встала задача заменит quagga на microtik после настройки mikrotk с одним из провайдеров сесия не поднимается
/routing bgp peer
 0   name="1" instance=default remote-address=10.11.255.1
    remote-as=196x tcp-md5-key="" nexthop-choice=default multihop=yes
    route-reflect=no hold-time=3m ttl=255 in-filter=map-AS19x-in
    out-filter=map-AS19x-out address-families=ip
    update-source=178.217.x.x default-originate=never
    remove-private-as=no as-override=no passive=no use-bfd=no
в логах при этом
05:21:19 route,bgp,debug Update source
route,bgp,debug     Address=178.217.96.122
route,bgp,debug     Connecting
route,bgp,debug     RemoteAddress=10.11.255.1
route,bgp,info      Failed to open TCP connection: Network is unreachable
route,bgp,info     RemoteAddress=10.11.255.1
route,bgp,debug,packet UPDATE Message
в quagga бвло настроена так
 neighbor 10.11.255.1 remote-as 19x
neighbor 10.11.255.1 ebgp-multihop 3
neighbor 10.11.255.1 update-source 178.217.x.x
neighbor 10.11.255.1 weight 3000
neighbor 10.11.255.1 soft-reconfiguration inbound
neighbor 10.11.255.1 route-map map-AS19x-in in
neighbor 10.11.255.1 route-map map-AS19x-out out
