 01 05:12:08 2006 authentication table timer is stopped
%Jan 01 05:12:08 2006 authentication table timer is set value 600, and has been started
%Jan 01 05:13:01 2006 Send a authencation
%Jan 01 05:13:01 2006 Authencation Report Version: 2
%Jan 01 05:13:01 2006 Authencation Report Vlan: 407
%Jan 01 05:13:01 2006 Authencation Report Port: Ethernet1/1
%Jan 01 05:13:01 2006 Authencation Report Group: 224.1.0.7
%Jan 01 05:13:01 2006 Authencation Report SrcMac: A8:F9:4B:22:9D:62
%Jan 01 05:13:01 2006 Receive a authencation result
%Jan 01 05:13:01 2006 Authencation Version: 2
%Jan 01 05:13:01 2006 Authencation Vlan: 407
%Jan 01 05:13:01 2006 Authencation Port: Ethernet1/1
%Jan 01 05:13:01 2006 Authencation Group: 224.1.0.7
%Jan 01 05:13:01 2006 Authencation SrcMac: A8:F9:4B:22:9D:62
%Jan 01 05:13:01 2006 Authencation Result: AUTH_SUCCESS
если кратко то:
1)Аккаунитниг для igmp authentication не поддерживается
2)Формат username и password не меняется
3)Акцесс лист передать через радиус атрибуты нельзя.
