Всем привет, пытаюсь настроить VPN между Mikrotik RouterBoard RB951 и Cisco ASA 5505:
у микротика настроено 2 интерфейса: 10.34.1.50 - внешний, 192.168.88.1 - интерфейс внутренней сети
у Cisco ASA настроено 2 SVI: vlan1 10.34.1.51 - внешний; vlan2 192.168.1.1 - интерфейс другой внутренней сети. Конфиг Cisco ASA:
: Saved
ASA Version 7.2(4)
hostname ASA
enable password 2KFQnbNIdI.2KYOU encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif outside
security-level 0
ip address 10.34.1.51 255.255.254.0
interface Vlan2
nameif inside
security-level 100
ip address 192.168.1.1 255.255.255.0
interface Ethernet0/0
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone MSD 4
access-list HELP_ACL extended permit ip 192.168.1.0 255.255.255.0 192.168.88.0 255.255.255.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (inside) 1 interface
nat (outside) 1 0.0.0.0 0.0.0.0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.1.0 255.255.255.0 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set DES_SHA esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 144000
crypto map TEST_MAP 10 match address HELP_ACL
crypto map TEST_MAP 10 set pfs
crypto map TEST_MAP 10 set peer 10.34.1.50
crypto map TEST_MAP 10 set transform-set DES_SHA
crypto map TEST_MAP interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption des
hash md5
group 2
lifetime 1800
client-update enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config inside
tunnel-group 10.34.1.50 type ipsec-l2l
tunnel-group 10.34.1.50 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
message-length maximum client auto
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:b82ecf870d8dcc3c3c233f112298e761
: end
Настройки VPN Mikrotik приложены в картинках. На вкладке Installed SAs периодически появляются и исчезают SAs.
При отладке debug crypto isakmp 7 выводятся следующие сообщения:
ASA# Apr 24 16:14:51 [iKEv1]: IP = 10.34.1.50, Received encrypted packet with no matching SA, dropping
Apr 24 16:15:01 [iKEv1]: IP = 10.34.1.50, Received encrypted packet with no matching SA, dropping
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 104
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, processing SA payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, Oakley proposal is acceptable
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, processing VID payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, Received DPD VID
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, processing IKE SA payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, IKE SA Proposal # 1, Transform # 1 acceptable Matches global IKE entry # 2
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, constructing ISAKMP SA payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, constructing Fragmentation VID + extended capabilities payload
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 108
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + NONE (0) total length : 188
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, processing ke payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, processing ISA_KE payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, processing nonce payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, constructing ke payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, constructing nonce payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, constructing Cisco Unity VID payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, constructing xauth V6 VID payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, Send IOS VID
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, constructing VID payload
Apr 24 16:15:15 [iKEv1 DEBUG]: IP = 10.34.1.50, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, Connection landed on tunnel_group 10.34.1.50
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, Generating keys for Responder...
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 256
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + NONE (0) total length : 60
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing ID payload
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing hash payload
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, Computing hash for ISAKMP
Apr 24 16:15:15 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, Freeing previously allocated memory for authorization-dn-attributes
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing ID payload
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing hash payload
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing dpd vid payload
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + VENDOR (13) + NONE (0) total length : 80
Apr 24 16:15:15 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, PHASE 1 COMPLETED
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, Keep-alive type for this connection: DPD
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, Starting P1 rekey timer: 1350 seconds.
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, sending notify message
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing blank hash payload
Apr 24 16:15:15 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing qm hash payload
Apr 24 16:15:15 [iKEv1]: IP = 10.34.1.50, IKE_DECODE SENDING Message (msgid=163c7a52) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 84
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, Sending keep-alive of type DPD R-U-THERE (seq number 0x6471339c)
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing blank hash payload
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing qm hash payload
Apr 24 16:15:16 [iKEv1]: IP = 10.34.1.50, IKE_DECODE SENDING Message (msgid=88e17178) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Apr 24 16:15:16 [iKEv1]: IP = 10.34.1.50, IKE_DECODE RECEIVED Message (msgid=8c477232) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing hash payload
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing notify payload
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, Received keep-alive of type DPD R-U-THERE-ACK (seq number 0x6471339c)
Apr 24 16:15:16 [iKEv1]: IP = 10.34.1.50, IKE_DECODE RECEIVED Message (msgid=a1994cf2) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + KE (4) + ID (5) + ID (5) + NONE (0) total length : 292
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing SA payload
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing nonce payload
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing ke payload
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing ISA_KE for PFS in phase 2
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing ID payload
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, Received remote IP Proxy Subnet data in ID Payload: Address 192.168.88.0, Mask 255.255.255.0, Protocol 0, Port 0
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, Received local IP Proxy Subnet data in ID Payload: Address 192.168.1.0, Mask 255.255.255.0, Protocol 0, Port 0
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, QM IsRekeyed old sa not found by addr
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, Static Crypto Map check, checking map = TEST_MAP, seq = 10...
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, Static Crypto Map check, map TEST_MAP, seq = 10 is a successful match
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, IKE Remote Peer configured for crypto map: TEST_MAP
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, processing IPSec SA payload
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, All IPSec SA proposals found unacceptable!
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, sending notify message
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing ipsec notify payload for msg id a1994cf2
Apr 24 16:15:16 [iKEv1]: IP = 10.34.1.50, IKE_DECODE SENDING Message (msgid=f5c3cc1d) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 80
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, QM FSM error (P2 struct &0x175bec8, mess id 0xa1994cf2)!
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, IKE QM Responder FSM error history (struct &0x175bec8) <state>, <event>: QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, sending delete/delete with reason message
Apr 24 16:15:16 [iKEv1]: Group = 10.34.1.50, IP = 10.34.1.50, Removing peer from correlator table failed, no match!
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, IKE SA MM:0ddf4fef rcv'd Terminate: state MM_ACTIVE flags 0x00000042, refcnt 1, tuncnt 0
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, IKE SA MM:0ddf4fef terminating: flags 0x01000002, refcnt 0, tuncnt 0
Apr 24 16:15:16 [iKEv1 DEBUG]: Group = 10.34.1.50, IP = 10.34.1.50, constructing IKE delete payload
Apr 24 16:15:16 [iKEv1]: IP = 10.34.1.50, IKE_DECODE SENDING Message (msgid=c9b9dc3a) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 76
Apr 24 16:15:26 [iKEv1]: IP = 10.34.1.50, Received encrypted packet with no matching SA, dropping
Apr 24 16:15:36 [iKEv1]: IP = 10.34.1.50, Received encrypted packet with no matching SA, dropping
