Доброго всем дня,
имеем BDCOM™ P3310B Software, Version 10.1.0B Build 18099
vlan 333 в котором бежит мультикаст и DHCP сервер с порталом.
выключаю глобально мультикаст ip mcst disable телик показвает но пару минут. Через 15-20 секунд вещание возобновляется.
Current configuration:
!version 10.1.0B build 18099
service timestamps log date
service timestamps debug date
hostname olt1
ip default-gateway 10.0.36.33
spanning-tree mode rstp
aaa authentication login default local
aaa authentication enable default none
aaa authorization exec default local
username admin password 0 admin
epon onu-config-template T1
cmd-sequence 1 epon onu port 1 ctc vlan mode tag 1501
cmd-sequence 2 epon onu port 2 ctc vlan mode tag 720
cmd-sequence 3 epon onu port 3 ctc mcst mc-vlan add 333
cmd-sequence 4 epon onu port 3 ctc mcst tag-stripe enable
!!slot 0 84
interface GigaEthernet0/1
switchport trunk vlan-allowed 207,333,1501
switchport trunk vlan-untagged none
switchport mode trunk
switchport pvid 333
interface GigaEthernet0/2
shutdown
interface GigaEthernet0/3
shutdown
interface GigaEthernet0/4
shutdown
interface GigaEthernet0/5
shutdown
interface GigaEthernet0/6
shutdown
interface EPON0/1
epon pre-config-template T1 binded-onu-llid 1-64
epon bind-onu mac fcfa.f7d8.5ea8 1
interface EPON0/1:1
onu-configuration
!!onu-configuration-end
interface EPON0/2
shutdown
interface EPON0/3
shutdown
interface EPON0/4
shutdown
!!slot end
interface VLAN207
description -- mgmt interface --
ip address 10.0.36.59 255.255.255.224
vlan 207
name mgmt
vlan 333
name iptv
vlan 1,207,333
ip mcst enable
ip mcst mrouter interface GigaEthernet0/1
ip mcst mc-vlan 333 range 239.0.10.1 - 239.0.10.255
ip http language chinese
ip http server
!Pending configurations for absent linecards:
!No configurations pending global
!version 10.1.0B build 16358
logging x.x.x.x debugging
logging monitor alerts
logging trap debugging
hostname OLT_XXXX
ip default-gateway 10.10.10.1
no spanning-tree
username admin password 0 xxxxxxxxxxxxxxxxxxx
!!slot 0 84
shutdown
shutdown
shutdown
shutdown
switchport trunk vlan-allowed 102,252,256,50
switchport pvid 256
interface EPON0/1
shutdown
switchport trunk vlan-allowed 252,256,50
interface EPON0/2
shutdown
interface EPON0/2:1
onu-configuration
interface EPON0/2:2
onu-configuration
interface EPON0/3
shutdown
interface EPON0/4
shutdown
!!slot end
interface VLAN102
ip address 10.10.10.47 255.255.255.0
vlan 102
name Manage
vlan 252
name STB-Gepon
vlan 256
name MCST
vlan 50
name PPPOE
vlan 1,50,102,252,256
ip mcst enable
ip igmp-proxy enable
ip igmp-proxy last-member-query interval 3
ip mcst timer response-time 10
ip mcst mc-vlan 256 range 225.0.0.1 - 225.0.0.100
ip http server
snmp-server community 0 xxxx RW
vlan 50 - PPPOE
vlan 256 - влан с мультикастом
vlan 252 - влан с dhcp для STB и доступом к Middleware
на onu
epon onu port 1 ctc vlan mode tag 50
epon onu port 2 ctc vlan mode tag 252
epon onu port 2 ctc mcst tag-stripe enable
epon onu port 2 ctc mcst mc-vlan add 256
Всё работает как часы, пока не разнес по разным vlan портал и мультикаст - было также, как у вас.
Edited by uk2558
Конфиг привел к вашему виду. МУльтик пошел. Но не грузится портал хотя DHCP получаю.
Building configuration...
hostname olt1
no spanning-tree
cmd-sequence 3 epon onu port 3 ctc mcst tag-stripe enable
cmd-sequence 4 epon onu port 3 ctc mcst mc-vlan add 334
cmd-sequence 5 epon onu port 3 ctc vlan mode tag 333
!!slot 0 84
switchport pvid 334
shutdown
shutdown
shutdown
shutdown
shutdown
interface EPON0/1
interface EPON0/1:1
onu-configuration
interface EPON0/2
shutdown
interface EPON0/3
shutdown
interface EPON0/4
shutdown
!!slot end
interface VLAN207
vlan 207
name mgmt
vlan 333
name iptv_stb
vlan 334
name iptv_cast
vlan 720
name voip
vlan 1501
name pppoe
vlan 1,207,333-334,720,1501
ip mcst enable
ip mcst mc-vlan 334 range 239.0.10.1 - 239.0.10.255
ip http server
ПОхоже что то не нат с петлей. Длинк блокирует порты.
7796 2014-08-07 10:10:11 INFO(6) Port 21 link down
7795 2014-08-07 10:10:11 INFO(6) Port 22 link down
7794 2014-08-07 10:10:11 CRIT(2) Port 21 LBD loop occurred. Port blocked
7793 2014-08-07 10:10:11 CRIT(2) Port 22 LBD loop occurred. Port blocked
А что, сложно разнести на разные vlan без извращений?
Еще рекомендую добавить
